01-04-2019, 11:42 PM
Anyone add weight to a 2019 TRD Pro
I’m happy that I made the switch from Jeep to Toyota. After all the stuff I did to the Jeep, I wanted to keep it simple and went with the 19 Pro. I did not plan to mess with the suspension. That being said, I would feel better with a winch since some of my hunting trails are deep and can get pretty wet. I ordered a c4 bumper last month and it shipped two days ago. I picked up a winch and am concerned the total weight will cause the front to sit much lower.
I thought I could simply change out the coils but after several calls, I have had zero luck finding a solution.
Has anyone added weight? If so what were the results or if you found heavier coils.
Thanks
01-04-2019, 11:44 PM
Real Name: 2017 TRD PRO
Thanks
I didn't see any drop in front when I added C4 bumper and 10k winch .. I highly suggest the corn-fed type of spacers to even out the front
01-05-2019, 12:33 PM
You should upgrade the suspension, when you do, I'll take those awful Fox Shocks off your hands.
In all seriousness, you should be fine.
01-05-2019, 02:42 PM
Banned
Banned
Lolz...at these TRD Pro owners making modifications before the ink is dry on their credit apps.
01-05-2019, 03:31 PM
lolz...where does it say he financed the vehicle? Lots of people here ordering up and planning mods before they take delivery....what's your point???
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
01-05-2019, 04:45 PM
Man you love to hate on the Pros. This is like the third thread I have seen you bash them. Guess I am crazy for adding a winch and bumper to my 4Runner, I should just tackle the mall parking lots instead of the woods.
Jealousy still does not look good on you bud. Thanks for the helpful post and good luck with your tires rubbing.
01-05-2019, 06:11 PM
Thanks
No expert here, but do you know about how much weight you’ll be adding? If so, can you simulate the weight somehow (hang weights from the frame somewhere near where the bumper/winch will be) and measure the change in height? Just a thought.
01-05-2019, 08:51 PM
Real Name: CJ
Real Name: CJ
I have an SSO Slimline bumper and winch totaling around 130 lbs on mine. I lost about 3/4" to sag on the "factory" Trail springs (590lbs?). I ended up going to an OME 885 which was almost perfect to offset that much weight, but I am on 5100's and could set my notch back at 0 to offset for the 2" lift the 885 advertised.
I think you are going to have to use a spacer cap if you find the droop objectionable. I'm just not familiar enough with the newer Fox shocks to make any recommendations for what might work since I don't know whether any of the current spring setups will fit them. The same problem applied to the older Bilstien TRD Pro setup because they had TRD Pro specific front springs and shocks, and wouldn't accept the available springs that fit the current 4Runner aftermarket. It's just too new a setup for most of us to be able to be much help.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
01-05-2019, 09:09 PM
Zero luck after several calls? Who the hell did you call?!
So many different options.. Check the stickies on the top of the forum.
Easy approach: Add .75-1" cornfed top spacer.
2015 Limited Blizzard Pearl: OEM TRD Pro Fox Suspension | 2”/2” Cornfed Spacers | TRD-OR 17" | 285/70/17 Firestone Destination A/T | Shrockworks Rocker Panels
01-05-2019, 10:11 PM
I see a resemblance.
2018 Off Road Premium - Magnetic Grey Metallic
01-05-2019, 10:22 PM
Banned
Banned
Lighten up Francis....this is the interwebz. And I’m probably 1 out of hundreds in here who tease and joke light heartedly the Pro guys. Why so touchy? You paid $50k for a 4runner...be proud and own it!
01-05-2019, 10:47 PM
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
01-05-2019, 11:33 PM
Banned
Banned
Originally Posted by mynameistory
Get that corn outa my face!!!!!
01-06-2019, 10:35 PM
I should have clarified. I meant I was trying to simply add a stronger spring.
01-06-2019, 10:37 PM
How did you know my name is Francis? I didn’t pay 50k and I like to be touched. Any other questions?
