Old 01-04-2019, 11:42 PM #1
Flea7907 Flea7907 is offline
Flea7907 will become famous soon enough
Anyone add weight to a 2019 TRD Pro
I’m happy that I made the switch from Jeep to Toyota. After all the stuff I did to the Jeep, I wanted to keep it simple and went with the 19 Pro. I did not plan to mess with the suspension. That being said, I would feel better with a winch since some of my hunting trails are deep and can get pretty wet. I ordered a c4 bumper last month and it shipped two days ago. I picked up a winch and am concerned the total weight will cause the front to sit much lower.
I thought I could simply change out the coils but after several calls, I have had zero luck finding a solution.
Has anyone added weight? If so what were the results or if you found heavier coils.
Thanks
Flea7907 is offline   Reply With QuoteReply With Quote
Old 01-04-2019, 11:44 PM #2
TaNk007 TaNk007 is offline
Real Name: 2017 TRD PRO
TaNk007 will become famous soon enough
Thanks
I didn't see any drop in front when I added C4 bumper and 10k winch .. I highly suggest the corn-fed type of spacers to even out the front
TaNk007 is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 12:33 PM #3
rihavens's Avatar
rihavens rihavens is offline
rihavens is on a distinguished road
rihavens's Avatar
You should upgrade the suspension, when you do, I'll take those awful Fox Shocks off your hands.
In all seriousness, you should be fine.
rihavens is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 02:42 PM #4
YellowSnow YellowSnow is offline
Banned
YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough
Banned
Lolz...at these TRD Pro owners making modifications before the ink is dry on their credit apps.
YellowSnow is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 03:31 PM #5
wsgoat's Avatar
wsgoat wsgoat is offline
wsgoat has a spectacular aura about wsgoat has a spectacular aura about
wsgoat's Avatar
lolz...where does it say he financed the vehicle? Lots of people here ordering up and planning mods before they take delivery....what's your point???
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
wsgoat is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 04:45 PM #6
Man you love to hate on the Pros. This is like the third thread I have seen you bash them. Guess I am crazy for adding a winch and bumper to my 4Runner, I should just tackle the mall parking lots instead of the woods.
Jealousy still does not look good on you bud. Thanks for the helpful post and good luck with your tires rubbing.
Old 01-05-2019, 06:11 PM #7
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Thanks
No expert here, but do you know about how much weight you’ll be adding? If so, can you simulate the weight somehow (hang weights from the frame somewhere near where the bumper/winch will be) and measure the change in height? Just a thought.
thennen is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 08:51 PM #8
3wbdriver's Avatar
3wbdriver 3wbdriver is offline
Real Name: CJ
3wbdriver will become famous soon enough
3wbdriver's Avatar
Real Name: CJ
I have an SSO Slimline bumper and winch totaling around 130 lbs on mine. I lost about 3/4" to sag on the "factory" Trail springs (590lbs?). I ended up going to an OME 885 which was almost perfect to offset that much weight, but I am on 5100's and could set my notch back at 0 to offset for the 2" lift the 885 advertised.
I think you are going to have to use a spacer cap if you find the droop objectionable. I'm just not familiar enough with the newer Fox shocks to make any recommendations for what might work since I don't know whether any of the current spring setups will fit them. The same problem applied to the older Bilstien TRD Pro setup because they had TRD Pro specific front springs and shocks, and wouldn't accept the available springs that fit the current 4Runner aftermarket. It's just too new a setup for most of us to be able to be much help.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
3wbdriver is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 09:09 PM #9
BIGpharma's Avatar
BIGpharma BIGpharma is offline
BIGpharma is a jewel in the rough BIGpharma is a jewel in the rough BIGpharma is a jewel in the rough
BIGpharma's Avatar
Zero luck after several calls? Who the hell did you call?!
So many different options.. Check the stickies on the top of the forum.
Easy approach: Add .75-1" cornfed top spacer.
2015 Limited Blizzard Pearl: OEM TRD Pro Fox Suspension | 2”/2” Cornfed Spacers | TRD-OR 17" | 285/70/17 Firestone Destination A/T | Shrockworks Rocker Panels
BIGpharma is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 10:11 PM #10
Rhinle's Avatar
Rhinle Rhinle is offline
Rhinle is on a distinguished road
Rhinle's Avatar
I see a resemblance.
Anyone add weight to a 2019 TRD Pro-61qqyq7qa0l-_sl1500_-jpg
2018 Off Road Premium - Magnetic Grey Metallic
Rhinle is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 10:22 PM #11
Banned
Banned
Lighten up Francis....this is the interwebz. And I’m probably 1 out of hundreds in here who tease and joke light heartedly the Pro guys. Why so touchy? You paid $50k for a 4runner...be proud and own it!
Old 01-05-2019, 10:47 PM #12
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 01-05-2019, 11:33 PM #13
Banned
Banned
Originally Posted by mynameistory View Post
Get that corn outa my face!!!!!
Old 01-06-2019, 10:35 PM #14
I should have clarified. I meant I was trying to simply add a stronger spring.
Old 01-06-2019, 10:37 PM #15
How did you know my name is Francis? I didn’t pay 50k and I like to be touched. Any other questions?
coils , jeep , pro , weight , winch
2019 6th Gen 4runner RunningLife 5th gen T4Rs 62 01-20-2019 11:40 PM
2019 TRD Pro's onepremiere General Discussions 233 10-03-2018 04:23 PM
2019 TRD Pro's JSparky 5th gen T4Rs 21 02-08-2018 08:36 PM
How much weight is too much weight for stock suspension? aelarson 5th gen T4Rs 16 11-08-2017 01:07 AM
Spare Wheel Weight vs. Alloy Wheel Weight xcmtb83 3rd gen T4Rs 4 11-26-2013 02:30 AM
