Old 01-06-2019, 05:58 PM #16
maybe they stripped it because you installed the sway bar and cross threaded the bolt.
Old 01-06-2019, 09:15 PM #17
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
This.
It’s highly unlikely they damaged it removing it, unless everything is rusting together and falling apart it’s much more likely the bolt was installed cross threaded and attempted removal revealed the damage already done.
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 10:57 PM #18
Originally Posted by Agent_Outside View Post
This.
i'm speaking from experience of creating my own problems lmao. i'm 99% sure i cross threaded one of the KDSS sway bar bolts last time i adjusted my 6112's...just closed one eye and torqued that bish down
Old 07-28-2020, 09:50 PM #19
jkaylen jkaylen is offline
jkaylen is on a distinguished road
I’m having the same issue. Top bolts on both the passenger and driver side KDSS have stripped the welded nut. I’m going to try to tap with the same size thread (M12, not sure if 1.25 or what size. Anyone know?)
If that fails, thoughts on either drilling out and using my own M12 nut stacked on the welded nut versus taping a larger, M14, hole (which would be harder to do). Spec is ~50ft lbs of torque.
jkaylen is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 10:38 PM #20
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
I never realized how many Karen’s drive 4Runners until i became a member of this forum.
Every few weeks i check in, read a thread like this and instantly remember why these forums suck.
GripT4R is offline   Reply With QuoteReply With Quote
bar , bolt , put , stripped , sway
Stripped Front Diff. Hex Drain Bolt josh.bunch 3rd gen T4Rs 78 11-07-2021 11:34 AM
Left Front Axle Leaking. Replace at dealer? Lolaya 4th Gen T4Rs 24 01-27-2019 07:27 PM
Anyone know the bolt size for front sway bar end clamp bolts? Okusputokus 5th gen T4Rs 0 01-02-2019 07:19 PM
HELP Sway bar end link bolt frozen and stripped buckeye4runner08 4th Gen T4Rs 8 07-11-2016 01:29 AM
Rear sway bar bolt stripped..... Ahhhhh xcmountain80 3rd gen T4Rs 14 08-28-2013 09:17 AM
