Old 01-05-2019, 11:50 PM #1
white4run white4run is offline
Real Name: PJ
white4run is on a distinguished road
Real Name: PJ
Dealer stripped left side front sway bar bolt
I took my Runner in for an oil change to Dealer. When they went to remove the oil filter they found the sway bar was in the way. I have an ICON lift that apparently caused this but my understanding is if you put the truck on the ground the bar moves out of the way. But they had it up on the lift, so there fix way to remove the sway bar. Doing this they stripped the bolt. They tapped it and put a new bolt with a double nut on the back.
Should I care? or let it go?
white4run is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 12:02 AM #2
willo willo is offline
Real Name: Will
willo is on a distinguished road
Real Name: Will
Which sway bar bolt? And yes you should care. They should replace the part that they stripped.
willo is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 12:14 AM #3
Riders of Lohan's Avatar
Riders of Lohan Riders of Lohan is offline
Riders of Lohan is on a distinguished road
Sounds like they did
Riders of Lohan is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 12:34 AM #4
Megalodon Megalodon is offline
Megalodon is an unknown quantity at this point
No way I would stand for this! They should swap it out for a brand new truck off the lot, or at least fully replace the entire suspension system. Nothing less! Get your lawyer involved if you have to!
Megalodon is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 12:35 AM #5
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
Wait, what?
How did the Icon lift block access to the oil filter?
I have an Icon lift and Toyota has done many oil changes and never advised the lift caused any blockage so that they have to remove the sway bar.
shrub1 is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 12:46 AM #6
YellowSnow YellowSnow is offline
Banned
YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough
Banned
Find a new dealer, or local shop who specializes in servicing rigs with aftermarket suspension.
YellowSnow is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 12:51 AM #7
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Yes you should care. But..... they broke it, then they fixed it. What else do you expect them to do? It's not like they can undo the stripped out bolt. The fix sounds legitimate to me.
nglayton is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 01:27 AM #8
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
They corrected the problem. You’re overreacting a bit much.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 08:09 AM #9
rasber3140's Avatar
rasber3140 rasber3140 is offline
rasber3140 is on a distinguished road
rasber3140's Avatar
I would care. Bolt removal and installation is a pretty basic process that you should be able to reasonably expect a dealer to perform. If it being aftermarket was going to be an issue they should have notified you before they began the work. I would start by asking them to pay to make it like new. You probably don't have a case to demand a new truck or an entirely new front suspension.
2019 4Runner SR5 Premium
2018 Tacoma TRD Off Road
2017 4Runner TRD Pro - SOLD
2003 Tacoma SR5 - SOLD
1999 4Runner Limited - SOLD
rasber3140 is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 11:22 AM #10
Agent_Outside's Avatar
Agent_Outside Agent_Outside is offline
Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice Agent_Outside is just really nice
There’s not enough info here to know what actually happened. Im assuming you’re trying to say the threads were damaged? It’s highly likely that it was the installation of that bolt that damaged it and the removal just revealed it.
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 11:53 AM #11
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
They didn't correct it. He said they tapped stripped thread, most likely put larger bolt in new thread and 2 nuts on the back of it. You want a new unaltered part and original size bolts. Go back and ask them to do it right this time. GL
<<<< is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 12:36 PM #12
That’s the repair I would do. Only other option would be to weld a nut onto the back. Given what transpired already, I wouldn’t let them do that. And good luck asking for all new shit. This is why I never take a car into a dealer.
Old 01-06-2019, 12:46 PM #13
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
None of this is adding up. The swaybar?
Do you think maybe they stripped a skid plate bolt? That needs to be removed to get to oil filter, not the sway bar.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 01-06-2019, 01:14 PM #14
Saker's Avatar
Saker Saker is offline
Saker's Avatar
OK, you said they stripped the bolt. If they stripped the bolt, they could have chased the frame threads and that should have made it good with replacement of the same size new bolt.
Now if they stripped the frame threads, they should have put a HeliCoil insert or a E-Z LOK insert to repair the threads and without need of double nutting or any other fix. If they tapped it, sounds like they went up one bolt size. That was taking a short cut!!! IMHO
I included a video of a HeliCoil insert process. How to Install a HeliCoil
Best Regards,
Saker
Old 01-06-2019, 05:49 PM #15
Judd94 Judd94 is offline
Judd94 is on a distinguished road
Can you post a pic of the new bolt? Also and I’m assuming you can take a pic of what it should look like on the other side. You should be able to measure the bolts and see if they’re the same size.
17 TRD O/RP Barcelona Red
6112/5160s- 1.6” Front and Dobinsons 599 Rear Coils
Philips 4300K HIDs/ Baja Designs Sport Amber WC
Husky Liners, N-Fab steps, Blackout Kit
Gibson Side Exit Exhaust
Judd94 is offline   Reply With QuoteReply With Quote
bar , bolt , put , stripped , sway
Stripped Front Diff. Hex Drain Bolt josh.bunch 3rd gen T4Rs 78 11-07-2021 11:34 AM
Left Front Axle Leaking. Replace at dealer? Lolaya 4th Gen T4Rs 24 01-27-2019 07:27 PM
Anyone know the bolt size for front sway bar end clamp bolts? Okusputokus 5th gen T4Rs 0 01-02-2019 07:19 PM
HELP Sway bar end link bolt frozen and stripped buckeye4runner08 4th Gen T4Rs 8 07-11-2016 01:29 AM
Rear sway bar bolt stripped..... Ahhhhh xcmountain80 3rd gen T4Rs 14 08-28-2013 09:17 AM
