Old 04-11-2019, 04:37 PM #1
Kingships Kingships is offline
Kingships will become famous soon enough
Something to look out for if installing a TRD Cold Air Intake
Installed the intake I received today from the TRD sale, fairly easy and did it myself in a few hours. Something I'm glad I caught however was a manufacturing defect in one of the couplers. The coupler that also connects to (i think the vacuum) tubing had a very small film of rubber on the inside where there was supposed to be a hole. Very easy fix with a knife or scissors, but would have been a complete pain if I hadn't noticed it.
Super White '19 TRDP, Eibach Lift Kit Springs F/R, Durobumps F/R, Spidertrax 1.25", TRD CAI, Shrockworks Sliders, DRZ Stealth 27" Light Bar, Baja Ladder, Canvasback liner, Ultimate camping mod, Accessorides Remote Start
Kingships is offline   Reply With QuoteReply With Quote
Old 04-11-2019, 04:38 PM #2
The thin film was on the inside of these 2 holes
Old 04-11-2019, 09:34 PM #3
krypto89 krypto89 is offline
krypto89 is on a distinguished road
thanks for the catch. waiting for mines to arrive and will definitely make the adjustment. so just to be sure, you removed the small film of rubber, correct?
krypto89 is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 10:42 AM #4
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Thanks for the heads up, still waiting on mine.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 11:38 AM #5
tstevens tstevens is offline
tstevens is on a distinguished road
Thanks for pointing this out! Waiting on ours to ship, just started processing yesterday.
tstevens is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 05:50 AM #6
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Also make sure the coupler from the pipe to the airbox is on there tight..
While revving hard (i.e. sand pulls), the engine tilts quite a bit and can pull the coupler off and risk pulling dust into the manifold
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 04-17-2019, 01:19 AM #7
Hydguy's Avatar
Hydguy Hydguy is offline
Hydguy will become famous soon enough Hydguy will become famous soon enough
Hydguy's Avatar
Mine was good.
If you guys are wondering what to do with the wire harness, here are some pics of what I did to reroute it.
In the last pic, I snapped the leg off the clip that was on the original airbox, then noticed there was a long flat clip taped further up the wire bundle towards the fender, so I just cut the tape and moved it so I could use it to attach the wire bundle to the new airbox.
2018 4Runner TRDORP MGM MODS: TRD Intake, full set of ARCLight Icraus Premium lights,Precision LED interior door/exterior lights, Rago MOLLE panels, Ellis Precision shift knobs w/Custom engraving, N-Fab nerf bars, 3-1 LED DRL/Fog lights.
Hydguy is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 04:26 PM #8
kfs-4runner kfs-4runner is offline
kfs-4runner is on a distinguished road
Relocating the MAF Sensor for TRD CAI
I am new to this forum I was just wondering if anyone has ever used a MAF Sensor extension cable as opposed to opening up the wiring harness to extend the MAF Sensor. Does anyone know if a cable for this application?
kfs-4runner is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 06:09 PM #9
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
Not sure why you would spend the money on it, literally takes 10 mins to untape and retape the MAF wires. Super simple and no tension on the MAF sensor.
MGordo is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 11:01 PM #10
The extender for the pre 2010 4Runners is 20 dollars from Michigan Auto sports or something like that. They do not have one for the newer 4Runners. For that kind of money I would prefer not taking apart a portion of my wiring harness. With my luck I will cut it in half.
Old 01-08-2020, 11:47 AM #11
Its really just unraveling some electrical tape.. dont even need a knife if you have finger nails.
easy , intake , pain , trd , tubing
'08 V8 stalls after installing new intake rokr1292 4th Gen T4Rs 11 01-13-2019 02:40 AM
Cold air intake or short ram air intake?? zu13 4th Gen T4Rs 3 05-12-2013 10:07 AM
Cold air intake with battery/intake swap on budget! Thurlo76 Classic T4Rs 13 05-24-2012 01:06 AM
Air intake crap - Kamotors Performance Carbon Fiber Filter 3" Cold Air Intake BMW VW Singtoe 3rd gen T4Rs 11 01-13-2012 06:51 PM
Installing Aftermarket Intake trd_style Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-14-2005 12:13 AM
