01-08-2019, 06:47 PM
#31
Real Name: B-Money
Real Name: B-Money
Every 30,000 miles is overkill. Even if you’re doing it yourself on the cheap, you’re wasting your time and money. The fluid is designed to last. In preparation for my 100,000 mile service, I changed all my major fluids for peace of mind. I feel good about that choice but anything under that mark seems entirely unnecessary.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
01-08-2019, 08:12 PM
#32
That may be true, but it's not your time/money being wasted; therefore, it's none of your business.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
01-08-2019, 08:32 PM
#33
Real Name: Morgan
Real Name: Morgan
I absolutely love “over maintaining” the 4Runner. Why? Cuz first of all it gets me out of the house and something to do. Second; I only drive it 10% of the time if that(and that’s off road usually) so the other 90% of the time it needs to be flawless and perform without question, I’m willing to use my money and my time to make sure that isn’t an issue. Most of all I enjoy the knowledge in the learning process, I can’t wait to teach the youngest two that are in it that 90%, the ins and outs and the know how of the vehicle.
2010 SR5 Blizz Pearl- Borla cat back, Firestone ride rite, Huskyliners, Afe Cai, Urd MAF, Gobi stealth with ladder, 5100s, icon 2" rear, toytec 1.6" front, TC UCA, HAF custom sliders, hand hold light mod, Led interior, stock rims and BFG KO2 265/70 C, Arb CKMA12- slider tanks w/ couplers, BD S8 10", opt7 40", BD dome light led in rear hatch
01-08-2019, 10:31 PM
#34
Looks like one is a quick and easy 3 quart swap, and one is several steps to change ~12 quarts or so. Which are you guys doing?
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
01-09-2019, 01:33 PM
#35
My first T4R was a 4th Gen purchased used from Dealer at 82K. It was a one previous owner and it excellent condition. I have them complete a full transmissions Drain, flush and refill. Sold to my Nephew at 115K who still has it at 175K......looks great and runs perfectly.
01-09-2019, 02:33 PM
#36
I have 97K miles on the 4runner (purchased new in 2011). I was thinking about changing the trans fluid (drain and fill not flush). I was planning on dropping the pan just to clean the pan, magnets and swapping the trans filter or strainer+pan gasket. Everything would cost around $115 for the parts I mentioned and 4 quarts since I was planning on only draining once.
I couldn't make up my mind whether draining once is okay or draining it 3 times is what I should do. Some say flush and some say drain/fill. Some say 30K some say 50K some say 60K and some say 100K. Some even say a trans fluid change can damage the trans. Toyota suggests to never change it unless you drive under aggressive conditions. My buddy is a mechanic and he told me not to touch it anytime soon. He suggested that I consider swapping the fluid around 150K - 200K.
At the end, I think I will just drive the 4runner until I either hit 150K or if I feel the shifting is not normal to do anything.
My uncle has a 2008 4Runner with over 175K and he never touched his trans fluid. No issue with his truck
01-09-2019, 08:10 PM
#38
On all three of mine, I dropped the pan, changed filter/screen, then flushed. Totaled around 12 qts. Yes expensive but I’d do it again.
2012 4Runner Limited 2WD
2006 4Runner Sport 4WD
2006 4Runner Sport 2WD
01-11-2019, 12:28 PM
#39
This is exactly what I'm talking about! There is no clear path haha
'12 Trail
Icon Stage 4 Billet
Stealth 6 Wheels with KO2's
Sliders
01-11-2019, 06:55 PM
#40
I used to do a spill and fill on my tacoma every 30k or so. Did it the first time at 120k when I got it. Used toyota WS fluid. Next two times I used valvoline maxlife fluid which is ws compatible but about half the cost. Didn't notice any difference. Fluid always looked fine and it shifted perfect when I sold it about 2 years ago. My 4Runner just hit 40k and it's never been touched. I'm currently on the hunt for a scan tool that will tell me trans temp to make it a little easier. And open the ABS pump for easier brake bleeding. Yeah I over maintain my stuff but it makes me feel better knowing the condition of what's in there. I'm sure the diff fluid in the rear is kinda nasty too.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
01-11-2019, 10:05 PM
#41
Originally Posted by Antman
I’m over 150k and I tow A LOT.
Still on the original 2011 fluid and guess what? I don’t ever plan on changing it. I’ll keep you guys posted lol.
Runs absolutely perfectly BTW.
My 2010 is also on the original fluid with 124k miles and I towed a 1200 lb aluminum fishing boat (total GVW including motor & trailer) about 12 times. I considered going to my local POS dealer, but since the punks that work there can't do anything right, I've decided not to change it. If Toyota claims that its tranny fluid is good for a lifetime, then I'll be happy to get 300k out of it. I think that it will be fine.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
01-17-2019, 09:41 PM
#42
Real Name: B-Money
Real Name: B-Money
Haha. Posts on a public opinion forum then tells me it’s none of my business...
You certainly can do whatever you’d like. The problem is that other, less mechanically inclined people come here for advice and see your post and may think that it’s necessary. It’s not. But please do whatever you’d like, by all means.
2010 4Runner SR5
