Old 09-11-2019, 09:12 PM #16
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
I'm running FN wheels 7x19 -10 (4.1" BS) with 305/70 RG's. I have a heavy BMC and did very little in back and have no rubbing. Also changed to 4.56 gears and i love it.
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 12:37 PM #17
aceee aceee is offline
aceee is on a distinguished road
Originally Posted by az1441 View Post
Sick now I just need to decide on which 17x9 -38s
Either SCS Ray 10 17x9 -38
OR
Method MR105 17x9 -38
Either will be on Toyo MT 33 12.50
anyone have opinions on either wheel?
Im on 17x9 -38 F5's with 33's. and i run them with 1.25" spacers..
aceee is offline   Reply With QuoteReply With Quote
Old 09-12-2019, 03:57 PM #18
r1verf3nix r1verf3nix is offline
r1verf3nix will become famous soon enough
Post a side profile that setup sounds sick, albeit really far out.
Also, what center cap do those F5s use? Looks almost like the old FJ Pro TRD caps.
r1verf3nix is offline   Reply With QuoteReply With Quote
Old 09-13-2019, 12:57 AM #19
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
f5's don't come with any center caps from scs
Old 09-13-2019, 11:29 AM #20
Cant find a side fitment shot, but I don't think its far out at all. But then again, I'm probably just used to it.
17x9 -38mm + 285s on 2.5" of lift...-truck1-jpg
Old 11-24-2019, 09:46 PM #21
DaveSmith DaveSmith is offline
DaveSmith is on a distinguished road
17x9 38mm Offset at full flex/stuff with 285/70/R17?
For the people running 17x9 -38 mm offset with 285/70/R17's and 3" lift with BMC, are you able to stuff the wheel up into the wheel well on full flex? Have you lost any up travel?
Can someone post some head on photos to show the offset out from the fender? Any photos at full stuff?
I like the idea of getting a slightly wider stance but I don't want to screw myself out of any up travel and tear off a fender. Trimming & cutting isn't an issue. I will be running 285/70/R17 Cooper ST MAXs with Icons Stage 7 suspension (billet UCAs), Body Mount Chop (BMC) and CBI front and rear bumpers.
Thanks.
DaveSmith is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 02:23 PM #22
Louisiana Overland's Avatar
Louisiana Overland Louisiana Overland is offline
Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough Louisiana Overland is a jewel in the rough
Thanks.
You wont have to do anything at all in rear. The BMC an UCAs with enough camber adjustment plus flap removal up front should get you pretty close. I still get a minir rub in reverse at full lock on the plastic rocker end cap. I havent trimmed it yet. I have offroaded plenty with the set up. No problem with articulatiion/stuffing.
Louisiana Overland is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 04:11 PM #23
Thanks for the response Louisiana Overland. I really appreciate the first hand information from someone like yourself that fully flexes their suspension off road.
This spring I'm going to pull the trigger on the SCS Ray 10s (17x9 -38 Offset) with Cooper ST Max 285/70/R17s. I know each 4-runner is unique when it comes to exact clearances but after reading that anchr3d (on Instagram) tore his driver side fender off with a 3" King lift, Icon UCAs, BMC and trimming while running the SCS Ray 10s 17x9s with 295/70/R17 Cooper ST Pros's I'll stick with slightly smaller 285's on the wider 17x9 Ray 10s.
I'll just go slow at first and keep trimming until I'm sure I have 100% clearance at full articulation/stuff.
moving , stock , understand , wheel , wide
17x9 0 offset 5" backspace with 285s HokieRunner 4th Gen T4Rs 4 02-03-2014 04:41 PM
Could I run 30-31" 285s with out a lift? 7B Snow 3rd gen T4Rs 13 05-08-2013 11:19 PM
Anyone else running 17x9 on 285s? adio3x 5th gen T4Rs 11 04-26-2013 07:28 PM
285s With Stock Suspension and a 1" Body Lift spectre6000 3rd gen T4Rs 15 08-05-2012 06:01 PM
Anyone in the Seattle area with a 3" lift and 285s? Noynumal 3rd gen T4Rs 10 11-07-2011 09:58 PM
