View Poll Results: Is there a way to make headlights to auto-turn-off w/o opening doors post shutdown?
Yes, I will share the info now
4 |
66.67% |
4 |
66.67% |
No, I have verified it is impossible
0 |
0% |
0 |
0% |
TLDR; I don't care about you
2 |
33.33% |
2 |
33.33% |
01-10-2019, 12:28 PM
#16
I updated my post.
2016 4Runner Limited
01-10-2019, 12:40 PM
#17
Real Name: Joe-Runner
Originally Posted by Superjet
The Compustar can be wired to trigger the door pin on shut down. Depending on which Compustar, it's most likely Orange wire rearm output to the drivers door pin which is red. It will pulse this wire briefly wit ha ground trigger tricking the vehicle into thinking the door opened then closed.
Seems easy enough. Hope I can find time to give this a shot this weekend! Thanks!
01-10-2019, 02:17 PM
#18
Originally Posted by Joe-Runner
So, little update:
I recently installed Xenon Depot Xtreme LED low beams, and a side effect was disabling the DRL when the stick is switched all the way to "off." Previously, when remote start was ended the DRLs would stay on indefinitely, if the stick was "off." Now, since the Xenons seem to disable the DRLs, the lights do turn completely off after remote start has been ended.
However, if I accidentally leave my low beams on, the lights will stay on until the battery is dead. This is the scenario I would like to hear people's input on.
You've lost me here, DRL's run the high beam bulb at a lesser voltage, converting the low beams to LED should have no effect on the DRL's.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
01-10-2019, 02:21 PM
#19
Couldn't agree more. I was surprised myself. There has been some discussion on these forums about it, and several other members with my same setup ended up with the same exact results.
01-10-2019, 03:04 PM
#20
Well, I have the XD Extreme HID kit on my low beams, and no side effects, just great light output, FWIW.
01-10-2019, 03:14 PM
#21
Gray connector on brain, solid orange to the red wire at fusebox shown in the pic.
To test when done, remote start it, then deactivate the remote start with the remote and do not open the door. The lights should time out under a minute.
01-10-2019, 03:39 PM
#22
Originally Posted by Baystate4Runner
Thanks - I would have lost that bet. Just checked Toyota website and auto headlights is indeed only available on PRO and Limited models. Wouldn't have expected that.
a few of us are working on changing that.
Automatic headlights at night : possible mod?
Stay tuned...
01-11-2019, 10:56 AM
#23
This will most likely trip the factory alarm, assuming the doors are locked (which they should be).
2016 TEP NBlue KDSS
01-11-2019, 12:17 PM
#24
The factory alarm isn't armed during remote start
