Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Old 01-14-2017, 11:46 PM #1
mosovich mosovich is offline
mosovich is on a distinguished road
Where is your ARB Compressor Mounted?
Ok guys, I'm having a hard time with this.. Where did you mount and how, your ARB compressor? I have the single one.. Thanks in advance!!
mosovich is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 01:00 AM #2
Jhalko's Avatar
Jhalko Jhalko is offline
Real Name: Halko
Jhalko has a spectacular aura about Jhalko has a spectacular aura about
Jhalko's Avatar
Real Name: Halko
Bandimount under hood, easy peasy!
http://www.toyota-4runner.org/sale-t...easant-nj.html
Thank you bandi for the 5th gen ARB compressor mount
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
Jhalko is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 08:13 AM #3
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
For the single...
Slee - Compressed Air Products
Install by @MTN4RNR
Building, Driving and Adventuring the MTN4RNR
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 08:19 AM #4
4Roamer 4Roamer is offline
4Roamer is on a distinguished road
I have the Slee mount as well. I chose that one because it dose not block my options for a second battery, if I decide to do that.
4Roamer is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 01:11 PM #5
ToyoDriver's Avatar
ToyoDriver ToyoDriver is offline
ToyoDriver is on a distinguished road
ToyoDriver's Avatar
I just want to inflate my 265 KO2s to 37psi after offroading at ~15PSI.
Will a single ARB work or should I just get a double? Also, is there any reason to run a switch to the cab for these? If I'm using the compressor I'll be under the hood anyway...but I'm not sure how I'd wire up a switch on the compressor itself anyway.
ToyoDriver is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 01:38 PM #6
raycie raycie is offline
raycie is on a distinguished road
It will take a lot longer.... as for the switch, it comes with everything you need.... I swapped the ARB switch for a AOB push button...
OP - I also have a twin with the bandi mount....
My Build------>http://www.toyota-4runner.org/5th-ge...ail-build.html
IG - @battadohana
raycie is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 01:50 PM #7
Cymon's Avatar
Real Name: Chris
Cymon's Avatar
Real Name: Chris
The single will work just fine. It's more powerful than my portable Masterflow and I can air up to 34 psi in about 2 minutes a tire. In terms of the wiring it is not that difficult (and that is coming from a non-mechanically inclined person). You would wire in a similar way to my light bar install described in this link.
"If I can do It You Can" Behind Grill Light Bar Install
Also if you look at the post I made above @MTN4RNR goes through the wiring including how to use an add-a-fuse in his install. If you go this route, it sounds like we are in the same area, pm me and maybe we can meet up and I'll help the best I can with the install.
ARB Breather Mod
Old 01-15-2017, 01:54 PM #8
How hard was it going from the ARB switch to the AOB switch. I want to do AOB switches.. Thanks..
Also thanks to everyone for the replies. I'm going to order the Slee tomorrow..
Old 01-15-2017, 02:04 PM #9
Liquidmantis's Avatar
Liquidmantis Liquidmantis is offline
Real Name: Will
Liquidmantis is on a distinguished road
Real Name: Will
My dual ARB is currently mounted in the passenger side firewall "hole" that the Bandi mount uses. I fabricated my own as I was in a rush but I would have bought the Bandi otherwise.
I bought the Slee compressor bracket though as I'm currently using it for my onboard charger and it makes a great shelf in the driver side firewall hole. However, I will most likely be relocating the compressor to it. Between wanting to eventually wire up dual batteries, and also have the option to relocate the washer reservoir should I decide to install a full bumper, the passenger side pockets are already overbooked. This is exactly why I got the Slee bracket for the onboard charger though: options and future-proofing. Now I just have to figure out where the charger will get displaced to...
Liquidmantis's modest [boring] build thread
2016 MGM TEP w/KDSS | OME BP-51 w/ 2889 rear | SSO Bumper | Warn Zeon 10-S Plat | TRD Pro wheels | BFG K02 275/70/17 | RCI sliders | RCI alu skids | Gobi Stealth No Rise | 1Up USA hitch rack
Liquidmantis is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 02:56 PM #10
LawnDart's Avatar
LawnDart LawnDart is offline
LawnDart will become famous soon enough LawnDart will become famous soon enough
LawnDart's Avatar
I'm rocking the Bandiworld mount, my second actually, as I asked Leroy to custom fab me one with the ability to securly mount my manifold kit, which is used for my front air locker.
Awesome mounts, but kind of a bear to wrestle into place and bolt down. I was going to run an air tank before 1. I realized how hard it was installing without a tank. And 2. Even ARB told me the tank wasn't worth it unless I was running air tools...which I don't plan on ever doing.
An air tank will save you like 5-10 seconds before you can start filling up a tire...not worth the effort.
I don't own a 4Runner anymore.
LawnDart is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 03:36 PM #11
Real Name: Will
Real Name: Will
Yeah, a tiny 1 gal or even 2 gal tank will give you a quick burst but filling tires (and even sustained tool usage) is all about CFM.
Old 01-15-2017, 05:21 PM #12
Ducmonsta's Avatar
Ducmonsta Ducmonsta is offline
Ducmonsta will become famous soon enough
Ducmonsta's Avatar
My dual is in my rear quarter panel.
Ducmonsta's Build Thread-very pic heavy!
Ducmonsta is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 08:16 PM #13
Super easy..... basically cutting off the female connectors and attaching them to the AOB switch harness. I've had the switch always hot as well as ignition controlled. Can choose which one you prefer.
IG - @battadohana
Old 06-04-2017, 12:05 AM #14
spizike9 spizike9 is offline
spizike9 is on a distinguished road
I was thinking about getting the SLEE mount for my ARB compressor. Based on their install instructions it looks like it uses two of the mounting points that the @RagoFabrication relay holder uses. Does anyone know if these two play nice together or if I have to choose one or the other?
spizike9 is offline   Reply With QuoteReply With Quote
Old 06-04-2017, 12:31 PM #15
Concon40's Avatar
Concon40 Concon40 is offline
Concon40 is on a distinguished road
Concon40's Avatar
has anyone mounted the single in the rear cargo area? Seems like it would be nicer to hang out under the rear hatch if the weather was bad. I'd love to see some photos of rear mounts
Live Free, Play Hard.
Concon40 is offline   Reply With QuoteReply With Quote
Compressor mounted. mavrick1903 4th Gen T4Rs 2 04-10-2016 08:10 PM
Train horn install with engine mounted compressor?? Jason B 3rd gen T4Rs 5 02-02-2016 12:52 PM
air compressor , mounted underhood VBdiver 5th gen T4Rs 27 07-15-2013 07:24 PM
Roof mounted or bumper mounted lights OCMike Classic T4Rs 8 04-17-2012 08:37 PM
strut compressor vs. spring compressor jmrwd3 3rd gen T4Rs 6 05-19-2008 03:03 AM
