Old 05-27-2021, 08:30 AM #1
Yukon4Runner's Avatar
Yukon4Runner Yukon4Runner is offline
Yukon4Runner is on a distinguished road
Grabber X3: will they fit?
Hello all,
I’m looking at buying a set of off road Grabber X3. Going to go with the 265/70R17 as I have a leftover set of stock rims.
The 5th gen is stock, no mods.
According to tirerack, the off road Grabber X3 265/70R17 won’t fit.
Instead they recommend the on/off road GRABBER A/TX 265/70R17.
Does anyone know if the Grabber X3 265/70R17 will fit an unmodified 5th gen? And if not, what mod needs to be made?
Thanks.
2016 TEP KDSS
2001 SR5 195k
The petting zoo closes at 2:00, the goat roast follows at 3:00
Yukon4Runner is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 08:42 AM #2
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
If you have OEM rims (non-TRD Pro) they should fit without any modification. If you have TRD-Pro rims on a non-trd pro they will fit but may require some fender pushing/trimming due to the different offset (TRD Pros are pre-trimmed at port). For reference I had 275 70r 17 Coopers that fit with no modification to my stock SR5 (32" tire). The Grabber X3 are listed as 31.6" diameter, 10.7" width. I currently run 265 Falken Wildpeak, 31.7" diameter, 10.8" width and they also fit without modification.
Tire Rack may say it doesn't fit because they only come in Load Range E, so it may be because of load as opposed to actual size...just a guess. They'll work just run the pressure at 40-44 psi depending on your vehicle weight (You can technically run as low as about 32psi at highway speeds safely but they may not wear evenly).
Rated 3195lbs per tire at 80psi.
4,800 lbs (4runner weight)/ 4 Tires = ~1,200lbs per tire
1,200lbs per tire/ 3195lbs @80 psi = .38 of load
This means the load at 4800 lbs vehicle weight is 38% of what they can handle at highway speeds.
38% of 80 psi = 30.4 psi... That is the minimum tire pressure you can run safely at highway speeds for 4800lbs of truck weight.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 09:05 AM #3
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
Originally Posted by Cymon View Post
If you have OEM rims (non-TRD Pro) they should fit without any modification. If you have TRD-Pro rims on a non-trd pro they will fit but may require some fender pushing/trimming due to the different offset (TRD Pros are pre-trimmed at port). For reference I used to have 275 70r 17 Coopers that fit with no modification to my stock SR5 (32" tire). The Grabber X3 are listed as 31.6" diameter, 10.7" width. I currently run 265 Falken Wildpeak, 31.7" diameter, 10.8" width and they also fit without modification.
tm965 is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 09:13 AM #4
@Cymon
Thanks for the detailed reply.
2016 TEP KDSS
2001 SR5 195k
Old 05-27-2021, 09:30 AM #5
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
If you do end up having to trim the bumper because you have the TRD Pro style wheels, here's the official Toyota procedures they perform on the Pros.
T-SB-0009-15.pdf - Google Drive
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
265/70r17 , fit , grabber , road , set
Grabber AT2's MATTYDIRT 5th gen T4Rs 22 11-10-2018 12:22 PM
Grabber X3 RedSled General Discussions 1 11-08-2016 01:26 PM
FS: 265/70-17 Grabber AT2 (Qty 4)- $250 Greydog For Sale: Suspension/Wheels/Tires 0 04-19-2015 11:08 AM
GRABBER AT2 tire deedst4r 4th Gen T4Rs 3 08-08-2011 10:10 AM
Grabber A/T2 vs Dakota A/T2 BobLMTDT4R Engines / Suspension / Wheels / Tires / Audio / Accessories 7 02-20-2011 12:13 AM
