Originally Posted by baysta
The point of the discussion here is to see two near-identical trannies with the difference of a couple solenoids, and how one could potentially give us a 6th gear without much extra work. I don't see how your suggestion would be any easier or any more useful, if it costs more and requires more parts to be replaced.
See below post:
Originally Posted by Turfboy
I would think you have to get into the ECU program to evaluate it. It is kind of like the development of the supercharger where everything runs through the computer and while the mechanical side gets solved relatively quickly, no one knows how the electronics will respond. My guess is the whole enchilada is wrapped together (throttle, emissions, speed, gearing) but now that you bring it up someone on the site is bound to try it and I can watch.
"A couple of extra solenoids" could mean a different ECU, different wiring and maybe different external sensors. Replacement would be easier than digging into the harness and trying to find the correct ECU that will probably come from overseas. Will that ECU work with the VATS system in the US? Will it communicate with the 4wd ECU? US cluster? A couple of extra solenoids can add up to a lot more work than you think.
