01-11-2019, 03:57 PM
#16
Real Name: Paul
Real Name: Paul
Originally Posted by Bayou_Pro
I did the conversion on my CTS-V but it was for horsepower reasons. On 14psi of boost I can dial in 8 degrees more timing and makes 80hp more on the corn.
You beat me to the response, sometimes the e85 is a crazy HP gainer. I think the Tundra 5.6 L is flex fuel, does it also get extra HPs with the corn gas? This stuff it everywhere in the Midwest. I only put it in rentals to fill it up to full when I return it.
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
01-11-2019, 04:24 PM
#17
To OP:
I would not recommend it… Here are some problems I see with ethanol:
1) Cost more to produce than it worth -therefore subsides by Government -AKA taxpayers- so we all are paying for that “experiment”
2) You are burning more oil to collect the corn for ethanol production.
3) Feed corn price are pushed a lot higher (at least 100% higher) because it is now used (wasted) on ethanol production, that propagates all the way from the farm to store shelf and we all are paying for it.
4) Ethanol is much worse than gasoline as a fuel: 50% less efficient, attracts water and it does break down faster than gasoline, increases gasoline vapor pressure, it is very chemically aggressive and eats robber seals\houses- those are made from oil and needs replacement, removes oil from engine parts (including cylinder walls\rings\pistons) therefore decreases the life of the engine and its parts- and in order to replace those you need more oil again…
My $.02.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
01-11-2019, 04:33 PM
#18
I think he was saying he tuned his car and did a lot of extra work to take advantage of ethanol's burn properties. But the normal vehicle like the Tundra you mentioned will actually lose horsepower and fuel economy.
01-11-2019, 09:09 PM
#20
Yes I did a lot to make it work right. I do disagree with you on a tundra will lose HP on corn. It should make more hp but a naturally aspirated motor the gain are not much. GMs new 5.3 motor I know is rated for 10+ hp when using Flex.
You are correct on the economy though, it will suffer. The loss of economy will offset the cost savings of the fuel.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
01-11-2019, 10:12 PM
#21
I may be wrong. No personal experience, just going by what I’ve read and a friend’s experience with his Ford pickup that he said was significantly under-powered when running E-85.
01-12-2019, 07:14 AM
#22
Originally Posted by jhguth
i don't think a kit exists for the 5th gen 4runner
and i get the desire, my background is agricultural and environmental engineering, but if you are talking land replacement it's food vs fuel or if you are talking separate land it has a greater footprint than oil, so basically no one wins except the corn lobby (which is why e85 is a thing). if cellulosic sources become more economical/popular (my undergrad did a lot wof research into sweet sorghum) it will become a better option, but for now corn is king.
Just an universal kit.
Yes some of it is desire. I guess I will wait until there is an alternate source material if that pans out...
Of you are asking me if I would do it again? Hell yes. My car is a beast with the added boost and running. I hate it when I can't find corn and have to run 93. Nothing like 750hp daily driven street car!!!!
It wasn't cheap for me to do it though. The flex kit was only $300 but then I had to add a second fuel pump for $1000 and a set of $1100 fuel injectors. Of then the custom ECU tune for $550. Totally work it, YES!!
You are going to see 0 hp increase on a 4runner, at least an increase you will notice. The fuel saving will probably be close to a wash. There are also maintenance issue will E-85 as well. Are you pump and house rated for full ethenol? Combustion Temps are much lower and build up and deposits can be an issue. No way would I personally convert my 4runner to it, nor would I run it if my truck was flex from the factory.
So basically the ideal engine for ethanol is one with a turbo, upgrade fuel system and a tune.
Why would you not run ethanol in a flex vehicle?
Originally Posted by progress4m
To OP:
My $.02.
Did not account for the subsidies. Not hundred percent but the by products of ethanol production are still used correct? I see how feed corn prices are upped and how that would take land away from actual food production. Thanks.
01-12-2019, 09:25 AM
#23
Yes any boosted vehicle can greatly benefit power wise from ethenol. Mine happens to be supercharged. The reasons I wouldn't run it in my truck would be loss of economy and ethenol is hard on parts. Zero benefits and I have to fill up more often.
Paul
01-12-2019, 10:32 AM
#24
I know that's thrown around a lot but is that really true? Or how do you mean? On the front end, Most people use the food vs fuel debate but ethanol depending on how and what it's made of is 'better' for the planet. On the back end, it definitely burns cleaner.
The other moral part is oil dependence is not good for the USA.
The U.S. is currently a net exporter of oil.
