Old 01-11-2019, 07:26 PM #1
TX4runr TX4runr is offline
Real Name: Martin
TX4runr is on a distinguished road
Real Name: Martin
On-Board-Air: Tubing Diagram
I saw the kit that @sponsoredbywifey built for his 4runner. He had a parts list online but not instructions or diagrams of how to install. So I created this diagram along with a detailed parts list. Nothing fancy but should help those that are handy.
I didn't come up with the idea of this system, but I did put together this information! All credit for the parts and idea is to @sponsoredbywifey . Rago Fabrications also sells a kit here:
The "Wifey" Air System – Rago Fabrication
Cheers!
2014 Trail
Follow my build on Instagram: TX4runr
TX4runr is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 03:46 PM #2
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Cool concept. Looks like a lot of potential leak points. Might want to think about keeping the system slightly pressurized at all times to detect a leak sooner rather than later.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 04:35 PM #3
oldschoolpl510 oldschoolpl510 is offline
oldschoolpl510 is on a distinguished road
Thank You TX4runr. Your diagram was very helpful in putting together my "wifey" system. I've gathered all of the components including the mounts from Rago. Once I get it all installed I will post pics.
Tip: I have been testing the system with a bicycle pump (valve to the compressor closed).
oldschoolpl510 is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 12:13 AM #4
dom42 dom42 is offline
dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light
Nice. Good info. Thanks. On-Board-Air: Tubing Diagram
dom42 is offline   Reply With QuoteReply With Quote
Old 07-03-2021, 11:58 PM #5
firegod33r's Avatar
firegod33r firegod33r is offline
firegod33r is on a distinguished road
firegod33r's Avatar
[QUOTE=TX4runr;3207801]I saw the kit that @sponsoredbywifey built for his 4runner. He had a parts list online but not instructions or diagrams of how to install. So I created this diagram along with a detailed parts list. Nothing fancy but should help those that are handy.
Cheers!
Can you shed some light on how you installed the ARB air hose coupling before it goes into the Wifey system, was this a kit? I can see the two 90 elbows but not ho the coupling is attached.
for all I know this may be sitting in my dual compressor box that I have not even opened yet so pardon my lack of knowledge here. also I'm guessing you're using a bandi mount and its just enough room to clear the hood with the coupling?
Thanks
firegod33r is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 12:51 AM #6
jrza101's Avatar
jrza101 jrza101 is offline
jrza101 is on a distinguished road
jrza101's Avatar
Cheers!
I’m about to install this on my 2020 ORP (many thanks by the way for the hard work on the diagram!!) and I am using the compressor tray by Rago. One downside I have learned is that in 2020+ there is a relay switch in that same area where the tray mounts, have you heard/seen a workaround for this? Thanks in advance!
jrza101 is offline   Reply With QuoteReply With Quote
Old 09-13-2022, 02:39 PM #7
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
What is the need of the PRV on the manifold? I have been collecting parts for building a system, and I'm not seeing the need for a PRV there. The compressor already has one, not sure what I'm missing. Has anyone tried putting a pressure switch that would shut of at the desired inflation level? I supposed the line pressure would have to be less than the wanted PSI so it might not work. Also any reason that a ball valve wouldn't work in place of the hand slide valve?
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
diagram , idea , kit , list , parts
97 4Runner ECU/ECM wiring diagram/PIN diagram Dawgz 3rd gen T4Rs 5 02-20-2023 03:04 PM
Need advice on tubing my wells... DeTwizzle 3rd gen T4Rs 14 02-09-2019 03:51 PM
2005 4runner running board light wiring diagram Greenbean80 4th Gen T4Rs 2 04-11-2015 10:40 PM
Anyone got the diagram for connector G18 (electric wiring diagram) jicko 5th gen T4Rs 0 04-03-2015 10:01 PM
what size tubing ron70062 3rd gen T4Rs 13 08-30-2008 06:43 AM
