Old 01-12-2019, 08:33 PM #16
ToolUser1 ToolUser1 is offline
ToolUser1 is on a distinguished road
Originally Posted by mo_mo View Post
I'm not telling you that prior to 200x Toyota received tens of thousands of complaints. I'm telling you that they would receive those complaints today. Go down to the dealership or local rental car agency and take a look at the HVAC systems of the vehicles on the lot. You're going to find that they all behave similar to your 5th gen 4Runner. If Toyota didn't add this feature/bug, then everyone else that is used to having it automated would be ragging on it. Instead they only have you. Therefore they got it right. Now it might be nice if it was a dealer adjustable feature or carista type setting, but you lose.
Also, my 4-wheel drive still works even if there is an engine code. Now A-trac/crawl control/multi-terrain-select will not function, but I still have 4-wheel drive with low range (I'm not sure about the locker under this scenario). Another reason to carry an OBDII reader to reset the system if you are in a bind.
I was about to concede the point since I only rent cars a few times a year, usually in the summer... But I just went out to my wife's '18 Honda Pilot Elite with it's puky giant touchscreen based dash console, and low & behold even that user interface nightmare lets you select defrost and recirc at the same time. Even on the high setting (gasp!). So no, I don't agree. This is simply a bad user interface choice by a marketing or PM shmuck at Toyota who thinks its cool for a car to "think" for you. Even if the thinking is really bad.
And I'll test my 4wd again, but am pretty sure that when I tested it a couple years ago it wouldn't go into 4wd if the check engine light was on - even for a *totally unrelated* issue. And yes, that made me always carry a code scanner in the vehicle - but you can't really believe that's a good solution for the average suburbanite do you? That one is beyond the marketing dept and is simply bad engineering design. Failure modes should ALWAYS be isolated to just the affected systems. Again, it's not like it's a hard software problem.
And yes, I'm just one consumer - but a thoughtful and discriminating one dead in the middle of Toyota's target demographic...
ToolUser1 is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 09:12 PM #17
lakerman lakerman is offline
lakerman is on a distinguished road
Go back to 1997
My old tacoma had this going back to 1997 , fresh air and ac kicks on with the defrost, which will suck out that moisture=no fogging up windshield,and a twenty degree drop with highs of -20 degrees celsius coming where I live.Love the north!
lakerman is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 10:02 PM #18
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Does the pilot automatically turn on the A/C when defrost is selected? If car manufacturers went with your philosophy, then they would leave the A/C in the last selected mode and let those pesky drivers smarten up on their own... read the manual and all that jazz.
I only had an engine code once at about 2000 miles, no fault found and cleared by the dealer with no hiccups in the next 7xk+ miles. I intentionally put it into 4wd, by the lever, and I recall the drivetrain bound up and the 4wd icon wasn't flashing (lots of other lights were flashing), but I could be wrong. I'm not planning on pulling a fuse to check it.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 11:18 PM #19
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
I use recirc/defrost/AC/heater all the time in my VW. It’s actualy listed in their “tips” for faster defrost and intentionally allowed.
Weird that the 4Runner won’t even allow the recirc to stay on during normal use, ill have to double check that.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 01-13-2019, 12:35 PM #20
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Originally Posted by JpAdct View Post
I know it sounds backwards and wasteful, but I run heat with the AC on a lot during the winter. It allows me to keep it on recirculate and prevents fogging up.
I think this is what other manufacturers call "DE-ICE" mode. I was told.....the A/C pulls the moisture out of the air, getting at the 'dry' air you need.
That worked! Hold the recirc button down long enough and it will stay on until you turn it off. Still doesn't work with defrost, and there's no beep so I'm not sure how long you need to hold it down, but I'll take it.
Thanks again!
I could swear mine makes a small beep, either way, I'm glad to hear it works for you as well.
nglayton is offline   Reply With QuoteReply With Quote
Old 01-15-2019, 10:44 AM #21
4Runner is in the shop today for the airbag recall so I had to drive my wife's new Pilot. The ventilation controls work exactly as you'd expect: turn on defrost (any speed), then you can add recirc or A/C, or both, your option. It does exactly what you expect it to do based on your inputs, not something different like preventing recirc on some settings, or shutting it off on it's own.
So while the giant touch screen interface on the Pilot is truly atrociously abysmal (certainly expect better for >$50k) Honda got the function tree right on the air controls while Toyota got it very wrong. And that bad decision isn't common across all manufacturers, or even the next largest Japanese manufacturer.
And not to beat a dead horse but shutting off unrelated functionality when there's a problem is just bad design. No justification (i.e. it doesn't happen very often) can change that fact. Having to carry a code reader and knowing how to use it is a kludgey workaround that most owners wouldn't be capable of.
Will either of these issues prevent me from buying another Toyota? Not individually, but a list of 15 taken together, maybe - and my list of annoyances with the 5th gen is at least that long now. Hopefully someone at Toyota reads these forums and takes constructive criticism seriously.
Oh, and the Pilot also still has a separate heater core for the rear seats, just like the 3rd gen 4runner did. Another thing us longtime 4runer owners used to have and now don't. Like I said, I hope someone at Toyota is listening.
Old 01-15-2019, 12:45 PM #22
keph13 keph13 is offline
keph13 is on a distinguished road
I was under the impression that you can't recirc on defrost because the defrost becomes the intake for the air. I could be wrong though.
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 01-15-2019, 03:23 PM #23
trulli3300's Avatar
trulli3300 trulli3300 is offline
trulli3300 is on a distinguished road
trulli3300's Avatar
My 2 cents...
I live in Michigan. All of the heating in all of my Toyota's have always been sufficient. If its slow to heat, you may be low on Anti-Freeze(coolant). Only use Toyota Brand coolant. It is bright pink and cannot be mixed with anything else. Their coolant is made for 100k miles of service before requiring a flush.
If you are in the cold climate and you recirculate the air using the heater, your windows will always be fogged up unless you turn on the defroster in which case the air conditioner compressor evaporates the humidity in the car....but you have your air cond working in the winter. In modern Toyotas, the defroster function automatically activates the AC compressor.
The ideal condition is to use fresh air from outside, flowing over your heater core to heat the inside of your vehicle.
[It is recommended that you turn on the air cond compressor once a month for 15 mins even in the winter to keep parts lubricated] In 16 years, my 3rd Gen never required AC work or a coolant recharge. NEVER. The last time we had a Toyota AC stop working was in my 1985 Celica Supra at 241K.
trulli3300 is offline   Reply With QuoteReply With Quote
Old 01-15-2019, 05:08 PM #24
Thrasher_S's Avatar
Thrasher_S Thrasher_S is offline
Thrasher_S will become famous soon enough
Thrasher_S's Avatar
So, recirc turned off when it's humid inside the car makes sense, but how about those of us who live in very humid climates like Oregon in the winter? The air in the car is humid, so is the air outside the car, especially when it's raining. My last rig, a Nissan Xterra, let me leave the recirc on all the time. I never turned it off and never had an issue with fogging windows.
2018 TRD Off Road Premium - Barcelona Red
Thrasher_S is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 09:00 AM #25
epjfsa epjfsa is offline
epjfsa will become famous soon enough epjfsa will become famous soon enough
I too live where the humidity is perpetually 95% and have never felt the need to use recirc to keep the windows clear during the winter on any of my cars. Defrost usually works well on its own, but it also helps to turn on A/C - especially when the engine isn't at operating temp.
I'm guessing that the primary goal is to raise the glass surface temperature above the dew point of the interior. Lowering the dew point of the interior (with A/C) is probably secondary and with breathing sweaty bodies in the vehicle fighting against this, recirc probably only helps speed up the first part - warming the surface of the glass before the engine is up to temp and can provide pretty limitless heat. This is probably why there's a timer.
For what it's worth, there's growing concern over CO2 levels of vehicle interiors and how it affects drivers (e.g. drowsiness). Premium vehicles are now coming with air quality monitors, but others could very well limit how much time recirc is on.
'16 TEP
'21 Model 3 LR
epjfsa is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 12:12 PM #26
57buick's Avatar
57buick 57buick is offline
57buick is just really nice 57buick is just really nice 57buick is just really nice 57buick is just really nice
57buick's Avatar
I read on another thread if you hold the recirc button down for 5 seconds it will stay on. I don't know if that was just for limiteds or not?
57buick is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 12:29 PM #27
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
But the larger point is that the freaking car should do what you tell it to and not try to apply a blanket rule to an unpredictably large problem set (>million owners at this point?). If I want recirc and defrost on at the same time there's a reason. If I set the controls to recirc and defrost, that's what it should do.
Totally agree and because my 4th gen allows both recirc and defrost I am perplexed as to why Toyota doesn't allow it on the 5th gen. I wonder if there is an option via Techstream to change it?
zonzin is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 07:50 PM #28
Classic95 Classic95 is offline
Real Name: Wes
Classic95 is on a distinguished road
Real Name: Wes
@nglayton Thanks for the tip... works like a charm on my 2011.
Classic95 is offline   Reply With QuoteReply With Quote
cold , heat , recirc , time , turn
A/C only works on recirc rfuree11 4th Gen T4Rs 3 08-12-2016 09:18 PM
Smart key ''accessory'' time limit. diverscale 5th gen T4Rs 17 03-04-2016 11:03 PM
recirc defaults to outside air cbreze 5th gen T4Rs 4 12-04-2013 10:23 PM
Spam & Time Limit b/w Posts Thai General Discussions 1 04-22-2009 02:28 PM
Recirc Air Button rockwall 4th Gen T4Rs 14 06-23-2008 11:04 AM
