Old 01-11-2019, 09:28 PM #1
ToolUser1 ToolUser1 is offline
ToolUser1 is on a distinguished road
Way to override recirc time limit?
So it's getting cold again in the NE. When it gets cold I turn the heat on ('11 Trail). The heat doesn't work very well, so I have to turn on recirc to get the temp up quicker. There are two maddening problems with this:
1) you can't use recirc and defrost at the same time???
2) recirc automatically shuts off after less than 3 minutes???
I purposely got the model with the least electronics in an attempt to avoid &$^% like this. When I tell my car to do something I just want it to freaking do it, not do something totally different.
I doubt there's a solution to this, so I guess this is just a rant. My apologies but venting did make me feel microscopically better...
ToolUser1 is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 09:36 PM #2
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Defrost with recirc doesnt work, you need dry air
Recirc shouldn't turn off after 3 minutes though
jhguth is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 10:48 PM #3
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Press and hold the recirc button until you hear it beep. Can't remember how long it takes, maybe 30 seconds? It will stay on until you turn off the ignition.
nglayton is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 09:35 AM #4
That's true sometimes, but not if it's -11. At that point the air is bone dry and running on recirc is super helpful. If the windows start fogging I can turn recirc off but up until that point it's helping me, and getting to that point when it's -11 takes way longer than 3 minutes.
But the larger point is that the freaking car should do what you tell it to and not try to apply a blanket rule to an unpredictably large problem set (>million owners at this point?). If I want recirc and defrost on at the same time there's a reason. If I set the controls to recirc and defrost, that's what it should do.
Old 01-12-2019, 09:39 AM #5
I tried pushing it twice, that didn't work. I tried holding it for 3-4 seconds, that didn't work. I'll try holding it longer and see what happens. If it works I'll owe you a virtual beer!
It's +11 right now and I have to go out in a couple hours. I'll give it a shot.
Thanks!!
Old 01-12-2019, 10:17 AM #6
JpAdct JpAdct is offline
JpAdct is on a distinguished road
I know it sounds backwards and wasteful, but I run heat with the AC on a lot during the winter. It allows me to keep it on recirculate and prevents fogging up. It also helps to keep the fumes out.
JpAdct is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 10:56 AM #7
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
So the vehicle should let you shift into 1st gear while doing 90 mph on the highway? Not going to happen. Let's pretend that Toyota did let the recirculation continue to run. The number of complaints they would get from customers saying their vehicles are prone to fogging up would be astronomical. Get used to the baby proofing of society.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 11:58 AM #8
kjbenner kjbenner is offline
Real Name: Kevin
kjbenner is on a distinguished road
Real Name: Kevin
You can't, but I think if you choose the position that's halfway between "feet only" and "feet/defrost" you can use recirc, and it'll still put some hot air on the windshield.
2015 Trail Edition w/ KDSS
TRD forged wheels, Cooper AT3 4S (P265/70R17)
kjbenner is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 12:01 PM #9
So lets go back to my sadly missed third gen, and every other pre-2005 toyota/lexus vehicle I've ever owned (>10 I think at this point) Most had a simple mechanical lever to switch between fresh air and recirculate + a selector button/knob for where you wanted the air to come out. In other words they were independent variables, allowing the maximum number of usage combinations. Even when it wasn't mechanical (i.e. Lexus SC300) the two controls were still independent rather than dependent. So you're telling me that prior to 200x Toyota was getting tens of thousands of complaints about recirc causing fogging?
And your 90mph shifting example is too specious to take seriously. The air system controls are simply a really poorly designed user interface that resulted in loss of useful functionality. Same as the 5th gen's cascading failure modes where the truck won't shift into 4wd if the computer is throwing a code from a loose gas cap (i.e. an evap system issue). Really, it's just stupid.
Shifting vehicle controls from mechanical to electronic is fine (cheaper to manufacture) but concurrent loss of functionality shouldn't be acceptable for us as consumers. Otherwise we'll just end up with crappier and crappier and crappier user experiences. And we're talking minor software changes here, so changes are effectively zero cost.
BTW I looked at a Tesla e-brake setup yesterday and it's totally electric - not a single cable involved - an electric servo motor directly actuates the brakes! It also acts as transmission lock, like the "P" in a automatic transmission. Interesting setup.
Old 01-12-2019, 12:10 PM #10
LeesO4's Avatar
LeesO4 LeesO4 is offline
LeesO4 is on a distinguished road
LeesO4's Avatar
My 2004 lets me keep the recirc on in any setting. I don’t like how the 5th gen won’t let me do the same. I also find it odd that it somehow turns itself off on its own. If I could leave it on forever I would, just like in my 2004. I want to keep the outside air and fumes out of my car.
2019 Blizzard Pearl 4Runner Nightshade Limited 4WD
TRD CAI-Weathertech Floorliner-Morimoto 2stroke 2.0 Lows-Tundra LED Fogs-Black Rhino Kunene 20X9-Falken Wildpeak AT3W 275/55/20-
2004 Silver 4Runner Sport Edition V8 4WD
Custom TRD Catback Exhaust-K&N FIPK-Silverstars-Rear Bumper LED Mod-DeBadged-Black powder coated rims-BFG AT KO2 265/70R17C-Charcoal Leather Interior-Weathertech Floorliners-Toyota Bug Guard-Wade InChannel Visors-Blacked Out Grille-AVIC-X9310BT
LeesO4 is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 12:53 PM #11
I'm not telling you that prior to 200x Toyota received tens of thousands of complaints. I'm telling you that they would receive those complaints today. Go down to the dealership or local rental car agency and take a look at the HVAC systems of the vehicles on the lot. You're going to find that they all behave similar to your 5th gen 4Runner. If Toyota didn't add this feature/bug, then everyone else that is used to having it automated would be ragging on it. Instead they only have you. Therefore they got it right. Now it might be nice if it was a dealer adjustable feature or carista type setting, but you lose.
Also, my 4-wheel drive still works even if there is an engine code. Now A-trac/crawl control/multi-terrain-select will not function, but I still have 4-wheel drive with low range (I'm not sure about the locker under this scenario). Another reason to carry an OBDII reader to reset the system if you are in a bind.
Old 01-12-2019, 12:56 PM #12
epjfsa epjfsa is offline
epjfsa will become famous soon enough epjfsa will become famous soon enough
It's not wasteful, in fact many vehicles automatically switch on AC (whether indicated or not) when in the defrost setting. Heck, our Mini switches AC on (at least indicated) if you just hit the "Auto" button on the HVAC controls.
FYI, the 4runner might have an auxiliary electric heater. Use it if you have it.
PSA for those in cold climates: Aux heater usage
'16 TEP
'21 Model 3 LR
epjfsa is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 04:04 PM #13
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Agreed. I think at least some of this is resulting from people becoming more and more accustomed to having their cars think for them. In response, and to reduce complaints, manufacturers automate some settings that receive the most complaints. For instance, I don’t believe most people understand that the A/C compressor is often needed to defog the windows. Cars just do it these days. I’m guessing it’s because leaving that in the operator’s hands produced significantly more complaints. I understand OP’s point - having more control is preferable when you know what you’re doing. But manufacturers have tons of data driving their decisions.
thennen is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 06:42 PM #14
That’s awesome! Thanks
Old 01-12-2019, 08:11 PM #15
Thanks!!
That worked! Hold the recirc button down long enough and it will stay on until you turn it off. Still doesn't work with defrost, and there's no beep so I'm not sure how long you need to hold it down, but I'll take it.
Thanks again!
cold , heat , recirc , time , turn
A/C only works on recirc rfuree11 4th Gen T4Rs 3 08-12-2016 09:18 PM
Smart key ''accessory'' time limit. diverscale 5th gen T4Rs 17 03-04-2016 11:03 PM
recirc defaults to outside air cbreze 5th gen T4Rs 4 12-04-2013 10:23 PM
Spam & Time Limit b/w Posts Thai General Discussions 1 04-22-2009 02:28 PM
Recirc Air Button rockwall 4th Gen T4Rs 14 06-23-2008 11:04 AM
