Old 07-31-2019, 10:38 PM #1
andrew4r andrew4r is offline
Real Name: Andrew
andrew4r will become famous soon enough andrew4r will become famous soon enough
Real Name: Andrew
Help me secure my roof cargo
I recently installed an SSO rack and ordered some 95L ROAM rugged cases for roof storage.
I'd like to secure the cases to the rack such that I can open the cases and access their contents without having to remove straps.
As you'll see from the pictures below, I have a ratchet strap looping through the handle, across the inside of the lid, and through the other handle. This does secure the box to the roof. However, the box has quite a bit of lateral play. I'm not real high on driving on the highway with the boxes moving side to side.
The cases do have additional slots along the front to loop straps through. I can use some tie downs to further secure, though they will really only prevent lateral movement in 1 direction.
Thoughts? Ideas?
I am open to drilling holes in the bottom of the cases and bolting them to the crossbars. However, I'd want some mechanism for quick releasing them from the inside.
@andyadventuring @samadventuring
'18 TRD Off-Road
andrew4r is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 10:48 PM #2
whiplashtx whiplashtx is offline
whiplashtx is on a distinguished road
We use turnbuckles to secure coolers in our jeeps. The coolers have similar attachment points, either use a short piece of strap or fabricate a metal L bracket. I have never seen a cooler come loose secured in this fashion even in a rollover.
whiplashtx is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 11:09 PM #3
Real Name: Andrew
Real Name: Andrew
Thanks for your reply. If it's not inconvenient, would you mind sending me a photo?
'18 TRD Off-Road
Old 07-31-2019, 11:11 PM #4
Real Name: Andrew
Real Name: Andrew
For a quick, easy potential solution, I'm thinking of running the ratchet strap through the side handle, underneath the crossbars, and up through the other handle. This probably won't limit horizontal play, but it will get the strap out of the way when I have the case open.
Each end has an additional 2 slots for straps, so I may use some tie down straps in the front (the front has the most play because of how far the ratchet strap has to extend out in front for room to ratchet).
'18 TRD Off-Road
Old 07-31-2019, 11:36 PM #5
Not my pic but here's what I am talking about.
Old 08-19-2020, 03:59 PM #6
JsinLegacy's Avatar
JsinLegacy JsinLegacy is offline
JsinLegacy will become famous soon enough
JsinLegacy's Avatar
I know this thread is old but wondering if you found your solution for this? I am about to order one of these cases and am looking for a way to secure it to the frontrunner roof rack without the use of straps.
Thanks.
JsinLegacy is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 09:15 PM #7
PK930's Avatar
PK930 PK930 is offline
PK930 will become famous soon enough
PK930's Avatar
Thanks.
Use some T-bolts that fit into the rack slots and drill holes in the bottom of the cases. Use wing nuts if you don't wanna mess with tools.
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 01:42 PM #8
JaevonAdventures JaevonAdventures is offline
JaevonAdventures is on a distinguished road
Looking into getting the 95L cases for our 2012 4Runner. We have a prinsu rack similar to the rack by the OP, just curious about the wind drag from having the cargo boxes on the roof rack.
JaevonAdventures is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 05:54 PM #9
whitemallcrawler's Avatar
whitemallcrawler whitemallcrawler is offline
Real Name: T
whitemallcrawler is on a distinguished road
Real Name: T
Thanks.
I know it's been months and you might have bought and installed it already but this is how I mounted two on my prinsu rack...6 holes, 1 1/2 inch carriage bolts that fit into the Prinsu crossbars, flextape(as of right now it's rain and snow proof) because I didn't want to use silicone, washer, wing nut. I have to take it off occasionally to put a ski box up there so I chose wing nut. It's gone through moderate trails and decently heavy snow and rain without any leaks or problems. Sorry for shitty photos
Help me secure my roof cargo-roam1-jpg  Help me secure my roof cargo-roam2-jpg
98% paved roads, 2% off road. #SR5Matters
whitemallcrawler is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 07:42 PM #10
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Use metal chocks to hold the box in place laterally, then loop straps at your arrows to hold the box down to the roof
i know frontrunner has chocks, but you could fab something pretty easily
jhguth is offline   Reply With QuoteReply With Quote
cases , inside , open , roof , secure
Best way to secure wires to roof rack? TerraCrawler 5th gen T4Rs 4 02-18-2019 05:28 PM
Secure awning to stock roof rack JeratBP 4th Gen T4Rs 7 11-19-2018 10:14 PM
How to secure roof lights MadeInMaine 5th gen T4Rs 3 08-09-2016 08:24 AM
How to Secure Cargo Offroad Marcocopuffs General Discussions 10 12-02-2014 08:51 PM
noise from roof rack cargo tray or cargo box Franzmann 5th gen T4Rs 2 02-20-2014 08:46 AM
