Originally Posted by Hadelson
Started in November when temps starting going below 30F. It's a model year 2017 TRDP manufactured Dec 2016. It appears to be coming from right rear side. I get it when the Right Rear suspension is unloaded on right hand turns and the right rear tire hits a dip or when the entire back lurches up and then down. I've been under the car 3x's and all clearances look good; no rub marks or anything loose. This is stock suspension with 1" Toytec front spacer removing most of the rake.
Any ideas or suggestions?
Not sure what you are aware of but I'll keep it simple as my my guesses. If upgraded suspension look up the half moon mod that had to be done with TRD PRO folks in regards to the Bilstein hitting a bit of metal when under load. Also, check out if your spare tire is secured properly. Thats all I got for now. Good luck
