Old 12-28-2019, 03:49 PM #61
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
2019 Trd Pro Roof Rack Availability
Originally Posted by scotttyB View Post
I'm new to the forum and considering purchasing my 1st 4Runner soon. Here is my first question.
Does the 2019/2020 TRD Pro Roof Rack fit on a 2019/2020 SR5 or TRD Off-Road model, lining up with the same bolt holes (no drilling required)?
It’s plug and play for all 5th gen. Just make sure you get the right install hardware to prevent leaks. I posted the hardware in this thread Incase sellers don’t include the hardware. But even if they did, the washers are one time use. So you’ll need those at bare minimum.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 03:50 PM #62
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
It should fit. I just removed my Pro rack and put on the black rails and there the same holes. Just different bolts are used for the rails than the Pro rack.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 05:37 PM #63
gSwift's Avatar
gSwift gSwift is offline
gSwift has a spectacular aura about gSwift has a spectacular aura about gSwift has a spectacular aura about
gSwift's Avatar
Originally Posted by daytonaviolet View Post
It’s plug and play for all 5th gen. Just make you you get the right install hardware to prevent leaks. I posted the hardware in this thread Incase sellers don’t include the hardware. But even if they did, the washers are one time use. So you’ll need those at bare minimum.
I just looked at all your posts in this thread and didn't see the hardware you're referring to.
I'm taking the rack off my 2020 and giving it to my sister for her 2016 and need to know what hardware I need in order to re-mount it to hers.
gSwift is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 05:48 PM #64
Real Name: Don
Real Name: Don
Hey Gswift,
I just took mine off. The bolts to your Pro roof rack are the ones for her 16 4runner if she is putting your Pro rack on.Also look at the Pro rack deleted next page by diah0. He has a good detail posted how to remove your Pro rack. Just take your time and don’t rush.
Old 12-28-2019, 07:11 PM #65
gSwift's Avatar
gSwift's Avatar
Originally Posted by RusPro17 View Post
Hey Gswift,
Yeah i've been keeping an eye on that thread. Just wasn't sure if the "nuts" on the inside of her 16' were the same size to accept the bolts from my 20'
Old 12-28-2019, 08:10 PM #66
Here is the kit. I believe you have all the parts already except the two sets of washers. When you take them off your 20, the washers may fall apart and it’s better to replace with new ones.
One is foam material and other is a hard card board. I believe this will make the install water proof.
Genuine Toyota Accessories PT278-35070-HW Roof Rack Hardware Kit https://www.amazon.com/dp/B00DPIF08Q..._54-bEbJ8R464F
Old 12-28-2019, 09:06 PM #67
gSwift's Avatar
gSwift's Avatar
I may have to go check with the dealer. I googled that part number and every website shows that its "no longer available" Thanks for the heads up though
Old 12-28-2019, 11:21 PM #68
gSwift's Avatar
gSwift's Avatar
Originally Posted by ForRun View Post
Thank ya sir! I'm not sure why I couldn't find that
Old 12-28-2019, 11:57 PM #69
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Opps, I deleted the post because after I looked at it said it was for an FJ. Ran a check and said not compatible with 4runner
ForRun is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 11:59 PM #70
gSwift's Avatar
gSwift's Avatar
Ah damn! Okay thats cool, i'll just check with my dealer. It'll still be a couple more weeks before the SSO rack gets here
Old 12-29-2019, 11:08 PM #71
Actually the kit i posted is for the fj. Not sure if there’s a kit specific for the 4runner as of yet. But when I compared the bolts and the washers, they looked exactly the same. Only thing with the fj kit is you’ll have extra parts.
When I purchase my rack you can see the original two washers (foam and cardboard) still stuck on some of the rack holes. But some were missing so i scraped them off and applied the new ones.
Old 01-02-2020, 01:20 AM #72
jsauce8921 jsauce8921 is offline
jsauce8921 is on a distinguished road
Originally Posted by Mandrick View Post
Yes, it does. I replaced it with the stock rails off a 2018.
Did you use the bolts that were in the truck it does the rack need special bolts for depth?
jsauce8921 is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 01:39 AM #73
I just finished this thread and found the info. Thanks though!
Old 01-03-2020, 04:50 PM #74
Picked up my kit today!
Old 01-04-2020, 01:13 AM #75
wasaland wasaland is offline
wasaland is on a distinguished road
anyone selling a trd pro rack in the bay area? please let me know
wasaland is offline   Reply With QuoteReply With Quote
availability , happen , purchase , trd , ugly
2019 TRD Pro Roof Rack JimJr15 5th gen T4Rs 70 04-06-2021 11:16 AM
WTB 2019 Trd Pro Roof Rack edgesalon Want to Buy/Trade 20 03-08-2019 01:38 PM
WTB: 2019 TRD PRO Roof Rack doyoueventraps Want to Buy/Trade 0 01-11-2019 10:29 AM
WTB 2019 Trd Pro Roof Rack edgesalon So Cal 0 12-12-2018 02:17 PM
WTB: New 2019 TRD Pro roof rack Bodhi327 For Sale: T4R Items 0 11-11-2018 07:56 PM
