01-16-2019, 12:40 AM
#31
Originally Posted by Jetboy
Bottle jack works just fine in a number of places. It makes no difference whether you're stock or lifted. (not counting long travel here). The suspension doesn't change when you put a 3" lift on. You have to lift it the same height off the ground as a stock one.
Also RTFM... Toyota 4Runner: If you have a flat tire - Steps to take in an emergency - Owners Manual
Also - I would remove the A-arm skids because they're pointless. But not for changing a tire.
But i'm the ******* for saying a arm skids are pointless
01-16-2019, 01:09 AM
#32
Originally Posted by MAST4R
I can totally see how the crowd made the situation worse due to actual or perceived pressure to act fast.
A few comments:
--What pressures were you running for that to happen? What rating do your tires have? If you are running P or LT-C you should not have to air down as a standard procedure. Too much pressure can get you a tread puncture by a sharp rock, but what you experienced is far more likely. Plus, it is debatable if lower pressures add traction in snow. If you have E-rated tires, then, yes, traction at street pressures won't be great.
--I understand that some enjoy clubs, etc, but I am not personally a fan of big groups of any kind. Having different types of vehicles in the group makes things even worse.
--One of the advantages of the air jack over the HiLift is that it can be easily used on uneven ground. I have a Chinese version off Ebay that I have only used in testing but I re-tested it recently and it still works. It has been wasting space on trail for years, but you never know.... That said, the rig can easily move after the air jack lifts it off the ground, so I would not call it a safe solution. Just different, a lighter tool that is easier to store.
--If we are to critique the skid plate package, the unprotected rear LCA brackets are #1 issue to address for any ledges, followed by the stock rear LCAs themselves, then the aluminum package, then the weak design of the front lip of the RCI tank skid. I don't want A-arm skids, but once there.... Also, after a lift the rear differential is quite exposed. Won't be damaged easily as a whole but the drain plug can.
Take or throw any of the above comments/suggestions at will, just my opinion based on what I do. I am not saying I know better what is good for you.
Overall, my best guess is that the entire situation was caused by unnecessarily low tire pressures. Or you really messed up on that spot, which is okay, we all have those moments!
I was running about 15 psi on snow/ice. Have C-rated ridge grapplers (285/70/r17). Felt a lot of pressure from the group where everyone was airing down, though another 4nr didn't and did fine, though he did use chains on a certain section.
And...yeah, I think more than anything it was caused by driver error. I probably should have tried to slow down more on that section but it was icy.I went out to get experience and....got some!
I do have rear LCA bracket skids...I wasn't aware of a problem with the front lip of the RCI fuel tank skid. Is there a mod or fix for that?
2018 ORP, SSO slimline, smitty x2o 10k, RCI full skid package, RSG sliders, FJ TRD Pro Bilsteins, King SPR3-14-650, Dobinson C59-505, 285/70/r17 Ridge Grapplers, SCS Gunmetal Ray 10, Marker Lights, Hood Wrap, tint.
01-16-2019, 01:31 AM
#33
Well, I will say the 15 psi is your culprit, not you. I don't air down for the heck of it on my P-metric Wildpeaks. The issue is more in the Sonoran desert because we have so many sharp nasty rocks, even when small. They are not as "nice" as the Sedona or Utah slickrock. Air down for soft or deep sand and volcanic ash and such. Do you have volcanic ash drives in Idaho? Around Craters of the Moon?
On P or LT-C, I would not do under 28 in most areas. In AZ or SoCal deserts, it depends. Deep sand, of course.
With D or E load is different. You have to air down both to keep your fillings and to ensure traction. The D/E loads have very stiff sidewalls, less footprint on vehicles too light for them, and hence less traction at equivalent pressures.
No, you have the skid you have and you have a lift to boot so I would not lose any sleep over it. The reason I did not get the RCI gas tank skid and endured instead the painful install of the Shrock one is that front lip: it is where you hit that skid plate the most. So an unsupported protruding lip will cave in after one impact. The Shrock and C4 designs are far stronger.
But again, be alone the judge, don't let forums and groups make decisions for you; just use us as data points. My goal is to drive all I care to drive at stock height. So the best armor is essential for me.
EDIT: presumably lots of people in your group had MT tires. So that's another difference from yours. MT tires are E-rated though I have never had or intend to have any unless I get a dedicated trail rig. So I won't comment about MTs.
01-16-2019, 01:58 AM
#34
Banned
Banned
No, you were the one who blamed marketing for buying worthless gear, then got called out for modifying your rig with every bro pro mod available.
01-16-2019, 02:18 AM
#35
They're actually worse than pointless. They make the LCA worse by tapping mud, creating unnecessary galvanic corrosion, adding weight and have no benefit. And apparently they also make it harder to use the jack
My beef is with the sellers. Not everyone is an experienced fabricator or offroader. They're relying on the "expert". But no one in the history of 5th gens has ever damaged an LCA in a way that a skid like that could help. Ever. Not once. And it never will happen. People who buy them do so because they don't know the difference and rely on sellers pushing a phony product. That's not cool.
01-16-2019, 02:42 AM
#36
If I'm putting the jack in the center of the engine skid and lifting the entire front...that sounds more dangerous than just trying to lift one side? It seems like its much more likely to possibly fall to a side.
I generally lift one side for safety also. But it's not bad to go right in the middle. In my shop I just put the jack under the center with the floor jack. Mostly because it's fast and easy. In the field go for the most stable option you can. Also use the spare as a safety in case it falls. It'll also make it easier to get a jack under again if it falls and lands on the spare vs the ground. Finally once it's up in the air. Give it a good shake. See if you can push or shake the vehicle off the jack. Make sure it's stable before you start taking lugnuts off.
It's easy to feel rushed with a group. They should recognize you're new and help you sort it out so you have more experience. I would not use a high lift to change a tire unless it was all I had. They're not very stable. But they are handy and fast.
Also one other tip. To reseat a bead without a big compressor, wrap a tie down strap around the tread pin the tire and as you tighten it down it'll push the beads out to the wheel so you can refill and reseat them. But take it off as soon as it starts to fill up. Otherwise it will break the strap.
01-16-2019, 03:55 AM
#37
Banned
Banned
Lighten up Francis or switch to decaf....we’re talking about $100 bucks in sheet metal.
01-16-2019, 05:09 AM
#38
I wanted to add, if you manage to destroy an A-arm, you probably destroyed everything else connected to it.
I'm going to admit, I bought mine cuz it looked cool....lol.
01-16-2019, 10:06 AM
#39
This is sage advice, OP.
01-16-2019, 10:58 AM
#40
Except the typos. "tread pin" = "tread of"
It usually does work pretty well.
01-16-2019, 11:12 AM
#41
I hear you, I’m cursed by autocorrect.
I like that method a lot better than starter fluid. It’s fun, but only if no one looses an eye!
01-16-2019, 11:28 AM
#42
I use the skid plates for two things: protection of the parts and protection of the appearance if I ever want to sell the rig. I did manage a scratch in the front stock plate and a small dent in the gas tank stock plate before the stronger skids arrived, but they are all stored and look pretty nice enough should I ever sell.
But what will happen to the A-arm itself more than rock rash? And that is rare enough. I sprayed it over. I agree that if you destroy the metal itself, you will also destroy a bunch of other things, so even if the A-arm skid protects the appearance of the arm here in dry climates, it won't make a functional difference. Plus, as always, by losing some clearance, you get more contact. The A-arms are 600 total so spending 150 to protect the paint of 600 worth of easy-to-replace parts is a lot. Black paint is my answer.
I don't feel like blaming the aftermarket for this. So long as the product is a quality one, it is up to the consumer to make up their mind. If the part itself is junk or is solid per se but causes issues with other parts, that's different.
As for buying for looks, it is a personal preference, helps the aftermarket thrive, and it makes the prices better for all of us.
01-16-2019, 11:34 AM
#43
I don't carry starter fluid or brake cleaner in my tool kit. I can't really think of any reason I'd carry it. WD40 doesn't really work... so the propellant method isn't usually an option for me whether I'd want to do it or not.
01-16-2019, 11:52 AM
#44
For me it's just hard to understand why would someone would want to put a weak aluminum skid plate over a strong steel part. Toyota spent a lot of time/money engineering a lower control arm that is both strong and light. Every pound shed from those arms cost a million+ dollars of engineering and tooling. Then pay money to add more weight without any utility. That just doesn't make sense.
If you want them to look pretty - that's cool. As long as you recognize they're not functional. My problem with the aftermarket is that they're misleading people who don't know the difference into thinking that they need to have a skid there. The people who know wouldn't buy them. It's like putting some thornbirds on.
01-16-2019, 11:57 AM
#45
Are you using "if you want" in place of "if one wants?" Because I have no A-arm skids. I also argued that they make no functional sense. The difference from your post is that I don't want to judge people for their tastes. If one wants A-arms because they look "cool" that's fine with me. I can as well live with a tiny little bit of what the aftermarket has to offer but a bigger market helps me, too.
