01-14-2019, 02:06 PM
Popped a Bead. Couldn't change tire because of A-arm Skid.
So, last week on a snow run with a 4x4 group, I popped a bead when sliding into a rut.
I have a full size spare so no problem (and didn't want to do the brake fluid method of reseating a bead). However....using my bottle jack I quickly realized that my A-arm skid plates are now covering the normal jack point for the front driver.
Excuse the bad picture/dirt ->
Luckily, someone in the group had a hi-lift jack so we just jacked up the truck using my rock sliders.
However....can someone recommend a different jack point when lifting the front or would I really need to remove the skid plate to do it?
2018 ORP, SSO slimline, smitty x2o 10k, RCI full skid package, RSG sliders, FJ TRD Pro Bilsteins, King SPR3-14-650, Dobinson C59-505, 285/70/r17 Ridge Grapplers, SCS Gunmetal Ray 10, Marker Lights, Hood Wrap, tint.
01-14-2019, 02:13 PM
I've used a floor jack and 2x4 to jack mine directly on the A-arm slider a few times recently to rotate my tires and install/torque my wheel spacers. No issues.
01-14-2019, 02:16 PM
Are you using the 2x4 on the bottom (near the wheel) or top of the skid?
01-14-2019, 02:17 PM
Near the wheel.
01-14-2019, 02:19 PM
But I guess I'm also putting my slider up on a floor-jack too, now that I think of it. In your situation I would probably just go for it though, personally.
01-14-2019, 02:28 PM
Banned
Banned
Why not use a jack pad, floor jack and your sliders?
01-14-2019, 02:31 PM
Well, currently I don't have a floor jack, but you mean...bring a floor jack in the trunk when going out on the trail every time?
01-14-2019, 02:38 PM
Real Name: KE0OIC
Real Name: KE0OIC
I'd just jack right on that skid plate. If it can't handle a jack, how's it going to handle getting bashed against a rock? Don't know anything about that one but likely it doesn't have a lot of clearance to the arm It should just flex a bit and make contact.
People do bring floor jacks on the trail, but you can also get heavy duty long-extension bottle jacks. Or a Hi-Lift obviously.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
01-14-2019, 02:42 PM
Banned
Banned
How exactly do you plan on changing out your tire without a jack? You could use the ARB tire repair kit, but then you would need air.
01-14-2019, 02:48 PM
Thanks. Yeah, I'll probably just go the 2x4 route and use my bottle jack and jack directly under the a-arm skid.
01-14-2019, 02:53 PM
Banned
Banned
I don’t trust my oem bottle jack at all....has anyone used it to change out a tire on a lifted rig?
01-14-2019, 03:29 PM
surprisingly, it's not a bottle jack, it's just shaped line one. You should try it before you need it. It raises much higher than you might expect - 19". There are 2 tiers inside
here's a thread that shows the jack extended. The top pad will also screw out to extend even further
https://www.toyota-4runner.org/2714513-post45.html
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
01-14-2019, 03:35 PM
Jack off of the frame. Usually also a good idea to carry a block of wood for situation like this.
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
01-14-2019, 04:12 PM
Banned
Banned
I’m not worried about the height...but the instability. Especially off road on uneven surfaces.
01-15-2019, 12:34 PM
Real Name: Jonathan
Real Name: Jonathan
Bring a few pieces of wood then. 2x10 or 2x12 and you're fine.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
