12-20-2018, 08:33 PM
5th Gen Fuel Tank Capacity Q answered
Ok, I ran the test:
1. I drove the tank on my 2016 TRDP to empty; (I know I know)
2. I poured in 1 gallon of fuel;
3. I drove 1.3 miles to the nearest fuel station; &
4. I filled the tank until fuel poured out the top & the pump read 24.003 gallons
Conclusion: A 2016 T4R holds almost precisely 25 gallons.
Have a nice day...
12-20-2018, 09:08 PM
Rip to your evap system for filling the tank until gas spilled out
12-20-2018, 09:12 PM
Yeah, it holds 23 gallons correctly. It will ready empty (or 0 miles to go) at 3 gallons remaining.
12-20-2018, 09:15 PM
the info on the toyota 4runner Specs says 23 galon
Fuel Tank Capacity 23.0 gal.
18 FunRunner
12-20-2018, 09:55 PM
Originally Posted by Owner’s Manual
It’s almost like you didn’t bother to read me...
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
12-20-2018, 11:38 PM
My 2014 seems to only take like 20 gallons when I fill up at dang near empty (miles left being under 5).
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
12-20-2018, 11:44 PM
Real Name: Charles
Real Name: Charles
The latest wave of intelligence to grace this forum
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
12-21-2018, 01:20 AM
Originally Posted by BlackCloud
Ok, I ran the test:
Have a nice day...
thanks, good to know
12-21-2018, 09:05 AM
Real Name: Jeremy
Real Name: Jeremy
why would you fill your tank until it poured out the top???
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
12-21-2018, 09:35 AM
Correction:
Fuel tank + fuel filler hose + evap (RIP) capacity = 25 gallons
12-21-2018, 09:46 AM
Does anybody know how the fuel capacity is reported through the ECU/OBDII port by the sending unit? The reason I'm asking is that I got a Maestro RR connected to the OBD port and you have to specify a tank capacity before it starts showing how full the tank is. Comparing it to the cluster gauge the values are a bit different when the tank is set to 23 gal.
12-21-2018, 10:26 AM
For oil, the 5th Gen owners manual states:
Oil capacity
(Drain and refill reference*)
With filter
6.6 qt. (6.2 L, 5.5 Imp. qt.)
Without filter
6.0 qt. (5.7 L, 5.0 Imp. qt.)
But...is this really the case? To verify, I'm going to drain the engine oil(remove oil pan drain plug). Once it has drained, I will drive approx. 4-5 miles with the drain plug removed in order to clear out all residual oil from the system.
After doing this, I will install exactly 6.6 qts. of new oil - that's 6 qts. and 19.2 oz. of oil and a new oil filter 04152-YZZA5
I will then start the vehicle to circulate the oil through the system, filling the new oil filter. The engine will then be shutoff and left to sit for several hours. Following this, I will remove the dipstick to check oil level. The oil level should be on the full mark - exactly. If not I will contact Toyota Customer Service and suggest they modify the "with filter" qty.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
12-21-2018, 11:03 AM
Real Name: Kevin
Real Name: Kevin
If you really want to make sure it's cleared out, you need to run a garden hose into crankcase for about a half hour with the drain plug open.
2015 Trail Edition w/ KDSS
TRD forged wheels, Cooper AT3 4S (P265/70R17)
12-21-2018, 12:54 PM
That only helps if the water is coming straight out of the hot water heater.
12-21-2018, 01:16 PM
If you're referring to the "Cruising Range" indicator, they left a lot of cushion on it. I believe when that hits 0, you still should have about 3 gallons of gas left.
Based on my fill up experiences (to the first click on a pump only), the light comes on around 4 gallons left (19 fill up) and the read out hits 0 with around 3 gallons left (20 fill up).
I assume this is because there's a bunch of people out there who refuses to fill up until the last second and will drive it until they're out of gas if it actually ran out at 0.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
