Old 01-16-2019, 01:02 AM #1
Tejas Tejas is offline
Tejas is a jewel in the rough Tejas is a jewel in the rough Tejas is a jewel in the rough
sPod HD or Switch Pros 9100
I am in need of a switch system for my lights and I find myself torn between these two. I see a lot of people swear by the sPod but I'll be honest when I say that I like the user interface/tactile feel of the Switch Pros. Maybe it's just that I am in love with the SDHQ dash mount for the 9100 but I feel myself leaning towards it simply because of how it mounts versus how it works.
So what do you guys think? Why did you go with one over the other and which do you think is the better of the two?
Tejas is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 02:09 AM #2
atchcraft's Avatar
atchcraft atchcraft is offline
atchcraft will become famous soon enough atchcraft will become famous soon enough
atchcraft's Avatar
I went with the SwitchPros SP9100 after a lot of reading up. No regrets here and I love the switch panel. I have mine sitting in the same spot as the SDHQ panel, but it’s just glued there.
atchcraft is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 08:55 AM #3
bigguy02's Avatar
bigguy02 bigguy02 is offline
bigguy02 is on a distinguished road
bigguy02's Avatar
I hope to be buying a a Switch Pro soon. Im about 99% sure thats the route ill go. Manly due to the S-pod being an open box under the hood. Seems like alot of dust and stuff will get in there.
bigguy02 is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 10:09 AM #4
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
There are advantages and disadvantages to both I think and there are a ton of reviews out there for both. I recently ran through this and chose an Spod
I have the Spod Bantam with the HD control pad (Non touch screen version)
It works great for me, easy to wire to and provides good protection for the electrical system. I like that the Spod is fully closed, the Switch Pros is kind of exposed for my tastes. (Under hood)
The Switch Pros control pad is slightly smaller and will fit in the location just above the mirror controls and below the AC vent in the 5th gen. The Spod HD pad will not fit here. The Switch Pros pad is also thinner. I think for control pad placement this is a distinct benefit of the Switch Pros.
The Spod all 8 circuits are 30 Amp where the Switch Pros is 4 x 35 Amp and 4 x 18 Amp. This probably wouldn't matter unless you have a bunch of high draw items.
With the Spod you can link 4 of the under hood units and control them all from one pad via the Bluetooth app.
With Switch Pros you would need multiple control pads to achieve the same thing. Again this is probably not an issue unless you have a bunch of accessories
I know the Spod is not setup to act as a three way switch. Not sure about Switch Pros. You could add an additional physical switch for this if it was important. (I abandoned that in my setup)
I love the ability to dim all the lights and strobe or flash. Both systems do this and it's really useful.
I think either is a good choice. A friend ran me through his Switch Pros setup just last week and functionally they are really similar.
I may be incorrect in some of these items so don't necessarily use my post as gospel.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 10:57 AM #5
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
The sPOD is an open box under the hood??? Mine actually has a sealed cover that latches over the top covering all of the connections! Switch pros is the one that is totally exposed (under the hood). That's the reason i went sPOD. I'm just throwing that out there since you stated that the sPOD being exposed is the main reason you are going with switch pro. Maybe you got these 2 mixed up?
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 11:08 AM #6
bigguy02's Avatar
bigguy02's Avatar
No, not mixed up. There is a latching cover, but on the bottom, there are large holes that allow the wires to enter the box. From my research there is no gasket or cover for these holes, or am I wrong?
The SwitchPro, all the sensitive internal stuff is, well internal. the wires are on the out side, but they are shielded.
Old 01-16-2019, 11:30 AM #7
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
I am leaning towards SwitchPro 9100. I honestly think you can't go wrong with either...
blksubykid is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 11:44 AM #8
Within those open "oval cut outs" it has rubber gaskets with a slit through it where just your wires pass through and it will keep debris out. Both systems definitely have their advantages and disadvantages. I've used both and they are both super nice products that make life a lot easier without a nest of wires running all through your T4R. Can't go wrong whichever you choose!
Old 01-16-2019, 12:03 PM #9
GreyBear GreyBear is offline
GreyBear is on a distinguished road
I don't know if they fixed it, but I noted a year ago SPod had a table on the back of their brochure that was supposed to help you but got the simple formula Watts = Volts * Amps wrong.
Running numbers for your setup is a good thing any way you decide to go.
__________________________________________________ __
2017 T4R Off Road Premium, KO2 tires, Bilstein shocks, OME springs, SPC UCA, Front Runner 3/4ths rack, RSG rock sliders, C4 Fab aux battery tray, Eaton 31S relay/fuse box, Blue Sea ACR, Molex ML-XT connectors, Air-On-Board push switches, Rago ditch light brackets, VisionX pod and scene lights, Rago rear window molle panels, rear diff+locker breather relocation, C4 Summit hatch ladder, custom flip up license plate holder, Dometic fridge DIY box, DIY drawer bank, DIY power panel with solar controller.
GreyBear is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 01:56 PM #10
srsrogerissrs's Avatar
srsrogerissrs srsrogerissrs is offline
srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice
I have the SP 9100 and it works great for my needs. My only complaint is that the bluetooth app is pretty finicky on my Pixel 2 but it works a lot better on my samsung s8. Probably not a problem with my switchpro but with my phone. For the most part you can't go wrong with either. The fact that they both allow you to program the switches, dim, strobe, etc, just make them that much more convenient to use over standard switches.
2016 White TEP
srsrogerissrs is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 07:35 PM #11
57buick's Avatar
57buick 57buick is offline
57buick is just really nice 57buick is just really nice 57buick is just really nice 57buick is just really nice
57buick's Avatar
I went with the switch pros 9100 and the SDHQ panel mount.
I like that its small and sleek to look almost factory on the dash.
And I like that i can easily customize the buttons on the phone app, for example I have 2 buttons that automatically turn on with the ignition, I don't remember if the SPOD does those kinds of things without actually wiring it that way?
Also the comment about daisy chaining? The description for the Switch Pros says " Daisy Chain up to 3 Switch Panels to One Power Module"
57buick is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 08:11 PM #12
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Sorry to jack the thread. (Not really)
But how do you wire accessories to the switch pro? I'm looking at the installation sheet and it looks like you need to add pins to the 16-pin?
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 08:17 PM #13
57buick's Avatar
57buick's Avatar
This is the switch pro terminals, you just hook your wires to whichever 1 thru 8 connector you want that accessory on.
Excuse my mess in pic, rerouting some stuff.
Its the terminal strip with the different colored wires going to it. I also have an added ground strip to hook all my grounds too and a separate fuse box to left I added for stuff that is always connected to the battery(not included with switch pro)
sPod HD or Switch Pros 9100-wiring-jpg
Old 01-16-2019, 08:47 PM #14
I'm assuming there is a cover?
2018 TRD OFF ROAD
My Build
Old 01-16-2019, 08:53 PM #15
57buick's Avatar
57buick's Avatar
You can buy one with a cover, the switchpro does not come with a terminal strip just the colored wires, You can buy different terminal strips on Amazon for $5 some with covers some without
feel , mounts , pros , spod , switch
SPOD vs Switch-Pro calimero 5th gen T4Rs 15 10-19-2019 09:50 AM
AOB switch to Spod diodes needed? Moto69Joe 5th gen T4Rs 14 08-17-2018 11:09 AM
FS: IL, Switch Pro 9100 Switching set up, $395 BNIB Shipped chitown4x4 For Sale: T4R Items 2 08-09-2018 02:34 PM
FS,BNIB: Switch-Pros 8100 Switch Panel PAKM4N For Sale: T4R Items 2 12-28-2016 05:14 PM
Anyone using a switch pros switch panel? mavrick1903 4th Gen T4Rs 0 04-11-2016 11:14 PM
