Old 08-15-2019, 01:57 PM #16
t4rcement t4rcement is offline
t4rcement is on a distinguished road
Originally Posted by bigair96 View Post
It looks like your wiring connector is right next to your hatch hinge? Did you use a supplied wiring harness or just wire yourself?
Did you bring the wiring into the cab? Then did you route along the floor to get to the dash switch then to the engine bay?
I'd like to get a single 6 inch amber chase light and trying to figure out best way to wire it. Extreme LED has a nice 6 inch option and they have a nice wiring harness. I've already brought in my solar panel wire through the rear hatch grommet. Just trying to figure out my options here....
Thanks
Yeah, the connectors are right next to the hatch hinges. There’s plenty of room between the hatch and the body, so there’s no worry of the connectors being damaged when opening and closing the hatch. I believe I also zip tied the connectors to the hinge brackets so they don’t shift around. No issues since initial installation. I modified the supplied wiring harness and i bought more wire because it wasn’t long enough. I routed the wires down the weatherstrip and to the floor all the way up front through the firewall and into the sPOD. The sPOD made it easy because a wire went into the positive and a wire went into the ground. When I wired the wires through the cabin, the wires went underneath the sliding cargo tray panels and the plastic door sills. I thought that was the easiest method of routing the wires.
Hope that answers your questions.
t4rcement is offline   Reply With QuoteReply With Quote
Old 08-15-2019, 06:58 PM #17
boyguan boyguan is offline
boyguan is on a distinguished road
i ran mine into the hatch and then out the tail light at the bottom and them up, no water leaks as it under the tail light
another option is to pull the seal strip out and cut a notch in the metal and run it in
boyguan is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 04:15 PM #18
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Originally Posted by 4RunningAK View Post
From the engine compartment, then wedged between the windshield and A pillar, then under the plastic cover in the rain gutter, then along the rack rail to the light.
Hey @4RunningAK ... what gauge wire did you use that you managed to fit underneath the gutter piece ... can you send a pic?
rageandlove is offline   Reply With QuoteReply With Quote
Old 11-29-2021, 04:53 PM #19
4RunningAK 4RunningAK is offline
4RunningAK is on a distinguished road
[QUOTE=rageandlove;3691957]Hey @4RunningAK ... what gauge wire did you use that you managed to fit underneath the gutter piece ... can you send a pic?[/QUOTE @rageandlove sorry, I don't recall the gauge, and have since removed it so can't provide pics.
Sent from my SM-N960U using Tapatalk
4RunningAK is offline   Reply With QuoteReply With Quote
area , hatch , light , rear , wiring
Help getting wiring from the rear roof rack to the battery. depth 4th Gen T4Rs 2 11-02-2017 05:10 PM
Rear roof light wiring help... MadeInMaine 5th gen T4Rs 3 01-05-2017 09:56 PM
Roof rack fig light wiring. sleeper17 3rd gen T4Rs 10 05-06-2013 06:37 PM
Wiring 4 lights on roof rack gmoney35c 5th gen T4Rs 14 01-04-2012 12:19 PM
Wiring Hellas on Roof Rack A10MileHusker General Discussions 3 09-28-2010 06:00 PM
