Old 01-18-2019, 09:16 AM #16
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Originally Posted by jhguth View Post
There's nothing wrong with it, but it will cost a lot more than doing it yourself. For the price of their kit and Northstar batteries you could probably make a lithium setup.
Has anyone on here successfully built a lithium setup? I considered doing it myself and it seemed ideal but gave up once I found out how complicated the charging would become. A Li house battery would be amazing!
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 09:26 AM #17
Xtremluck's Avatar
Xtremluck's Avatar
Also, if it's helpful here is my dual battery setup spec sheet. Where I outlined all the components and cable types needed to build an entire setup: Dual Battery Setup (5th Gen Toyota 4runner) - Google Docs
Old 01-18-2019, 09:33 AM #18
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
not that complicated, just get a DC-DC charger that supports LiFePO4
jhguth is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 12:48 PM #19
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I have... and that's what I am building.
I am using a DC-DC to charge off the main system. Fridge, Viair compressors, lighting, are all native 24v DC anyways and all run more efficient too.
Here is a proof of concept video I made, running a ARB fridge off 18650 batteries.
YouTube
I can scale this battery bank as large as I need it to go, its modular. Looks more complicated than it needs to be due to the test equipment, but its just a stack of cells on a custom printed PCB.
For items that require 12v, I have another step down DC-DC to provide 30 amps of stable 13.8v output.
I was going to build this into a base the fridge sits on, but its going to be a part of my drawer system. Small, high capacity, and very stealthy. Most wont even know its there.
Old 01-18-2019, 01:32 PM #20
it doesn't need to be that involved though, he can buy a LiFePO4 battery off the shelf, a DC-DC LiFePO4 battery charger off the shelf, and go to town
Old 01-18-2019, 02:23 PM #21
Bumbo's Avatar
Bumbo's Avatar
Also correct... LiFePO4 in 4S configuration is pretty much a drop in compatible automotive 12v voltages.
It’s less work, more compatible, the noteworthy difference between LiFePO4 and Li-ion is you generally get better power density, lower cost, and more available options with Li-ion.
LiFePO4 cost more, but it also tends to handle cycle abuse better, and often times can handle more cycles too. Its also generally considered a “safer chemistry”
If I was going to build a car battery pack, I would use large format prismatic cells like this if going LiFePO4.
Old 01-18-2019, 04:10 PM #22
4RExplorer 4RExplorer is offline
Real Name: Ted
4RExplorer is on a distinguished road
Real Name: Ted
How many amp-hours is the LiFePO4 battery you want to charge? e.g. if around 200Ah, then wiring two of the DC to DC chargers in parallel could bring you up to somewhere near the optimal charging amperage of the LiFePO4 battery, but you might then have to limit the continuous charging time off the Toyota OEM alternator to say 20 minutes at a time, to avoid overheating it.
2019 4Runner TRD Off Road
4RExplorer is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 06:39 PM #23
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Northstar Group 65M
nglayton is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 10:37 PM #24
leo4x4's Avatar
leo4x4 leo4x4 is offline
leo4x4 is on a distinguished road
leo4x4's Avatar
Here u go
Odyssey 35r
Sent from my SM-G965U1 using Tapatalk
leo4x4 is offline   Reply With QuoteReply With Quote
Old 01-20-2019, 11:09 PM #25
Coyotegray's Avatar
Coyotegray Coyotegray is offline
Coyotegray will become famous soon enough
Coyotegray's Avatar
Odyssey for both batteries.
2017 Toyota 4Runner TRD Off-Road Premium, Dual Battery with Blue Sea Switch, 2" Lift with Eibach Coilovers & ICON 2" Rear Springs, GOBI Stealth Cargo Rack, BFgoodrick KO2 Tires, weBoost Drive 4G-X OTR 470210 Cell Phone Signal Booster, Goose Gear Rear Plate, ARB CKMTA12 On-Board Twin Air Compressor, ARB Differential Breather Kit, Yaesu FT-891 & ICOM IC-2730A Amateur Radio Transceivers, Victory 4X4 Blitz Bumper and HF APEX 12,000 lb Winch.
Coyotegray is offline   Reply With QuoteReply With Quote
aux , battery , external , frig , night
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
Anyone using the $26 Summit Racing SUM-G1201 battery tray for 31M battery? jicko 5th gen T4Rs 3 04-27-2015 12:24 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
SS006-07 08/11/2007 Battery - Absorbed Glass Mat Battery (AGM) Information CBR_GUY_IA TSB 0 07-12-2009 09:30 PM
