Old 03-05-2018, 03:18 PM #1
calimero calimero is offline
calimero is on a distinguished road
Powertray with ARB single compressor
Does anybody have that specific powertray with the ARB compressor installed on?
- Is there enough clearance under the hood to put in the T junction with the quick disconnect and the pressure switch? The photo on the website seems to be using additional pressure hose and connectors to attach the disconnect to the board. I am more interested in simply attaching the disconnect on the top of the T to the manifold.
Note that to fit in the space, the compressor cylinder needs to be inverted compared to the config it is sold in and the manifold put flat to maximize the space above (the way it is on the photo below)
- Any issue with the compressor vibration and any impact on the electronic part?
Thanks
Eric
Powertray with ARB single compressor-img_5377_360x-jpg
calimero is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 03:32 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Which model ARB compressor is that? It looks tiny, like the one used for air lockers.
Vibration would be my only concern, but that thing is solid state for the most part, probably fine, but I can understand the want to move it somewhere else.
Old 03-05-2018, 04:05 PM #3
12Bravo4R's Avatar
12Bravo4R 12Bravo4R is offline
12Bravo4R is on a distinguished road
12Bravo4R's Avatar
Looks like the CKMA-12...exact same one used in the portable unit I just bought, CKMP-12.
Played with mine this weekend...If all you're doing is airing up tires its just fine; 20-30psi in right at 1min.
2016 TP - Toytech - ICON - FN Wheels - MT Deegan 38 - Borla - TRD CAI - RSG - RCI
12Bravo4R is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 04:33 PM #4
It's the CKMA12. What ARB calls the High Performance 12V on-board compressor. It is also sold in a carrying box like the one in the photo above.
Old 03-05-2018, 04:55 PM #5
Bumbo's Avatar
Bumbo's Avatar
Its a lot more compact than I thought it would be... I think I can find room for that thing even with my dual battery... I've been having trouble finding room for a Viair pump.
The pump for the lockers must be tiny.
Old 03-05-2018, 05:00 PM #6
12Bravo4R's Avatar
12Bravo4R's Avatar
Its the same one...
https://www.4wheelparts.com/Air-Comp...t_pn=ARBCKMA12
"Not only will it enable the ARB lockers to work; but it is also capable of supplying air pressure for other occasions, such as refilling a low tire"
Old 03-05-2018, 05:40 PM #7
Bumbo's Avatar
Bumbo's Avatar
Originally Posted by 12Bravo4R View Post
Its the same one...
Its different... the one for lockers is even smaller and not for tire fill...
ARB On-Board High Performance 12 Volt Air Compressor (CKSA12)
You can use the bigger one for lockers too, but I would still consider buying a separate dedicated system for air lockers if I went that route.
I'm just surprised how compact the CKMA12 is when compacted to the foot print of some other pumps.
Old 03-05-2018, 05:52 PM #8
12Bravo4R's Avatar
12Bravo4R's Avatar
Originally Posted by bumbo View Post
its different... The one for lockers is even smaller and not for tire fill...
arb on-board high performance 12 volt air compressor (cksa12)
10-4.
Doesn't look to be that much smaller, based on the video. But yes, this one is pretty compact as is.
Old 03-05-2018, 10:47 PM #9
Bump! So anybody has this tray with the ARB compressor?
Old 03-06-2018, 05:39 PM #10
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
I do not have the plate but I do have the same compressor mounted in the same general location in engine bay with a custom mount. As you stated the manifold has to be rotated to clear hood, but the pressure switch is under the disconnect on my install.
I suggest contacting power tray.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 12:37 PM #11
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
Just received this combo, yet to install. Seems like a lot of features for a small space.
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Overland Equipped or PowerTray fuse block plate mscot General Discussions 33 02-08-2018 08:56 PM
ARB Single Cylinder Compressor - CKMA12 Review Rock_Rat General Discussions 3 08-21-2016 04:16 AM
a/c compressor "screech" wen compressor engages or cycles? xspsi6 3rd gen T4Rs 9 06-14-2014 04:51 PM
What's a single mom to do? fiercefoxie 3rd gen T4Rs 139 10-10-2013 09:03 PM
strut compressor vs. spring compressor jmrwd3 3rd gen T4Rs 6 05-19-2008 03:03 AM
