Originally Posted by delloro
Is the padding foam? Can I use a hose to wash the pulled carpet and padding?
On the back of the carpet there is some padding in key areas, most of it is jute backing, with a couple of pieces of foam. I pressure washed mine (with a basic home electric pressure washer, like 1800 PSI I think) both times. The jute backing is a little worse for wear, but I wanted to make sure I got all traces of funk removed. I sprayed mine with some enzyme-based carpet cleaner and left it in the sun for UV activation and to dry, with a big shop fan blowing over it. Careful scrubbing the carpet, if you do, I "fluffed" the pile a bit in one section when getting aggressive with a nylon brush.
Absolutely worst case, I found the carpet for around $500. While I'm done with mud bogs and unknown water traps, if it happens again I'll likely end up replacing the carpet rather than trying to get another deep cleaning out of it. I don't think the jute will hold up to another pass.
