03-12-2019, 04:07 PM
#61
This will most likely be my first MOD (My used TRD PRO came with a SSO bumper already). A few questions:
1) As someone who's never done body work would you recommend me install this myself?
2) Has anyone put any protective mesh in the exposed area to protect things like the fog light wiring?
3) My bumper isn't pre-drilled for the high-clearance kit. Is it easy to figure where to drill the extra hole into the Hybrid Bumper?
All of your trucks look great! Thanks for your time.
"HANZO" 2015 TRD PRO: SSO Front Bumper w/ Stage 2, SCS F5's (17x9-38), 285/70/17 Falken Wildpeaks, 2" all-around Dobinsons IMS, JBA UCAs, Slee Sliders, BMC, Warn Winch, LED High/Low, DD SS3 Fogs, Rigid Lightbars (Amber/White light), Nise Rack, Extended Diff Breather. Road Trip 2021 - YouTube
03-12-2019, 04:31 PM
#62
If you are going to hack away on your bumper w/o the stage 2 kit, watch YouTube for tutorial as where to cut but u may want to disconnect your fog lights and tuck the wires back when you cut. Other than that, hack away.
If you are planning to install the sso stage kit, that’s way more involved than just cutting. Wonder overland on YouTube has a great tutorial on this install as well
03-12-2019, 04:44 PM
#63
Haha, I'm not sure i'm brave enough to do it without a kit to give me a guide of some sort. Thanks for the vid! What a cool couple
03-12-2019, 05:03 PM
#64
I did the unofficial version without the kit, just started cutting.
I just followed the below body line carefully and threw some weather stripping on over the lip. Took about 30 minutes total. Super easy, a lot less effort than going with the SSO kit I would imagine.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
03-12-2019, 05:16 PM
#65
Haha, you have nerves of steel to just start cutting!
I like the idea of the kit because it has the metal extensions. I'm thinking I can mount a mesh grill/screen in the exposed area and mount the mesh to the metal extensions from the SSO Stage 2 kit.
However, without really looking at it I can't know for sure.
03-12-2019, 07:05 PM
#66
The side protection is nice. I would have been more inclined to go with SSO's product if the cut wasn't so aggressive. Picking the line I did was a more middle-of-the-road option that I think looks good.
Build Thread
03-12-2019, 10:05 PM
#67
MY advice to you is with the SSO wings:
1. the tape has to meet at both measurements (bottom of bumper and near the wheel well).
2. the tape has to follow the straight edge below the fog light.
3. the tape has to lay down flat (if you are getting creases, its not straight).
4. View the tape from all the angles, if it doesn't look or feel right then it probably isn't.
5. If you aren't happy with steps 1 to 4, rip the tape off and start over. Do it over until you are happy. Waste as much tape as you want.
I spent a lot of time on step 5, and I'm glad I did. Every time I got frustrated, I started over, until the tape just fell into place....freaking weird.
One thing with the SSO kit is that if you have a heat gun you can melt/shape the inner fender lining and tuck it inside the braced wings. I didn't realize I could do that, so I chopped mine off....oh wells.
Now if you skip the SSO kit all together, you can cut it however you like so its more forgiving.
If I had to do it all over again, I would just hack my bumper apart, and if I liked the style and wanted to go higher with the cuts, that's when I would go the SSO route. Mainly, because the SSO cut is so high up that if you aren't running big tires and/or wide wheels, it looks a bit out of place. I'm running 285s w/ 17x8.5 w/ -40ish offset, and my wheels and tires look tiny now. Need more tire!!!!!!!
04-12-2019, 07:56 PM
#68
Originally Posted by samwhich
I went with the DIY route as well with my SSO. About 30 mins and a dremel!
Originally Posted by Crusifix
Sawzall with fine tooth blade and edge trim. The SSO kit is nice, and adds a level of protection, but to me, it takes the cut too high.
Originally Posted by YellowSnow
Bro...just do it! I used zip ties to tuck the fog light wires up under, and spray painted the washer reservoir.
Below shot of the driver side.
Originally Posted by stephan07
I ordered these back in early November and they showed up this week. Took about 90" to get them installed and 2 Sip of Sunshine brews. Not a perfect fit secondary to my trimming, but pretty close and looks great.
Thanks all for your helpful photos. I just finished cutting mine, and it definitely worked out better thanks to this thread
04-12-2019, 08:01 PM
#69
Ahhhh pics please!!
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
04-12-2019, 08:16 PM
#70
Originally Posted by Bayou_Pro
Ahhhh pics please!!
I'm not ready for prime time yet haha. Trying to avoid edge trim so I still need to fine sand it. Mine is probably the least aggressive cut in the thread so far, but I think I like it this way. Of course, I can always go back and cut more. I'll be sure to post once finished.
05-13-2019, 10:53 AM
#71
Not sure how I feel about the kits yet. It looks like
@ C4 Fabrication
is about to come out with one as well (they are sharing lots of pictures via Instagram stories lately-I just ordered a low profile bumper from them).
I think
@ YellowSnow
really got it right proportionally with his cut lines. It's a nice even reveal that matches other lines along the fascia. I'm most likely going to shoot for that design and see how it works for my setup. You can always cut more. I'm hoping to make the cuts with a razor knife and finely sand it down so I don't need a trim piece. We'll see how realistic that plan is.
I did research and this is a pic of the new C4 Lo Pro High Clearance Mod
C4 Fabrication on Instagram: “Nice shot from @overlandiowa when he came to visit us a couple weeks back. His front end is featuring our Lo-Pro winch bumper with full…”
2019 TRD Off-Road Premium - MODS:
C4 Fab Lo-Pro Bumper & Hi-Clearance Mod, SB X20 Winch, Radflo 2.5 w/ 3 inch all the way around / Long travel rear MT, SCS Ray 10 17 285s, Toyo AT2, Caliraised rock sliders w/ kickout, RCI Offroad skid plates full kit, roof rack delete, ARB breather relocate kit, Factor 55 fairlead rope guard ultrahook, ExtremeLED 30in, Feniex dual color lighting, typhoon handheld controller/siren, and Hammer low frequency siren system, Diode Dynamics turn signals switchback, Xenon Depot HID kit and 9005 low beam, Philips LED Fogs 2700k yellow, BOSS StrongBox drawer system, Genesis Dual Battery Kit.
05-13-2019, 04:12 PM
#72
Originally Posted by Marine 4Runner
Good to know, thanks! $325 sounds a little spendy, but I'd take a look at it if it had a way to secure the plastic so it doesn't flop around and conceal the cut lines.
11-06-2019, 03:00 PM
#73
So if you just opt to hack it ... I know people have mentioned the bottle for the washer fluid and the fog wires being more exposed.
Do I really have to worry about anything being damaged? I’m so close to just getting the dremel out and just getting her done ... all That’s holding me back is that question
So driving in any weather is ‘a ok’???
12-03-2020, 11:30 AM
#75
Looks kilker! I did mine with a dremel, and $10 in rubber weather strip
Looks awesome! Cleanest cut line I’ve seen, better approach yet understated and classy compared to most. Can you provide more photos from different angles (underneath, inside wheel well)? Did you retain all the factory bolt locations? I’m itching to try to duplicate this on my 2020 Venture. Time to chop ‘er up 💪
