Old 12-03-2020, 11:46 AM #76
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
Originally Posted by Dirty Dan View Post
Looks awesome! Cleanest cut line I’ve seen, better approach yet understated and classy compared to most. Can you provide more photos from different angles (underneath, inside wheel well)? Did you retain all the factory bolt locations? I’m itching to try to duplicate this on my 2020 Venture. Time to chop ‘er up 💪
His cut looks pretty similar to mine. If you do it right, you don't cut out any bolt locations. I ended my cut in the wheel well right under the last fender liner bolt.
I'll tell you right now that I cut out too much fender liner when I did this. My advice would be to leave as much as possible, only start cutting the fender liner once you know exactly how you're going to secure it in there, then cut the excess.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 11:58 AM #77
Dirty Dan's Avatar
Dirty Dan Dirty Dan is offline
Dirty Dan is on a distinguished road
Dirty Dan's Avatar
Nice! Looks great. Thanks for the quick response. How much of the “guts” are exposed? I gather I’ll have to paint the washer bottle and tie up the fog light wiring. Anything else you’d recommend?
Dirty Dan is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 12:10 PM #78
With this particular cut, which I mentioned before is like the middle-of-the-road option, the washer bottle is not overly exposed. I spray painted mine black at first, but I'm not in a hurry to do it again now that the paint is wearing off. It's just not that noticeable.
A heat gun will be helpful to manipulate the fender liner how you want. And zip ties are perfectly adequate for holding it in place if needed. I like using the zip ties, since they are easy to put on, they hold well, and if you need to cut them off to get in there it's no biggie to replace. Sounds like a hillbilly fix, but it's effective and easy, and nobody will notice.
Also, I wouldn't worry about getting your cut edge perfectly smooth. The edge trim (which I recommend, obviously) will cover it up nicely, no need to sand it down.
Your fog wiring will be more exposed, depending on what you do with your fender liner. Definitely a good idea to tuck it out of the way, but like I said, keep as much fender liner as possible to try to keep it covered. This was my mistake.
Other than that, there's nothing to it. Cut conservatively and then shave off more if you need, it doesn't work the other way around.
EDIT to mention: Wear safety glasses and sleeves. You'll get hot melting plastic sprayed all over you. It won't burn your arms or anything, but it stings. And you definitely don't want it in your eyes.
Build Thread
Old 12-03-2020, 12:17 PM #79
Dirty Dan's Avatar
Dirty Dan's Avatar
Also, I wouldn't worry about getting your cut line perfectly smooth. The edge trim (which I recommend, obviously) will cover it up nicely, no need to sand it down.
Sweet. Believe me, I am a huge proponent of zip ties, call me hillbilly if you like but those things are amazing!
I’m definitely going to do a conservative cut, I like the look better and given the fact that she’s my daily driver, I want to retain a fair bit of bumper to keep the aerodynamics reasonable, and wind noise down as much as possible. Thanks again for the solid advice.
I’ll post photos when I get the job done!
Old 12-09-2020, 12:39 PM #80
dakgildea dakgildea is offline
dakgildea will become famous soon enough
Chopped mine the other day.
| IG: daks.4rnr | 2018 TRD Off Road Premium | Dobinsons 302/505 700/705 | Dobinsons UCA | Shrockworks Angled Sliders | RCI Skids | C4 LoPro | Prinsu 3/4 |
dakgildea is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 12:49 PM #81
maspenny maspenny is offline
Real Name: Matthew
maspenny is on a distinguished road
Real Name: Matthew
Love that look. I'm thinking of doing the same.
Matthew
17' Trail KDSS, black matte wrap, Gobi rack, Klien onboard air, Ridged lights, K&N and soon to be supercharged
maspenny is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 03:03 PM #82
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
What is everyone utilizing for the plastic or rubber edge trim?
ragin_cajun is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 07:33 PM #83
D1105 D1105 is offline
D1105 is just really nice D1105 is just really nice D1105 is just really nice D1105 is just really nice
I used these from Amazon
Sent from my iPhone using Tapatalk Pro
17 TRDOR | Metal Tech OPOR sliders | Summit Wheels | Wildpeak 285/70/17 | 5100's / C59-302 w 1/4" plate driver's side / C59-505 w/ 10mm packer | Prinsu full rack/GOBI ladder | C4FAB lo-pro bumper w/high clearance | Sprint Booster | RoofNest Falcon RTT | Ellis Precision knobs | BPF molle panel | Rago center console molle
D1105 is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 12:59 AM #84
Dirty Dan's Avatar
Dirty Dan's Avatar
I cut mine up the other day. Kept it quite conservative. Thanks to ryguytheman for the solid advice.
One thing I want to point out is that I figured out a good way to attach the passenger side inner fender in a way that mostly covers the washer bottle, while also leaving almost all of the liner intact.
I cut the liner vertically just outside of the washer bottle, wrapped the inner portion around the bottle, trimmed just the end of that piece down a bit and zip tied the end of it to the plastic washer fluid hose retainer on the front of the bottle. The outer part I zip tied to the fog light bucket, after drilling a small hole in the bucket.
Got the SSO high clearance mod done today-cd0b93c9-4a92-4965-9f71-955eacbbcb0a-jpg  Got the SSO high clearance mod done today-8fe70486-09bd-4c18-9707-b3343480d21a-jpeg
Old 12-10-2020, 12:30 PM #85
Dirty Dan's Avatar
Dirty Dan's Avatar
I cut mine according to your recommendation, and I really like the way it turned out! Thanks for your advice 🙌
Check out my last post to see my solution for the inner fender/washer bottle situation.
Got the SSO high clearance mod done today-9a5b5bc0-d099-47df-9e6f-c85aaf4eb88d-jpeg  Got the SSO high clearance mod done today-049c096c-6e1e-4eaa-957c-36671f68e047-jpeg
Old 12-10-2020, 01:27 PM #86
Well done, looks great! Glad I could be of some help.
The remnants of my fender liner are zip tied to my washer reservoir as well, but I cut too much to make a neat job of it like you did.
Build Thread
Old 12-10-2020, 01:54 PM #87
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
Man that looks good!! It looks like it's supposed to be cut like that. Very clean... Like most others in this thread who have not done this mod, here I am thinking, "I want to do this..."
I think I'm gonna do this....
I'm gonna do it.
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
smeerun is offline   Reply With QuoteReply With Quote
Old 12-11-2020, 12:00 AM #88
Dirty Dan's Avatar
Dirty Dan's Avatar
I'm gonna do it.
Do it! Read ryguy’s posts, his advice helped me a ton.
My best advice is spend some time getting your cut line taped out. Rip it off as many times as it takes, until you get a line that you are happy with. I literally spent well over an hour just messing with tape...I am picky. 😂
Have fun and post photos when you get ‘er done! 💪
close , feel , garage , great , week
Wilco high clearance or similar bigair96 Want to Buy/Trade 1 01-31-2019 09:55 PM
SSO High Clearance problems? westtex 5th gen T4Rs 48 01-15-2019 01:10 AM
Anybody running 265s with SSO high clearance? westtex 5th gen T4Rs 26 11-28-2018 01:44 PM
High clearance fuel tank? KCcarguy 5th gen T4Rs 4 05-05-2014 01:57 PM
Valve Clearance on High Mileage 3.4L? RC57 3rd gen T4Rs 7 09-30-2010 02:20 PM
