Old 01-29-2019, 11:57 PM #16
Outinfront's Avatar
Outinfront Outinfront is offline
Outinfront is on a distinguished road
Outinfront's Avatar
Originally Posted by jrandom View Post
@Outinfront Sucks for sure, join the club. I will leave you with this, a solid piece of advice I was given years ago...no one cares about your truck as much as you do, do your own work.
Amen first and last time!
Outinfront is offline   Reply With QuoteReply With Quote
Old 01-30-2019, 12:23 PM #17
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I've had a friendly reminder of that since my 2nd "free" oil change; a nice chip on the very front edge of my hood obviously made when a tech closed it on a tool.
1000MPH is offline   Reply With QuoteReply With Quote
Old 01-30-2019, 12:28 PM #18
renau001 renau001 is offline
renau001 will become famous soon enough renau001 will become famous soon enough
Originally Posted by Outinfront View Post
Took it to the dealer had them do the service 2
Got home checked the oil the next day and it was 1/2" above the full line.
Opened up the airfilter housing and found the airfilter installed wrong again.
LoL I give up
While I don't doubt you, make sure you read the oil right. A lot of people misread the level on these vehicles. Here's some tips.
1) Check w/ engine warm greater than 5 minutes after shutting off engine
2) Leave dipstick out while waiting 5 minutes to allow oil in dipstick to drain back down, makes it easier to read (won't be splotchy)
Dealer service centers are hit or miss. Hopefully you have another close enough to you. Even if you do your own maintenance (which I recommend), you never know when you might have to get an airbag replaced (recall) or have a warranty issue. I still want a place or at least a person I can trust. You can also decline the "free" multi-point inspection so they don't go poking around in your filters and what not.
2016 Trail Edition Premium w/ KDSS. LT265/70R17 BFG KO2s, Ceramic Pro, TSO pro grille, sliding cargo tray, WeatherTech floor liners, '10-'13 trail running boards.
Nobody cares about your vehicle as much you do. DIY Maintenance Quick Reference
renau001 is offline   Reply With QuoteReply With Quote
Old 01-31-2019, 09:15 PM #19
Outinfront's Avatar
Outinfront's Avatar
Update
So I took her in for #2 service
Picked her up and drove around for a few days
After work I decided to check the airfilter again and sure enough it wasn't seated again after i had them look at it.
Weird thing is when I put it in with care it will stay seated.
Old 01-31-2019, 09:23 PM #20
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
*****es about dealer.
Takes it back to same said dealer.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 02-01-2019, 02:09 AM #21
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
That filter has taken a bad set from your initial problem. Have them put in a new one or put one in yourself. The first time you were there did you get a work order written up for it which shows a resolution? If you did, just put a new on in and move on, save the first record if needed way down the road. Good Luck.
CavPro is offline   Reply With QuoteReply With Quote
Old 02-04-2019, 08:24 PM #22
Outinfront's Avatar
Outinfront's Avatar
I purchased the vehicle brand new from them and decided to give them a chance to fix the issues before condemning them unfortunately the guy looked at the air filter and then smacked the lid down and put the clips on right in front of me I have no doubt in my mind he was the cause of the problem in the first place
Lesson learned
dirt , filter , installed , offroad , wrong
WTT 2017 SR5 MGM hood with clear dealer installed CPP for TE hood ( NC) drtyjerz47 Want to Buy/Trade 0 04-04-2017 05:52 AM
2x 2017 Limiteds on dealer lot, but with different tires from factory enolasfinest 5th gen T4Rs 29 03-17-2017 01:17 PM
Seriously? Dealer installed wrong end link sashcraft 3rd gen T4Rs 3 08-27-2015 11:18 AM
factory or dealer installed security system? chuckerg 3rd gen T4Rs 2 03-14-2014 01:42 PM
Factory/Dealer installed winch? Serotta 4th Gen T4Rs 0 06-22-2011 08:57 PM
