01-13-2018, 02:30 AM
Trail Center Trim on SR5 and Limited
Does anyone know if the Trail (TRDOR) center trim unit and head unit trim, that is SMOKED GREY, fit with the sr5 and limited units?
Has anyone tried replacing them? My silver trim is really scratched up and now looks really old and cheap.
01-13-2018, 02:45 AM
It looks identical to my sr5 trim aside from the color and finish. Easy to remove and replace. I replaced it in my sr5, its about a 5 min job.
01-13-2018, 05:07 AM
Awesome! Would you let us know where you go the parts? Did you replace the head unit as well?
01-13-2018, 12:20 PM
I was interested in replacing my sr5 trim as well but didn’t have luck finding where to purchase
01-13-2018, 01:00 PM
In interested in replacing a few of my trim pieces. I just can't find where to buy the parts.
01-13-2018, 01:02 PM
Real Name: Chris
Real Name: Chris
It is identical other than the SR5 has an electronic shifter for the transfer case, not a lever. Not sure the electronic panel can be moved from the stock silver panel over to the black panel. Keep us posted though, i'd like to do this also.
01-13-2018, 02:11 PM
Slightly off subject I'm selling the trail version of the trim piece that goes around the glove box.
2018 Toyota Tacoma
2010 Toyota 4runner TE - Sold
2002 Toyota 4runner - Sold
2000 Toyota 4runner - rolled
1996 Toyota 4runner - sold a long time ago in a galaxy far far away.
01-14-2018, 01:33 AM
Ordered mine at:
https://toyotaparts.sullivanbrotherstoyota.com/
It is just a matter of figuring out the right part number for what you need. Like 2016 said above, the sr5 has the electronic shifter, I actually ordered one with the manual shifter inlay on accident and had to return it for the one with the electronic shifter inlay, so I know what you need is available on there.
01-14-2018, 01:43 AM
Just found it in my old emails. The part I had to return with the manual shifter inlay like you show in your picture is # 58804-35490
That is the # for one with the light grey finish that matches my 2013 sr5 interior.
01-16-2018, 12:45 PM
OK. Thanks so much Larry. Will check this out and post how to do this. I'm not sure what the 2013 "center console upper panel" looks like, but assuming it's like the 2015 Trail trim, I think it should work.
There are also silver door handle trims that match. I'll look into those as well.
01-16-2018, 01:13 PM
@ lukeskywalker
, why don't you just remove your trim panels, wet sand them with + 350 and then spray them with a few coats of rattle can color match?
Troner envy... the struggle is real!
01-16-2018, 01:19 PM
Originally Posted by CF_Machete
@ lukeskywalker
I don't have anywhere to do that. Physically and conveniently. I live in a high rise.
01-16-2018, 01:25 PM
I personally love the 'faux-carbon fiber' look of the 2018 interior trim piece.
01-16-2018, 08:44 PM
You should be able to order one with whatever trim color you want, just use the search function to define the year and model, and they should have the part that matches.
01-18-2018, 05:37 PM
waukeganlarry, hate to ask, would you be able to show a picture of your interior and explain a little about what you did?
