Old 01-23-2019, 10:58 PM #16
bigair96 bigair96 is offline
bigair96 will become famous soon enough
rear bumper will even that right out.....I think theres a thread on that.
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
bigair96 is offline   Reply With QuoteReply With Quote
Old 01-23-2019, 11:13 PM #17
atchcraft's Avatar
atchcraft atchcraft is offline
atchcraft will become famous soon enough atchcraft will become famous soon enough
atchcraft's Avatar
Originally Posted by Pat_reek View Post
So 2-3 weeks ago I had my local shop installed my kings shock. When i went to pick my car up I saw that my car had a rake upfront that doesn't evenly lined up with the rear. So I called the shop the next day and told them about the situation they told me that it will fix itself, just put in couple 100 miles or so. So last week went to LA to take my kids to Disneyland to put in the miles that they suggested. Now it seems like nothing changed. Somewhere in the forums I read about the rake issue. But still confuse. (sorry for being a noob) but i had to call my shop back and tell them again that the rake is still happening up front. Give in mind i paid 2k to have it installed, dont flame me for not installing myself. LOL. Anyways, Before i take it in, I know the max on Kings Shocks is about 2" ...that or upgrade the different spring up front to eliminate the rake. So any input will help. What should i do before i take it in?
It’s most likely not going to “fix itself”, but it does need time to settle in. Drive it for a while, then take it back to the shop and have them adjust your front coils. It’s easy to do and not that big of a deal. There are a lot of things to factor in when setting up a suspension, but I’m sure that a couple of turns of adjustment will get you where you need to be. I’m sure your shop will take care of you.
Also, if you normally have a lot of gear in your truck, or do a lot of camping, load it up and see how it rides and handles then, before you make a lot of changes. Mine has a bit of rake, but it’s set up t haul and wheel with a metric f@ck ton of stuff.
atchcraft is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 01:57 AM #18
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
get airbags and your problems are solved.
cheap and easy to install.
Old 01-24-2019, 03:03 AM #19
Pat_reek Pat_reek is offline
Pat_reek is on a distinguished road
Will do. I just took off my gear when we headed to LA. Probably why it didnt settle in yet. I'll just have the shop look at it still.
Pat_reek is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 11:38 AM #20
MTN4RNR's Avatar
MTN4RNR MTN4RNR is offline
Real Name: Max
MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough
MTN4RNR's Avatar
Real Name: Max
The rear is higher than the front. Just want the front to level with the rear. Or have it leveled it out all around .
As others have said, the coils will settle some, but the fronts will as well. Load it down and hit the trail for a trip as it is. That will help "break in" your springs, so that when they do any adjustments, things have already settled and they can make one more adjustment. These suspension systems, while generally being factory replacements, do need tuning to get things right. I had to have my coilovers adjusted after about a thousand miles to dial things in. Definitely not the installer's fault because every vehicle's weight distribution is different, so be sure to remember that if they want to charge you for the adjustment.
2016 MGM Trail Premium - KDSS
Explore4R.com
Building the MTN4RNR
Instagram --- life.to.the.max
Writer/Editor at Trail4Runner.com
MTN4RNR is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 02:17 PM #21
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
"Hit the trail"
I LOL'd
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 10:53 AM #22
I just had the chance to look at it this weekend. And it seems like it's dialed in on 1 tread on the shocks. I was reading somewhere it has to be between 8 treads or so to be even. I can be wrong.
And yes I need to hit the trail soon. But since everyone from the bay lives in a busy life style. The earliest time for me that my work permits would be in May, for Overland 2019. And my truck needs to be ready for that. I HOPE. lol.
Old 01-25-2019, 02:24 PM #23
mrblah's Avatar
mrblah's Avatar
8 threads will give u about 3 inch lift in the front. You should leave some rake
Old 01-25-2019, 07:18 PM #24
MTN4RNR's Avatar
Real Name: Max
MTN4RNR's Avatar
Real Name: Max
Originally Posted by MeefZah View Post
"Hit the trail"
I LOL'd
Ahhh c'mon, some of us actually do that you know....
Explore4R.com
Old 01-25-2019, 08:23 PM #25
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
There is no way to accurately say that 8 threads gives you a specific amount of lift. This is all going to change by the weight of the vehicle and spring choice, (weight/length). Just get the height set to where you want it and make sure you have enough or not too much preload.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 01-26-2019, 02:05 PM #26
So i should load all my gear and have it adjusted...and go from there.
Old 01-26-2019, 04:36 PM #27
Bayou_Pro's Avatar
Bayou_Pro's Avatar
Just depends on what you want. I would adjust it so that you have a little rake rear high when unloaded and level when loaded. If your rear is really squatting when loaded them you need heavier rear springs as well.
Paul
Old 01-26-2019, 05:13 PM #28
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
Your asking bunch yahoos on the internet to give you advice on you suspension set up in a rather vague way.
If you want a more specific answer post up exactly what your running, what coilovers ,what spring rate, front and rear, plus a pic of your front coil over. With that information perhaps someone has your set up and can share how they have it set up.
But from the description what I am reading is the rear is too high and the front coil overs are set near the lowest setting- based on you saying there is not much thread showing above the springs. Which to me says your front coil overs are set near the bottom = less lift.
Hopefully the $2k you mentioned included your suspension and not just labor, as just labor for install should be $500-$600 including alignment.
Teamoatmealpie is offline   Reply With QuoteReply With Quote
installed , kings , rake , shop , told
Noises with race shocks (icon/kings/fox/etc) THEROK 5th gen T4Rs 1 07-16-2014 07:53 AM
Installed 5100's, light rattle upfront... advice on tracking down... PwAg 4th Gen T4Rs 8 01-23-2013 01:15 PM
Anyone have a pic with 1" spacers upfront? bgmac 3rd gen T4Rs 0 09-13-2008 12:06 PM
Kings shocks for 86 4runner prodigy2k7 Classic T4Rs 0 03-11-2008 04:19 PM
Upfront 4RUNN3R Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-09-2006 09:03 PM
