Old 01-24-2019, 04:50 PM #16
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
For 2017 4Runners …
Standard Hill-start Assist Control (HAC) provides additional control when accelerating from a stop on a steep incline by helping to hold the vehicle stationary while the driver transitions from the brake pedal to the accelerator.
Limited and SR5 models equipped with 4WD also feature standard Downhill Assist Control (DAC). This feature augments low-speed descending controllability by helping to maintain a constant slow speed and preventing wheel lockup, allowing the driver to concentrate primarily on steering.
TRD Off-Road, Off-Road Premium, and TRD Pro models add the capability of an electronic-locking rear differential and Toyota’s Crawl Control (CRAWL) feature. The latter helps maintain a constant speed, enhancing vehicle control when driving up and over obstacles in challenging off-road situations. With the transfer case shifted into low range, CRAWL regulates engine speed and braking force to propel the vehicle forward or in reverse at one of the five driver-selectable low-speed settings. The driver can focus on steering over obstacles without having to also modulate the throttle or brake pedal.
As conditions on the trail change, the 4Runner TRD Off-Road, TRD Off-Road Premium, and TRD Pro driver can adapt the vehicle with the Multi-Terrain Select system. A dial is used to select the mode that matches prevailing terrain and conditions, adjusting wheel slip accordingly. For example, on loose terrain such as mud and sand, more-than-normal wheel slip is permitted, allowing wheel-spin to work in the vehicle’s favor.
The Mogul setting is for any extremely uneven terrain, such as V-ditches, slopes, and ridges -- uphill or down. In this mode, wheel slip is minimized and the system acts more like a limited slip differential. On TRD Off-Road models, an overhead console groups the off-road control switches into one location.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 04:54 PM #17
Drama1 Drama1 is offline
Drama1 is on a distinguished road
Don't post very often here either, frequent reader though. I have an 05 SR5 V6. 220,000 miles on it. I was ready to pull the trigger on a new 18 SR5 Premium last year until I went to Denver for a week on business. I rented a 2017 SR5. After a week of driving the 5th Gen. there was no way I was giving up my 05. I know you can do mods on pedal feel and supposedly it works, but in my un-educated opinion the 5th Gen. is God awful underpowered. Going up the mountains outside Denver I had to practically floor the Runner to get it going. Really turned me off to a new model and especially since I really like the look of the 5th over the 4th Gens I was really disappointed. Like I said, just my un-educated opinion.
Drama1 is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 04:59 PM #18
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Well yeah, normally if you want to go faster up a steep hill you have to press down on the gas. Floor it and it'll top 100 up any grade on I-70 no problem.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 05:11 PM #19
Orc's Avatar
Orc Orc is offline
Real Name: Ben
Orc is on a distinguished road
Orc Orc is offline
Orc's Avatar
Real Name: Ben
We have a 2016 Outlander now that's underpowered! The 4Runner has plenty of power but the 4.0 isn't a 4.7 V8 so more revs are needed.
If you want power get a tahoe with a small block
2019 SR5 MAGNETIC GRAY METALLIC
Orc is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 05:22 PM #20
Jimbo's Avatar
Jimbo Jimbo is offline
Jimbo is on a distinguished road
Jimbo's Avatar
I own a 4th gen SR5 and a 5th gen LE.
To me, the most important differentiating factor between all the 5th gen models is that only the LE has full-time AWD. Every other model offers only part-time 4x4 modes.
I rarely offroad. The 5th gen is my bad weather / winter daily driver. To me, having power to all 4 wheels all the time is much more useful that crawl control or a locking rear differential. Full-time AWD affords you power to all 4 wheels in rain and patchy snow/ice. You can't use part-time 4x4 modes in those conditions without either constantly switching back and forth to rear wheel drive, or leaving it in 4x4 on the high traction sections and putting strain on the drivetrain / transfer case.
So it really comes down to how you're gonna use this thing.
Jimbo
'18 Limited
'05 SR5
Jimbo is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 06:04 PM #21
Orc's Avatar
Orc Orc is offline
Real Name: Ben
Orc Orc is offline
Orc's Avatar
Real Name: Ben
In my 2007 Tacoma that didnt have traction control I lost total control on ice at probably near 55mph on an interstate bridge. Sliding sideways at those speeds I looked outside the passenger window to see a semi coming right at me. Somehow the truck turned back but slightly too far tapping the bridge to turn me perfectly straight. Needless to say I checked my underwear after that one. The rear bumper was dented slightly.
When you get a huge snowfall part time 4x4 is great but I generally prefer my fwd beater in the winter. Awd and 4x4 just make you go faster and that can be bad when you think you can stop and you can't. Fwd is great traction tester.
Old 01-24-2019, 06:46 PM #22
In my 05 SR5 V6, I can run in four-wheel all year long or leave it in two-wheel all year long. What I generally do, summer, I'm in 2. Winter, I leave it in 4. Don't know why the hell Toyota moved away from this. Another reason I hate to get rid of my 4th Gen.
Old 01-24-2019, 06:55 PM #23
Orc's Avatar
Orc Orc is offline
Real Name: Ben
Orc Orc is offline
Orc's Avatar
Real Name: Ben
If it's not rusted out I would just fix it. You know if it's a solid truck or not. I paid 37k for my SR5 and that's no small chunk of change. You might keep yours on the road for many more years for not much money.
Old 01-24-2019, 10:32 PM #24
GearJunkie88's Avatar
GearJunkie88 GearJunkie88 is offline
GearJunkie88 will become famous soon enough GearJunkie88 will become famous soon enough
Originally Posted by 4-Legged-Runner View Post
We really like the XREAS until it came time to replace shocks/struts. When it failed, it FAILED. We ended going the 5100 route.
I went from a 2008 4R Sport with XREAS to a 2017 ORP without KDSS or XREAS. The 2008 XREAS failed and I replaced it for some enormously expensive amount. I wish I had found this forum before I did that. I would have replaced the suspension with 5100s instead. My 2017 with normal suspension was perfectly fine. I didn’t miss XREAS at all. I eventually did a lift and installed 5100s and I think it handles better than that overrated XREAS stuff I had before. Don’t buy into the suspension “upgrade hype” of XREAS or KDSS. Maybe I’m just not sophisticated enough to fully appreciate the benefits. Just my 2 cents...
2022 SR5 Premium 4WD
GearJunkie88 is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 10:23 AM #25
RPS99SHO's Avatar
RPS99SHO RPS99SHO is offline
RPS99SHO will become famous soon enough
RPS99SHO's Avatar
I think being a mile above sea level contributed...I'm not defending the general laziness of the 5g, but maybe try one in Chicago and see if it feels different. I bet it will.
RPS99SHO is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 11:23 AM #26
FZRunner FZRunner is offline
Real Name: Greg
FZRunner will become famous soon enough
Real Name: Greg
I've had 3 gen's of 4runners and love em all. I completely understand the issue, having had the chance to upgrade to a 5th gen recently. Honestly, I could live with one. I could adapt, but I prefer my 4th gen. But, if economically it wasn't worth keeping, I'd buy a newer (used) 5th gen and be fine.
If I were you, I'd do a spreadsheet kind of thing with repair stuff vs. money down and such, plus the fact a newer one will last another whatever amount of mileage. Or not. Cheers.
PS My daughter loves the new Voodoo Blue, so it's good she doesn't get to make these decisions. Good luck.
FZRunner is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 11:42 AM #27
4-Legged-Runner's Avatar
4-Legged-Runner 4-Legged-Runner is offline
4-Legged-Runner is on a distinguished road
Originally Posted by IanB View Post
I'm a current owner of an '04 GX470 (same drivetrain as your 4th gen minus the vvti and power boost that came in '05), and a '15 4Runner Ltd.
The pedal calibration in the 4Runner made it feel like a dog, despite having a signifigant power and torque advantage on paper over the GX. I purchased a sprint booster for the 4Runner and it made a considerable difference, making the 4Runner feel like the spec sheet suggests it should, well worth the purchase price IMO. Totally changed the character of the 4Runner for the better. The power is there, you just have to work it really hard to access it in stock configuration.
How does the use of the sprint booster impact your warranty? Do you set it back to factory with every visit to the stealership??
For me, full time 4WD is not always a positive. More spinning parts all of the time can mean more to go wrong when it does, especially since we have kept our current 4G since new and we are at approx. 165K miles. We get attached to the vehicle.
Matt
2005 T4R Sport Edition V8
2016 Honda Accord Sport 6MT
4-Legged-Runner is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 11:56 AM #28
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
The CV's and front differential still spin with a selectable 2wd/4wd model, really you are only saving the front driveshaft from wear.
165k miles isn't much for these trucks, if they are taken care of.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 01:03 PM #29
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
It installs in-line between the gas pedal connector and the wiring harness, up under the dash. It could be removed in 2min if you ever needed to. The sprint booster doesn't require you to hard mount the controller, and you can actually disconnect the controller once you've got it set where you want it so you'd really need to be looking to even notice it's there.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 02:05 PM #30
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
I'm a little confused--you do or don't like your 4G AWD? Because that's the same system in the 5G LE.
Toffees is offline   Reply With QuoteReply With Quote
5th , reduction , road , sr5 , t4r
Second generation Tacoma CV axles vs 4th generation 4 runner CV axle mrwinkle13 4th Gen T4Rs 0 10-15-2015 06:02 AM
1st Generation Stereo Information 58rennur4 Classic T4Rs 12 04-21-2015 10:39 PM
All this information! swisstype 4th Gen T4Rs 8 12-31-2007 12:58 PM
2003-Up Toyota 4Runner (4th Generation) Information Thai 4th Gen T4Rs 6 04-28-2006 08:17 PM
Complete Information on 3rd Generation 4Runners Thai 3rd gen T4Rs 9 04-17-2003 01:10 PM
