04-08-2019, 05:07 PM
#166
Real Name: Chad
Real Name: Chad
@ Victory 4x4
Product suggestion: How about a weld-on swing arm that only cuts a hole in the stock rear bumper? Something like this:
my custom tire/fuel carrier build using stock bumper
2016 TE - 2.5 Icon Stage 2 Ext Coilovers, Icon 2.0 Remote Res rear shocks - RCI sliders & skids - Custom front LED in-grill mount - Rigid - General ATX 275/70 - SCS Wheels, Terrapod RTTx, Raingler, Baja Designs, Rhino Rack.
04-09-2019, 10:23 AM
#167
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Originally Posted by Terrapod
Thanks for the suggestion! I'll pass this along.
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
04-09-2019, 10:28 AM
#168
Real Name: Chad
Real Name: Chad
FYI - I have a design that I believe will work great if interested. PM me.
C
04-09-2019, 10:32 AM
#169
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Roof Rack Prototyping
Roof rack prototyping is underway!
There will be a no-drill, full & 3/4 rack option in the near future.
@victoryrunner
04-09-2019, 10:59 AM
#170
I would second this for sure.
How to make some improvements:
Use some type of universal mount flange that sits as flush as possible to the bumper cover. It flexes so of course there needs to be some clearance where you cut through the bumper cover. But it would be great to have the option to bolt on the swing out assembly or unbolt and bolt other fixtures into the same spot. Thinks like a nice swing out for bicycles, or whatever else you wish to carry back there, or just to remove it for daily driving.
I'm more of a function over form guy. So in the interest of keeping weight down and utility high - put the tire down and on the side where the visibility is least impacted and the shortest arm can be used. That would keep the hinge forces lower and allow for lighter weight assembly. I don't think there is anywhere in the USA where you'd want double spare tires like you would in Africa or Australia, but the way Kaymar does it is the best I've seen.
Personally I wouldn't move my spare out of the OEM location. However I would like to have a swing out carrier for other stuff like fuel.
04-10-2019, 12:43 PM
#171
Just the other day I found myself wondering if you were going to make a roof rack.
Any options for integrating a slim light bar that won't get in the way of any cargo on top?
04-10-2019, 02:31 PM
#172
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Yes, the front fairing will be available with or without a light bar cutout.
@victoryrunner
04-10-2019, 02:39 PM
#173
Will there be a final seal between the rack and the roof to cut down on noise? How wide are the crossbars? I assume the mounting brackets are steal vs bent aluminum like your competitors? I can't wait to see the final design.
I don't currently own a 4runner, as i'm waiting to see the new 2020's to come out before I pull the trigger. I've been creeping around the forums to get ideas of mods and accessories.
I'm thinking my 4runner is going to be a Victory 4x4 poster, molle racks, sliders, bumper, and now this rack.
04-10-2019, 02:46 PM
#174
hmmm....once that roof rack is done I might just need to buy everything you make for a 4Runner at once.
2016 TRD Pro: C4 Rock Sliders | Victory 4x4 Roof Rack | Ellis Precision Shifters | Blackvue 650s 2 CH | Full Front Clearbra | 20% Tint | Beavertail | Borla S-Type | Pedal Commander | Tail as Turn | DRL LED Foglights | ArcLight Triple State Voltage Booster | Victory 4x4 Front Winch Bumper | Victory 4x4 Front Skid | TRD CAI | SCS Stealth 6 | Dobinsons Lift & UCA | Warn Zeon 10s | Northstar 31m | Factor55 Flat Link | ARCLightLED Hatch/Map/Dome Lights | Lock'er Down Console Safe | XD Door Light / License Plate Bulbs
04-10-2019, 02:47 PM
#175
Also, I am looking for something that adds minimal height...that looks pretty low, any guesstimation how much height it may add over the stock roof rail things?
04-10-2019, 05:36 PM
#176
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
The front and rear fairings will be adjustable so you could add some edge trim and press it all the way against the roof if you'd like. The whole rack will be aluminum but the mounts will be steel. The rails will be 2" wide extruded aluminum.
Look forward to seeing your 4Runner!
@victoryrunner
04-10-2019, 05:47 PM
#177
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Maybe 1-1.5"? I'll check when we install the final.
@victoryrunner
04-10-2019, 11:22 PM
#178
Real Name: Eddie
Real Name: Eddie
will you guys be making ladders by any chance?
Thanks
As Is: 2014 SR5 Premium. Replace 3rd Row with DIY drawer. Front SPC UCAs + Icon LT + Coils. Rear Daystar @1.5 + Icons. ARB Springs. 285/70-17 Duratracs. Antman tailgate Mod. AVS Bug Shield. V1 radar detector. Front Runner rack. AlphaFoxTrot ladder. 32" auxbeam in lower grille. Rago ditch brackets. 2 x Auxbeams pods in ditch and 2 rear facing. ARB2000 + Room. AVID Offroad Sliders. Midland MXt275. Iceco JP50 fridge + Slide.
Maybe time for a build?
IG: eddiezt4r
04-12-2019, 03:34 PM
#179
Real Name: Christoph
Really love & want to pull the trigger on 3 of those crossbars. Anyone have any link to a good lockable maxtrax or jack/shovel mount that would adapt to these Victory 4x4 crossbars??
Thnx!!
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
04-17-2019, 12:01 PM
#180
Thnx!!
Bump.
Nothing anyone can suggest for these? Maybe more of a RTT type of rack system, or larger items? What are people throwing up there?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
