Old 01-24-2019, 11:34 AM #1
xcalbr2 xcalbr2 is offline
xcalbr2 will become famous soon enough
JBA uca's and 285's question
Who has successfully run 285's on 2.5"+ lift with JBA UCA's?
Looking for successful setups and wheels selected without using spacers.
Factory Trail wheels, 17x7.5", rub with 285 wildpeaks. Rubbed just slightly on the JBA arms only after the fender tuck and mudflap removal.
I know JBA suggests 17x8.5 with 4.30 backspace or a 17x9 with 4.50 backspace but looks like 4.30 backspace will stick out and require quite a bit of modification.
Thanks
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 11:40 AM #2
chon79 chon79 is offline
chon79 is on a distinguished road
I am running JBA UCAs, 2.5" lift on SCS Ray10s and 285 RG's with no rub at all.
chon79 is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 11:47 AM #3
please post wheel size when responding.
Looks like the SCS Ray 10's are 17 X 8.5 4.30" -10mm
Do they stick out much? How much modification was required and do you have any pics? maybe down the side etc.
Thanks
Old 01-24-2019, 11:49 AM #4
Thanks
Pretty flush. slight trimming of front bumper and that was it. Clearance is great.
Old 01-24-2019, 12:46 PM #5
mailbox mailbox is offline
mailbox is on a distinguished road
I was also pondering this as I get ready to start making suspension purchases.
I'm running FN pros so I'm not sure if they'll work well with the jbas. Didnt want to go with SPC because of all the issues with them.
The FN pro wheels have these specs:
Diameter: 17"
Width: 8"
Offset: 0mm
Backspacing: 4.5"
mailbox is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 01:03 PM #6
YellowSnow YellowSnow is offline
Banned
YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough
Banned
5100s/Wheelers T1-T13/JBAs/SCS Ray 10s 17x8.5/Falken Wildpeaks 285/70/17
Had to BMC as I was rubbing on full turn reverse. The point I circled in the picture is where you will get rubbing. I could probably run 295s with this set up, but nothing larger because I will probably rub on the JBA UCAs.
JBA uca's and 285's question-704deded-ec4e-42c5-b3ff-96d6f8720e2c-jpg  JBA uca's and 285's question-659c4c4a-b4da-4615-bab4-55887657cf24-jpg  JBA uca's and 285's question-ca8bc720-5cb1-4969-85f1-38266bd4d4e6-jpg
YellowSnow is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 01:47 PM #7
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Diameter: 17"
Width: 8"
Offset: 0mm
Backspacing: 4.5"
The newer SPCs have not had any issues that I am aware of. There was a recent topic about this. No body chop with my SPCs, 285s, and SCS wheels. All 4Runners are different I hear.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 01-24-2019, 02:26 PM #8
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
wow that looks like about a 1/2" inch of space
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 11:14 AM #9
Ultarnr75 Ultarnr75 is offline
Real Name: Max
Ultarnr75 is on a distinguished road
Real Name: Max
When did you purchase the JBA UCA and are they the 7.0 set?
I ask because i have a similar setup and had issues with my JBAs hitting the coil on my Bilsteins with Toytec 521600 Springs at full drop ( during wheel removal). I have 285 70 17 Wildpeaks, JBA UCA and SCS RAY 10s.
I heard they where going to design a new UCA with a higher caster. I pushed mine in Spring 2019.
Ultarnr75 is offline   Reply With QuoteReply With Quote
285s , backspace , jba , ucas , wheels
Quick question tundra fabtech dirt logic question Diggo 3rd gen T4Rs 3 06-09-2016 02:33 PM
Question about FJ suspension swap (not a common question) cacarbuff 4th Gen T4Rs 2 02-18-2014 10:37 PM
Question about 2013 Limited vs SR5 rim & tire question? duckman06 5th gen T4Rs 21 01-09-2013 07:06 AM
2003 V8 90k Maint. Question + Steering Question zerowkul98 Maintenance/Detailing 1 10-21-2010 07:35 AM
