10-13-2016, 08:15 PM
Real Name: Anibal
Real Name: Anibal
2016 Puddle Light Write up.
I recently upgraded every last light on my truck to cool white LED's all were fairly simple and found write ups for all, except for the puddle light write up or video. So here, it is. It's my first, so bear with me.
STEP 1: Turn mirror inward as far as possible and gently pull off, it will sounds bad but it won't break anything as long as you're gentle. After that, follow these pictures below.
2016 Trail Premium • 3" Toytec Leveling Kit • 1.25" Spider-Trax Spacers • G8 LED Headlight Conv. Kit by (LUMEN) • Fog/DRL 2 in 1 LED Conv. Kit by (LUMEN) • Full LED upgrade including puddle lights • BFG KO2's 285/70/17 • K&N cold air intake system • Flowmaster Delta 40 series •
10-13-2016, 08:17 PM
Real Name: Anibal
Real Name: Anibal
Carefully take back cover off following the step below.
10-13-2016, 08:19 PM
Real Name: Anibal
Real Name: Anibal
Remove screws to begin the removal of the lower cover and light housing assembly.
10-13-2016, 08:20 PM
Real Name: Anibal
Real Name: Anibal
Again, carefully use flat head on these clips to remove lower cover.
10-13-2016, 08:27 PM
Real Name: Anibal
Real Name: Anibal
Once removed, you'll see the light housing.
10-13-2016, 08:28 PM
Real Name: Anibal
Real Name: Anibal
Remove old bulb carefully.
10-13-2016, 08:30 PM
Real Name: Anibal
Real Name: Anibal
Here, you can see the difference in the bulbs. MAKE SURE YOU REALLY PRESS THE NEW BULB IN, I PUT EVERYTHING BACK TOGETHER AND HAD TO RE-DO IT. The connection is very finicky.
10-13-2016, 08:33 PM
Real Name: Anibal
Real Name: Anibal
Here's a picture of the new bulb, and over a street light. So you can still see how bright it is.
10-13-2016, 08:35 PM
Real Name: Anibal
Real Name: Anibal
Make sure you order bulbs capable of dimming. I got these from diodedynamics.com
10-13-2016, 08:37 PM
Real Name: Anibal
Real Name: Anibal
Here are the rest of the inside LED's which I ordered from carid.com.
10-13-2016, 08:39 PM
Real Name: Anibal
Real Name: Anibal
These are also dimmable, and I ordered from carid.com
10-13-2016, 08:41 PM
Real Name: Anibal
Real Name: Anibal
All four doors, swapped.
10-13-2016, 08:43 PM
Real Name: Anibal
Real Name: Anibal
The vanity lights are stupid crazy bright, and I got those at carid.com as well.
10-13-2016, 08:45 PM
Real Name: Anibal
Real Name: Anibal
Stock vs. Led license plate bulbs.
10-14-2016, 12:06 AM
Real Name: Gus
Real Name: Gus
Very nice write-up. Well illustrated. Gonna have to get some bulbs and finish the lights.
Thanks!
2016 T4R SE Premium, 3" ToyTec Lift, SPC UPC, Baja Rack, Shrockworks Sliders, KO2's, Rigid SAE Fog Lights, Gobi Ladder, ArcLight Map & Hatch LED's, Blueridge Overland Attic, 2m Ham.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
