04-09-2019, 11:12 AM
#16
Awesome. Post pics too!
2019 T4R TRD ORP Silver | BFG KO2s | RSG Sliders | Rago MSP | SSO Roof Rack | Icon Stage 1 | CBI Steel Skid Plates
2005 UZJ100 LC | 200k miles strong
04-09-2019, 01:53 PM
#17
Originally Posted by silverslug
THANKS
@ 57buick
According to the CBI website, the 2 piece set weighs 180 lbs and would probably be worth that weight in gold when you hit a big piece of rock on the trail. I'm just curious how much you'd save with the Aluminum set ...
This is a Typo that we have brought to CBI's attention.
The 180lbs refers to the Steel Skid Plates.
We have also been told that Aluminum is roughly have the weight of steel.
_
04-09-2019, 02:28 PM
#18
ok Aluminum skids just arrived 10 minutes ago. got them unbolted from pallette and used a digital bathroom scale to weigh each piece.
Front Skid= 26.8 pounds
rear skid= 24.4 pounds
rear crossmember and all hardware still wrapped on it= 10.8 pounds
total weight= 62 pounds
2018 TRD Premium, KING suspension, 285/70/17 Duratracs, 4.88 gears, Addicted offroad front Bumper, C4 FAB rear bumper, My build thread https://www.toyota-4runner.org/5th-g...ld-thread.html
04-09-2019, 06:39 PM
#19
Wow, they look great. So, the aluminum set might be only 1/3rd the weight of the steel; this is gonna be a tough decision. GL with the install
@ 57buick
04-09-2019, 09:13 PM
#20
Ok so I just got them installed and this is my experience. These were the aluminum front and rear.
First, man the clearances for the holes are super tight so it took a lot of wrangling to get them all on and bolt holes lined up. Had to use the bolts themsleves and a ratchet to bring everything together.
You definitely need to run a M8x1.25 tap into the bolt hole for rear crossmember because the factory paint in the threads will not allow you to thread in the bolts.
The instructions need to be updated with a few things. I also found that I had to remove the factory braces ant the rear crossmember, that was not in the instructions at all.
Also, I was missing several of the 3/8-16 nuts so I had to run to the hardware store.
You can see in one pic below that my URD Y-pipe just barely clears by 1/4" I think the factory Y-pipe would hit it for sure!
04-09-2019, 09:17 PM
#21
Also I had installed the Baxter Performance oil filter adapter a couple weeks ago so I could use a regular spin on oil filter.
I had to modify the factory skid to clear the filter I used because of the piece sticking up on factory skid I had to hammer that a bit and cut some out.
With the CBI skids it cleared great with 2 inches to spare so that was another plus and seems easy enough to replace filter without removing the skids now.
04-09-2019, 09:21 PM
#22
I had also temporarily mounted my rock camera on the factory skid before so after installing the CBI skids I finally got around to installing the rock camera up in a hole in bottom of bumper which protects the camera better anyway.
the pic of the work blanket under front of vehicle then seeing the front view on the screen gives you an idea how super wide of view this camera is lol
And you can see I painted the front skid with the matching toyota touch up paint, I know its gonna get scratched up but figured better blending in a bit than standing out
04-09-2019, 10:07 PM
#23
One thing I don't understand with how these skids are made is what the purpose of this square area that sticks down from the skid. It is nowhere near sitting under the transfer case. There doesnt seem to be anything around that area once mounted so I don't get why its there?
Hopefully someone at CBI can elaborate on that?
04-09-2019, 10:20 PM
#24
I thought that would be for the exhaust crossmember?
04-09-2019, 10:28 PM
#25
Here is a better view of that area installed, I dont see anything anywhere near it? But now that you say that maybe that was where the stock Y-pipe ran? I don't remember now lol
04-09-2019, 10:37 PM
#26
here is a better view of the clearance for my oil filter now with the CBI skids. I could maybe even get a longer filter for more filtration since I have lots of clearance.
08-17-2019, 06:43 AM
#27
Originally Posted by TotalAutomotiveLV
CBI Skids Plates vary in lead time depending on build.
They will confirm at 5-6 weeks for powder coat, but usually these
ship out in about 2-3 weeks.
CBI does offer Aluminum Skid Plates. Part #T4R5-SKID-FRT-PRO
Our website is being update to included Steel and Aluminum options
_
I'm not seeing the option "Part #T4R5-SKID-FRT-PRO" on your website.
08-17-2019, 03:42 PM
#28
Real Name: Jonathan
Real Name: Jonathan
Just saw this old post. That's to accommodate the stock exhaust crossover.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
10-24-2019, 03:38 PM
#29
CBI Aluminum Skids are Popular Choice!
_
02-18-2020, 03:38 PM
#30
CBI Skids Plates continue to be a popular choice.
Our Fulfillment Team is working hard to update options, Steel and Aluminum,
and the coating choices; Bare, Power Coat and TRD Grey.
We will be splitting up the skid plates available; Front, Rear, Gas, and LCA.
Current Lead Time on Skids Plates - 4-6 weeks
_
