Old 01-25-2019, 07:39 PM #1
blackie2's Avatar
blackie2 blackie2 is offline
blackie2 is on a distinguished road
blackie2's Avatar
Brake pad question, and yes I did a search....
I've got 83,000 miles on my 2016 and recently I noticed a very small squeak on cold braking when I go to work in the morning. Once they warm up no squeaks. Anyway, I got OEM pads and rotors to do the front end. Today I took the front tires off to measure the pads and on both sides the pads averaged about 6.5mm. My question is that enough pad to keep them awhile longer or should I just do the job and replace them? Thanks in advance.
2021 SR5 Premium 4x4 stock, Nitto Terra Grapplers
blackie2 is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 07:44 PM #2
CavPro's Avatar
CavPro CavPro is offline
CavPro has a spectacular aura about CavPro has a spectacular aura about CavPro has a spectacular aura about
CavPro's Avatar
How thick are the new OEM pads? Maybe just clean up and lube the caliper pins if all you had was a little noise.
CavPro is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 07:50 PM #3
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
that's probably around 50%. you could run them for quite a while yet.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 08:10 PM #4
blackie2's Avatar
blackie2's Avatar
The OEM pads are 11mm thick so I'll just clean everything up and wait. Thanks guys.
Old 01-25-2019, 08:13 PM #5
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
The rotors/pads may have glazed over which is giving you some noise. You could resurface the rotors and scuff up the pads and see how that does. You could also rebed the pads/rotors. To rebed:
1. Start with cold brakes.
2. Warm them up gradually with about 4-5 near stops with moderate pressure from about 50mph.
3. Rapidly Perform 6-8 Hard Stops (don't engage ABS) from about 70-10mph (DO NOT come to a complete stop).
4. Drive normally for a few miles to allow brakes to cool down. Avoid coming to a complete stop until brakes have cooled down.
5. Park it for several hours.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
front , pad , pads , question , tires
Lift + sway bar question (don't shoot me I did search for like 30 minutes) PWD4R 3rd gen T4Rs 40 06-22-2016 01:14 PM
Did thread search, still have vibration question Wile.E.Coyote 4th Gen T4Rs 11 03-31-2015 01:24 PM
Not another E-Locker Question!? Yup. Sorry. (I did search, A LOT) Troybylt 3rd gen T4Rs 6 06-23-2014 02:24 PM
Tire Rub Question (Yes, I did a search) RPC 4th Gen T4Rs 7 04-29-2014 10:33 PM
more lift question? already abused search feature. RGPIII 5th gen T4Rs 4 05-04-2012 02:31 PM
