Old 08-07-2019, 10:56 AM #61
r1verf3nix r1verf3nix is offline
r1verf3nix will become famous soon enough
Originally Posted by gibburnz View Post
Hey everyone--
The installation/review article is now live on Trail4Runner.com.
Autoease Electric Powered Liftgate Review & Install for 5th Gen 4Runner
As for the Gobi ladder, you can see in my video in the article that I have it installed with an unfilled Rotopax and it works for me. They don't recommend any additional weight on the tailgate since they probably calibrate the lift speed and pressure based on a tailgate with nothing attached. I took the ladder off and it worked just as smoothly with it on.
I did try to open it driving through a parking lot at slow speeds and it would not open. I'm no expert, but my assumption is that because this kit taps into the lock/unlock wire, while the car is in anything but Park it won't allow you to unlock the gate. I could be wrong there and that may not be the way it works, but it wouldn't open while driving for me.
If you do wind up buying this kit, I highly suggest you refer to my article vs. the instructions included in the kit. I had the hardest time finding the right CANbus wires and where they say "run the wires through the liftgate", that is no simple task and we needed to put the wire fish I had to the test to make it work.
If you get one, hit me up with any install questions you have. I'm not normally the early adopter with this stuff but my girlfriend has the power liftgate on her Evoque and I've wanted one on my 4Runner ever since.
I bought mine last week, arrives tomorrow. Best believe I used that group buy and got the 3 year warranty.
And I will more than certainly be using your writeup and messaging you about the installation. Thanks in advance
r1verf3nix is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 11:05 AM #62
97BlackAckCL's Avatar
Real Name: Chris
97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold
Real Name: Chris
Great writeup, thank you so much for a detailed writeup. Curious if anyone has this system and a remote start system that uses the 3 lock command for the remote starting. The drilling for the button was my biggest question, thank you for covering that in detail
2017 Nautical Blue SR5 Premium - Black Emblem Overlays, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back, Morimoto MLED 2.0 Headlight Retrofit, Morimoto Black LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Smoked CarTrim Miror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, N-Fab Side Steps, BajaRack Full Length Roof Rack, 6xMB Quart Door Speakers, JBL 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, CanvasBack Liners, ScanGauge, Blackvue DR900S Dash Cams
Old 08-07-2019, 12:13 PM #63
I have the factory remote start so I will be a tester for that, but like I believe is covered above the tailgate is opened with 3 presses of the unlock button. The factory remote start is activated with 3 presses of the lock button. Shouldn't interfere with each other.
Old 08-07-2019, 01:00 PM #64
MasonCO MasonCO is offline
MasonCO is on a distinguished road
I am assuming that this lift system, and others like it, will not work if the battery goes dead, is that correct or can you manually lift the tailgate?
I'm going to keep my wife from seeing this post as long as possible, because once she does, I'll have to order one
2016 TEP, Nautical Biue w/ KDSS
MasonCO is offline   Reply With QuoteReply With Quote
Old 08-07-2019, 02:06 PM #65
Real Name: Chris
Real Name: Chris
If the battery is dead the rear hatch opener won't work either
Old 08-07-2019, 02:59 PM #66
Old 08-09-2019, 09:21 AM #67
gibburnz's Avatar
gibburnz gibburnz is offline
Real Name: Ryan
gibburnz has a spectacular aura about gibburnz has a spectacular aura about
gibburnz's Avatar
Real Name: Ryan
3x unlock is what opens the liftgate, so those with the factory remote start should be good. But yeah, no power means the rear liftgate won't unlock. BUT, if you have power and for whatever reason the liftgate struts don't work, you can open the gate with no power and they have the ability to stay open without power. I only know that because you mount everything up during the install before you connect the power.
2011 Trail Edition. Black. '17 Icon Rebounds w/285 KO2's. Rago molle panels. C4 Fabrication lo pro with 25" LED and Smittybilt X20 winch. Rago rock sliders. TRD front skid. Spidertrax spacers. Gobi ladder. Yakima SkyRise RTT. ARB Safari snorkel. 14+ tails. Blacked out projector/retro-fit head lights. Baja Designs pro fogs. Dobinsons 2.5" lift w/ ICON delta joint UCA's.
gibburnz is offline   Reply With QuoteReply With Quote
Old 08-09-2019, 09:47 AM #68
My kit arrived yesterday and during my inspection I have already come across a couple changes from Gibburnz installation writeup.
The group buy kits changed the CANBUS wiring from Yellow/White to Red/Black. After speaking with the main contact through WhatsApp he confirmed the color swap.
Original White (CANBUS H) swaps to new Black wire
Original Yellow (CANBUS L) swaps to new Red wire
Hope that helps for any within the group buy.
Old 08-09-2019, 09:51 AM #69
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
Wow, good to know. I'm going to see if I can edit the article with that update. Thanks brother!
Old 08-09-2019, 03:19 PM #70
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
Install article updated - thanks @r1verf3nix !
Old 08-11-2019, 02:44 PM #71
@gibburnz Here's one for you, I was laying out the wiring and connecting everything to make sure I understood the layout.
I can't figure out where the white male connector that's on the lock wire goes. The connector right next to the purple wire tap that goes to the rear control box. Picture below.
Old 08-12-2019, 08:45 AM #72
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
If memory serves me correctly, you ignore that connector. I found this picture in my e-mails. I haven't installed the foot sensor yet, so I wonder if it has something to do with that, but I believe one of the connections on the control box is for the foot sensor.
Aftermarket power lift gate finally available-wires-jpg
Old 08-12-2019, 12:08 PM #73
Attachment 341383
That's what is looks like to me, a dead connector but why it is included is beyond me.
The connection point for the foot sensor is on the control box next to the lock assembly connector.
Old 08-12-2019, 12:11 PM #74
gibburnz's Avatar
Real Name: Ryan
gibburnz's Avatar
Real Name: Ryan
Yeah, weird they included it but I believe the control box is a newer model, so that wiring bundle could be from the previous control box. Also, I think a lot of those parts are universal for other makes and models, so it could tap into another harness on another vehicle but for the 4R, it's not used. #ShoulderShrug
Old 08-16-2019, 06:42 PM #75
Techflyer Techflyer is offline
Techflyer is on a distinguished road
I ordered the kit on Sunday and it was delivered on Thursday. Not bad.
I just unpacked everything and all of the parts and bits arrived in great condition. The packaging was great. They even included a drill bit for mounting the rear switch.
However my kit (V3) did not include the screws for the brackets or any manual or reference on connecting the foot kick switch.
The foot kick switch I received has a couple of extension cables with mating connectors and the last one only has separate wires that have the insulation prepped for removal with no connectors to interface with the control box.
I sent an email to Autoease, let's see what they have to say.
Update: Tao with Autoease emailed back very quickly.
The newer kits use the existing screws for the new brackets.
As for the loose wires on the foot kick switch: The red ACC wire is not used, the green KEY wire gets connected to the grey wire at the existing control box (Step #8), the ground and BAT wires get connected appropriately. (Tao suggested that they could be connected at the liftgate control box).
Techflyer is offline   Reply With QuoteReply With Quote
aftermarket , finally , gate , lift , power
Power Lift Gate? starbai 5th gen T4Rs 36 12-07-2018 12:38 PM
No power to rear lift gate Native 5th gen T4Rs 16 02-04-2014 10:02 AM
Non power lift gate -> power liftgate.. anyone? czastrow 4th Gen T4Rs 1 07-14-2011 09:35 PM
Power Lift Gate 5th gen SR5 CApilot78 5th gen T4Rs 1 12-13-2010 09:21 PM
Aftermarket or Add-on Auto Lift Gate feature for 4th Gen? zuhl 4th Gen T4Rs 1 01-04-2009 10:33 PM
