01-30-2019, 01:49 PM
#61
Banned
Banned
Originally Posted by Jesse1983
what is a stage 2 trail?
Stage 2 suspension bro....coils, springs, shocks, UCAs
01-30-2019, 01:56 PM
#62
5th Gen Moderator
5th Gen Moderator
oh, never heard of 5100's and JBA's being referred to as "stage 2"
Originally Posted by 7harper
First 5th with real CO's
2017 White TRD OR, Icons, BFG Mud-Terrains, Konig Countersteer, Retro Headlights, Gobi stuff
01-30-2019, 02:31 PM
#63
Real Name: Max
Real Name: Max
01-30-2019, 05:19 PM
#64
Banned
Banned
You don’t get out much..
Stage 1: shocks/springs/coils
Stage 2: shocks/springs/coils/uca’s
Stage 3: shocks/springs/coils/uca’s/trailing arm
Complete Suspension Systems - ICON Vehicle Dynamics
01-30-2019, 05:23 PM
#65
Banned
Banned
Originally Posted by MTN4RNR
01-30-2019, 08:31 PM
#66
Originally Posted by nb rob
the ground clearance difference has been disproven lots of times on here. Go measure it.
The stock pro skidplate will fit on the trail / OR if it is notched. How is that possible if it takes up an entire extra inch?
the cutoff is 12mph. which equals 20kmph everywhere else in the world
You do have to remove these J shaped bars in order to get the pro skid plate on a KDSS trail. They simply hang too low to allow the skid plate to mate up to the bolt holes. I’m not sure what the purposes of the bars are, but the Pro skid plate is not a one for one swap. The J shaped bars on the SR5/Pro/non-KDSS vehicles stay in place on with the Pro skid plate.
2023 4Runner TRD Pro, 2023 GR Corolla
01-30-2019, 08:47 PM
#67
Originally Posted by Offwidth
Nonsense. KDSS does not make anything worse for actual off-roading. .
So for you driving dirt roads and easy trails above 15 mph is not actual offroading? Here is some news:
1/ that is where most of the time is spent whether you like it or not.
2/the bigger the sway bar, the better the performance and the worse the comfort.
3/ comfort matters to most folks and is extremely important to those who offroad with kids.
What in my post made you think I had not measured it?
Brand new vehicles on dealer's lot:
Regular TRD and SR5: 9.6 to front of the front skid plate where the edge is.
TRD with KDSS 1" less to the same spot.
Take a look at the design of aftermarket plates also. There is a reason the front of the engine skid is very different. The more it protrudes, the worse as that front edge is where most hits happen.
No, the lost 1" is no end of the world, but it is an annoyance that has to be dealt with. The front edge of the engine skid is the area that takes the most regular beating though not the one that takes the big hits (that would be the rear pax side LCA bracket skid), mistakes at speed excluded.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
01-30-2019, 09:01 PM
#68
I have so much to learn (seriously). I've come from lowering vehicles, not raising them. There's a thread on lifting 4Rs with KDSS, looks like I'm going to need to spend some time in there.
Finally got the Pro eibach suspension shipped to me, now to figure out how to get it raised 2" over where I'm currently at, and not have the KDSS lean.
2018 ORP, 2001 S4 Tial605, 2001 Maxima, 2013 GS350
01-30-2019, 11:24 PM
#69
"Unless you are driving buggies on extreme trails, most time offroad is spent on dirt roads and easy trails at speeds above 15 mph, whether one likes it or not."
I suppose that's how you spend your time. I wouldn't know. I only see 4Runners offroad on the East Coast beaches, mostly the Outer Banks or Eastern Shore/Delmarva or maybe Jersey. Lots and lots of very deep soft sand and coquina sand.
I do drive some dirt roads to get to a couple of lakes and ponds, but that's only when I'm pulling my boat and there aren't any ramps when I get to the muddy banks.
2023 TRD ORP w/KDSS. Red again.
This is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
01-31-2019, 12:01 AM
#70
Fair enough! I am talking about the West, true.
You had a GL for a long time! That's awesome.
In the West most time is indeed spent on dirt roads and easy trails. That's how one usually gets to interesting places as well as to the moderate and difficult trails.
There are exceptions for people interested in extreme stuff (lots of these around Phoenix, Lake Havasu, Moab, some places in CO) where you can get to that kind of trails with minimum dirt road and easy trails between the pavement and those. But if one is into exploring, then easy and dirt road mileage dominates. And most of the mileage on moderate and many difficult trails is also easy. Trails are rated by their hardest spot and few non-extreme trails are consistently difficult. Even around Moab, there are dozens of dirt roads and easy trails in addition to the moderate, difficult, and extreme ones. In addition, a 5th gen is not really for extreme stuff though with enough mods, desire, and damage tolerance everything is possible.
Back to the topic, my point is that each trim so far (before 2019 Pro) has offered a different kind of compromise. I am not arguing that KDSS is a bad choice but that it is not the best for everyone. So the point is to choose the best for one's particular wants.
01-31-2019, 05:10 AM
#71
Who says I’m running oem suspension....
What you're clearly running is your mouth.
2017 PRO (ICON-NFAB-GOBI-SCS-FALKEN-HWMS-WARN-SPOD-RAGO-BD-ARB-NORTHSTAR-BANDI-VIAIR-FACTOR 55)
01-31-2019, 09:30 AM
#72
Wow. This sure turned into a "TRD PRO vs Everyone else" thread really quick
'17 T4R TRD OR Premium w/KDSS. Icon Stage 7,Nitro 4.88 Gears, Volk TE-37 XT-M SPec wheels, Toyo Open Country RT Trail 35/12.50/17 Tires, RCI Aluminum Skids, CBI Front/Rear Bumpers, Alu-Cab load bars, Alu-Cab 3.1 Roof Top Tent, OEM Audio Plus Reference 450Q, Baja designs S8 30", Baja Designs Squadron Pros, Baja Designs Squadron Sports (Rear bumper), Baja Designs LP6 (Roof)
IG: @Expo_T4R
01-31-2019, 03:16 PM
#73
5th Gen Moderator
5th Gen Moderator
I've heard of ICON stages, but you don't have ICON components.
01-31-2019, 03:51 PM
#74
Banned
Banned
Ok, i will do my best to explain one last time since you seem incapable of comprehension. In the tuner market, upgrades to cars were broken down into stages. For instance: stage one would be bolt-ons, cold air intake, exhaust. Stage 2 would add an ecu tune. Stage 3 would be a larger turbo, fuel injectors, etc. if you still cannot understand and comprehend what the different stages of suspension upgrades are, then I don’t know what else to tell you....maybe turn on Nickelodean, drink a juice box and flick your boogers at the wall.
01-31-2019, 04:22 PM
#75
Real Name: Mark
Real Name: Mark
I see you changed the last words of your post from SR5 to the wall.You are a stage 5 Jerk off!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
