Old 06-14-2019, 05:38 PM #76
FamousAv8er's Avatar
FamousAv8er FamousAv8er is offline
FamousAv8er is on a distinguished road
2017 just rolled 60k from April '17
Daily Driven '17 T-Force T4R - Baja Flat Rack - 5100s
odo: 80,000
FamousAv8er is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 06:29 AM #77
cougar428's Avatar
cougar428 cougar428 is offline
cougar428 is on a distinguished road
cougar428's Avatar
2014 sr5 with 146k miles. Only major issue was ac crapping out on me due to bad evap core. Other than that no issues.
cougar428 is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 10:58 AM #78
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Interesting. I feel like my AC is getting quite weak as I near 130k here. Charged it last summer and it held out but just barely. What did that repair run you - just curious in case mine is a similar story.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 11:34 AM #79
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
180K on a September 2014 SR5.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 12:45 PM #80
cougar428's Avatar
cougar428's Avatar
My friend did it for me so parts and labor was about $700. I know local shops will charge anywhere from $1300-$1500 and the dealer is about $2400. Hopefully your problem isn’t the evaporator core because that requires the dash to come out. That’s why it’s so expensive
Old 06-16-2019, 01:22 PM #81
Yikes. Yeah I know it's a big deal. Good to know the dealer cost is insane. Will probably get the AC "serviced" by a shop and see what they think. Still blows cold as of today, not as cold as I'd like though.
Old 09-29-2019, 02:09 PM #82
ashepherd ashepherd is offline
ashepherd is on a distinguished road
May it run forever
I just hit 281,000 on my 2010 Gen 5. Only issue was front wheel bearing at 90k. Just tires, shocks, brakes and synthetic oil...as soon as the Gen 6 arrives I will pass to my college age son.
Even now not a 2nd guess to take on 1000mi road trips or deep into the Calif hills.
ashepherd is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 12:35 AM #83
Goyo Goyo is offline
Goyo is on a distinguished road
Two years later.... Who's at 500k miles ?
Goyo is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 03:09 AM #84
SpaceBanana's Avatar
SpaceBanana SpaceBanana is offline
SpaceBanana is on a distinguished road
2020 w/ 47k miles
2020 4runner ORP
SpaceBanana is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 09:36 AM #85
Snowtrooper Snowtrooper is offline
Snowtrooper will become famous soon enough Snowtrooper will become famous soon enough
You might have the highest mileage 5th gen on this thread?
I wish we had a sticky, or the OP would edit his or her original post so we could have a standing list.
Let us know when you get to 300k so we can celebrate with you.
Snowtrooper is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 11:34 AM #86
zippinbye zippinbye is offline
Real Name: Rich
zippinbye is on a distinguished road
Real Name: Rich
2005 GX470 with 173,000; alternator failure at maybe 80,000 (no small job with KDSS), air bags at 150,000/14 years old, A/C refrigerant service once (tightened HP line fitting, never an issue since). Changed a couple of o2 sensors after receiving failure codes/unable to smog. Both cats indicated failure at different times; local indy shop performed a chemical wash that restored operation. As you may know, these cats are attached to the exhaust manifolds. Replacement options are OEM ($2000+ a piece if I recall), or a talented welder and a generic cat, plus a bunch of R&R labor. For a while, there was one aftermarket cat/manifold assembly available for just under $1000. I bought one and returned it after the wash was a success. I mention this detail in case anybody else experiences cat failure on any vehicle; try a wash! It was about $150 with zero guarantee, just a Hail Mary that worked. Both have been holding for over five years.
Otherwise, just scheduled maintenance, tires and brakes. "Permanent" ATF changed. Bought new spark plugs with thought of changing them around 100,000; pulled one and it looked like new. Still running original plugs for now. Original shocks seem far better than they should (no indication of leak or failure), but thinking about suspension mods that would eliminate electronic ride control and air bags.
zippinbye is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 11:41 AM #87
TacoRunn0517's Avatar
TacoRunn0517 TacoRunn0517 is offline
TacoRunn0517 will become famous soon enough
Originally Posted by TacoRunn0517 View Post
Bought my 2016 Trail "new" 5/27/2017 (Memorial Day Weekend) with 125 miles on the ODO. I'll be taking it in this weekend for the Takata recall and 60K-Mile Servicing. I'll have "high-mileage" Runner by the 2 Year mark hahaha.
Random update haha. Just did my 115K Mile Routine servicing. With my first "major" issue on hand. Apparently the water pump is leaking. Other than that, just oil, brakes and tires.
2016 Toyota 4Runner Trail Edition - Magnetic Gray Metallic - 4x4 *** Trailfinder AT 265/70-178 *** 3M Obsidian Tint (30%) *** LASFIT LA Plus Series H11 H9 H8 LED Bulbs *** XenonDepot Xtreme LED Pro 9005/HB3 Bulbs (w/ DRL Driver) *** LASFIT LD Plus Switchback H8 H11 H16 LED Fog Light ***
TacoRunn0517 is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 04:43 PM #88
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Just about to hit 148k miles on our 2014 TE. Picked it up with 1 mile on it new in July of 2014. It’s been a great rig so far. It’s needed a battery, a new stereo, camshaft connector/pigtail (my fault) and replaced the brakes at 130k. Wouldn’t hesitate to take it anywhere. Here it is on Elwood Pass from last week;
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 11-24-2021, 11:15 AM #89
Blackwatch's Avatar
Blackwatch Blackwatch is offline
Blackwatch has a spectacular aura about Blackwatch has a spectacular aura about
Blackwatch's Avatar
Not sure if this is the definitive thread on high mileage 5th gens but what's the highest anyone has seen on this 4.0 without replacement or rebuilds?
My local dealer had a tradesman visit their dealership to do some work and he was driving a 4runner with over one million kms on it (about 620,000 miles), original engine and transmission. The salesperson didn't know what year but said an older one.
There must be some 400,000-500,000 miles 5th gens on here?
Blackwatch is offline   Reply With QuoteReply With Quote
Old 11-25-2021, 08:01 AM #90
TRD Toy TRD Toy is offline
TRD Toy is on a distinguished road
I got about 30,200 on my 2020 4R ORP.
TRD Toy is offline   Reply With QuoteReply With Quote
drives , mileage , ran , road , winderin
Highest Mileage 4th Gen? T?@\7 4th Gen T4Rs 1558 03-28-2024 01:48 PM
highest mileage on a v8 DTOM_plz 4th Gen T4Rs 7 03-25-2018 12:04 PM
Who Has the Highest Mileage? MikesToy 4th Gen T4Rs 17 09-22-2008 10:04 AM
Highest mileage on '98 4R?? Idaho Doug 3rd gen T4Rs 15 02-18-2005 03:21 PM
