Old 01-27-2019, 08:36 PM #16
MrGainzz's Avatar
MrGainzz MrGainzz is offline
MrGainzz will become famous soon enough MrGainzz will become famous soon enough
MrGainzz's Avatar
undercoating rustproofing
Just take it to a car wash and wash the underneath once a week.
Nothing beats continual and frequent rinse when it comes to road salt.
You will be amazed at what rinse would do to prevent rust if you plan to keep the truck down the road. Plus ,it’s a good leg workout.
MrGainzz is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 09:05 PM #17
Big_Cuss Big_Cuss is offline
Big_Cuss will become famous soon enough
I like fluid film, because there's a lot to be said for a product that both extends protection over an already durable vehicle, but soothes our OCD in a way that's environmentally friendly.
Half of these other products do nothing, and are really freaking toxic for the environment.
Big_Cuss is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 09:17 PM #18
TRDBlue TRDBlue is offline
TRDBlue is on a distinguished road
The main reason Fluid Film is ideal is the exact same reason some folks here are against it. It doesn't create a hard seal, its Fluid, soaks into the metal, gets into every small space under the frame, inside the body, inside doors, inside engine bay, even on hinges and latches. Hard seals eventually form cracks and water gets into those spaces between the seal and the metal and rust starts underneith. Think about it, why would you want a waxy coating water can get trapped under and rust?! So, literally soak your 4Runner in Fluid Film and it will keep on protecting in those hard to reach places, often where rust starts. And it doesn't wash off those places either because there is no frequent contract with water. For the places that there is contact with water, like I stated before just generously reapply once or twice a year and occasionally lightly hand spray wash the bottom. Very easy...
TRDBlue is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 11:19 PM #19
t6pilot t6pilot is offline
t6pilot is on a distinguished road
Eastwood Tools makes several different types of anti rust products and applicators, I’ve used there products on several trucks(inside panels) applies easily with appropriate gun.
t6pilot is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 12:06 AM #20
4x4orbust 4x4orbust is offline
4x4orbust is on a distinguished road
So I have rust inside my frame, it's flaking, but I've been throughout the whole frame with a ball peen hammer and haven't found any soft spots yet. What can I use to spray inside the frame to Stop or slow down the rust? I'm thinking motor or bar chain oil because I can't prep the inside at all other than with high pressure air or water. Any advice is appreciated.
4x4orbust is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 12:24 AM #21
Fluid Film
Old 01-28-2019, 01:08 AM #22
zephyr424 zephyr424 is offline
zephyr424 is on a distinguished road
Corrosion Free is (according to a rigorous test evaluated by the Canadian military) the best rust proofing and prevention system. Go to their site and read the document. Also comes in buckets to spray with a spray gun and is starting to expand to local garages around the us
zephyr424 is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 08:49 AM #23
Originally Posted by TRDBlue View Post
Fluid Film
Will that soak into the rust or just sit on top of it?
Old 01-28-2019, 11:45 AM #24
It soaks into the rust and completely stops any further corrosion, yes. You can actually see it reacting with rust by bubbling and foaming when it makes contact.
Old 01-28-2019, 11:58 AM #25
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
be careful with what you put on there. Lots of oils will react with rubber and plastics. Fluid film is relatively safe, but still be cautious. While it says it is lanolin based, there is also a note about it containing petroleum distillates. Proper, careful application is key.
My initial undercoating (krown) warped my OEM fender flares VERY badly. They pulled away from the body. The 'L' shaped profile was no longer L shaped. I taped and re-taped them with 3M VHB tape, but in the end they were too warped to do anything with. I wound up putting bushwacker fender flares on, because it was cheaper than replacing the OEM flares with new paint. hindsight, I wish I had just replaced the OEM fender flares.
I use fluid film for touchups in the fall and I clean everything up with small amounts of rust paint in the spring. Continuous maintenance can keep the undercarriage rust-free. Don't go apeshit with oil in one large application, or you're going to get acquainted with all the door seals and rubber grommets under your vehicle that you never wanted to know about.
I visit the wash bays very often in the wintertime. The fluid film doesn't wash away easily. Get down there and spray that salt away as often as you can.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 12:05 PM #26
nb rob's Avatar
nb rob's Avatar
here's a picture of the original tape peeling away with a warped fender flare,
And then a picture of 3M's very high bond tape (used with the proper cleaning and 3M primer) peeling away.
plastics and oil do not mix! The Krown guy did a proper application on the fenders (this is where body rust is going to start) - but in the end, I wound up screwing around with these MF fender flares for months on end before I got the bushwackers. Learn from my mistake.
undercoating rustproofing-flare2-jpg  undercoating rustproofing-flare-1-jpg
Old 01-28-2019, 12:48 PM #27
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
After doing my research, and having been a previous Rust Check customer on my old Celicas, I decided to go with Corrosion Free rustproofing on my 2011 4Runner (that I bought used in May 2016).
Corrosion Free HEAD OFFICE Contact us to Order
Why Corrosion Free Rustproofing
Corrosion Free Rustproofing Application Video
I had the underbody "U" package that treats the frame, gas tank, fuel and brake lines, parking brake cables, and wheel wells.
It is a no-drip, eco-friendly application.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 07:56 PM #28
JerseyDevil5's Avatar
JerseyDevil5 JerseyDevil5 is offline
Real Name: 2018 Blizzard Pearl Limited, 2.5”/1.5” Daystar Lift, SPC UCA’s, K&N CAI, Magnaflow
JerseyDevil5 is on a distinguished road
Man, that sucks. Sorry to hear and see that. I can’t imagine how much it would be for the oem painted fender flares. I had the dealer undercoat and rustproof my 4Runner before I picked it up. It was brand new. I heard mixed reviews about having this done, but they offered a lifetime warranty with it. I’m sure there’s some fine print when it comes to “lifetime” warranty!
2018 Blizzard Pearl Limited, 2.5”/1.5” Daystar Lift, SPC UCA’s, 17”x8.5” Method Wheels, 285/70R17 Cooper Discoverer AT3’s, Magnaflow Cat-Back Exhaust.
JerseyDevil5 is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 07:59 PM #29
I’ve never used it, but read about Eastwood Internal Frame Rust Encapsulator. I guess it comes with a tube that you attach to the can and spray it inside your frame. It comes in black or green. It sounds like it might help you out, but I have no experience with it.
Old 01-28-2019, 08:03 PM #30
Matt_in_MI Matt_in_MI is offline
Matt_in_MI is on a distinguished road
Has anyone ever used corroseal and then frame paint to attack a frame that's already starting to rust? Everything i've read about it seems to be good.
Matt_in_MI is offline   Reply With QuoteReply With Quote
diy , oil , rubber , sort , sprayed
Rustproofing/Undercoating pag04 Maintenance/Detailing 16 03-17-2021 07:30 PM
Is rustproofing worth it? sherryKangz 5th gen T4Rs 49 09-15-2017 06:57 PM
Rustproofing/Undercoating-opinion scarface 4th Gen T4Rs 16 10-02-2014 06:24 PM
Rustproofing Axis 4th Gen T4Rs 6 03-04-2010 06:37 PM
Oil spray rustproofing skiwindjunkie 4th Gen T4Rs 0 01-11-2008 05:13 PM
