Old 01-27-2019, 03:55 PM #1
rasber3140's Avatar
rasber3140 rasber3140 is offline
rasber3140 is on a distinguished road
rasber3140's Avatar
SR5 vs TRD Pro Rim Specs
Does anyone know the specs (width, offset, etc.) on SR5 rims and TRD Pro rims?
Thanks in advance
2019 4Runner SR5 Premium
2018 Tacoma TRD Off Road
2017 4Runner TRD Pro - SOLD
2003 Tacoma SR5 - SOLD
1999 4Runner Limited - SOLD
rasber3140 is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 04:46 PM #2
Matt_in_MI Matt_in_MI is offline
Matt_in_MI is on a distinguished road
I'm also curious what others have experienced going with TRD Pro wheels on an SR5. I'm wanting to put TRD Pro wheels with 275/70r17 Falken Wildpeaks on my stock 2011.
Matt_in_MI is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 05:28 PM #3
[email protected] Evan@B.I.B is offline
Evan@B.I.B has a spectacular aura about Evan@B.I.B has a spectacular aura about
Going Bigger - 5th Gen Tire Fitment Guide
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
Evan@B.I.B is offline   Reply With QuoteReply With Quote
Old 01-27-2019, 11:31 PM #4
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
They are both 17x7
The SR5 are +15mm
The TRD Pro are +4
So the TRD Pro are going to stick out 11mm further from the hub compared to SR5 wheels.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 08:34 AM #5
mnofpeace's Avatar
mnofpeace mnofpeace is offline
Real Name: Patrick
mnofpeace has a spectacular aura about mnofpeace has a spectacular aura about
mnofpeace's Avatar
Real Name: Patrick
So...flame me if necessary, but does that mean its a straight one to one swap...or do you need spacers and other things to go from SR5'ers to TRD'ers??
that is my first change out when i pay this bad boy off...TRD Pros or TRD ORs
Patrick L
Ft. Washington, Md.
2014 SR5 w/ 3rd row
My TRD-Pro-Lite
mnofpeace is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 10:14 AM #6
SCMountaineer's Avatar
SCMountaineer SCMountaineer is offline
SCMountaineer is on a distinguished road
Someone will correct me if I am wrong, but I had my sr5 rims swapped out to the TRD ones last month, and I'm almost certain it was a direct swap.
2020 SR5 Premium 4WD in Magnetic Gray
(former) 2018 SR5 Premium 4WD in Classic Silver
SCMountaineer is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 10:42 AM #7
dade73 dade73 is offline
dade73 will become famous soon enough
I did a direct swap before I even took delivery of mine. No issues
SR5 vs TRD Pro Rim Specs-tmp-cam-6101816995771380156-jpg
Humankind cannot gain anything without first giving something in return. To obtain, something of equal value must be lost.
dade73 is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 11:27 AM #8
pDubs's Avatar
pDubs's Avatar
The bolt pattern is the exact same, and the center bore is the exact same. It is a direct swap, and you can use the OEM lug nuts as well.
2014 SR5P
Old 06-17-2019, 12:19 PM #9
four10Glen four10Glen is offline
four10Glen is on a distinguished road
Just bought my 2019 4Runner SR5. Looking to purchase the TRD pro rims. so it is safe to swap directly?
four10Glen is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 12:20 PM #10
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
Its the same truck.
Offset difference is 11mm, or .43" or about 7/16"...which means the TRD wheel will stick out 7/16" farther than the stock SR5 wheel, or move away from the shock 7/16".
In other words, yes it is a direct swap and the offset difference is minimal.
GripT4R is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 02:45 PM #11
Ivan4R Ivan4R is offline
Ivan4R is on a distinguished road
Offset does more than push the tire out.
I am considering swapping 2019 stock SR5 wheels for the TRDs. Because the offset is different, it's not a perfectly equal swap. The lesser offset on the TRDs does "push" the wheel further outward from the wheel well by a little less than half an inch. But it does more than that, because decreased offset also means increased scrub radius, which means that the tire will have a larger arc of movement through its max steer angles (especially the outer corners of the tread). For those minority reports of people who have gotten rubbing after making such a swap, I wonder if this is the problem.
Has anyone had a confirmed case of tire rubbing with 265/70/17 tires on the TRD wheels? If so, which tires?
Also, has anyone had a confirmed case of non-rubbing with 275/70/17 tires on TRD wheels? How about non-rubbing with 275 tires on the stock wheels?
Ivan4R is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 04:31 PM #12
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
I can help with this one. I have a 19 SRS Prem 2wd, off the dealer lot stock wheels & tires.
Day 5, back to the dealer for TRD wheel swap, stock tires. No rub
Shortly after, swapped for TRD Pro suspension with Toytec spacer on front only, lift =+2"(ish), basically level.
A cple weeks later, TRD wheels and tire upgrade to BFG KO2/275/70/17. Very minor rub on the front side of the fender liner both left and right. Easy fix, unbolt it, push forward, rebolt. Grind off about 1" of plastic for clearance. No more rub.
Hope that helps alittle.
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 06:50 PM #13
HWNRUNNER, thanks, very helpful. I might also go 275. When you say grind off some plastic, do you mean plastic from the same liner that was pushed forward, or plastic from fender/flap?
Old 11-10-2019, 09:08 PM #14
hwnrunner's Avatar
hwnrunner's Avatar
Just a little off the bumper inner lip edge. Its not as bad as it sounds. I applied some tape as a cut guide and used a dremal with a cutting blade, was like butter. Used a grinder to make smooth. Didnt even take off the wheel, just turn in or out to make room. Looks oem, can not tell it didn't come like that.
Old 02-27-2020, 04:23 AM #15
bamma's Avatar
bamma bamma is offline
Location: Stuck in an electric mountain trap in the Pyrenees or Mars, or Spokane WA.
Real Name: Dark Lord Xenu
bamma will become famous soon enough
bamma's Avatar
Bumping an old thread. I put Toyota TRD Pro SEMA wheels on my wife's new 2020 Limited 4Runner with Falken Wildpeak AT3s in P265/70R17 and am getting rubbing in reverse without going full lock.
Removed the mini mud guards from the front wheel wells and I am still getting rubbing. Had these wheels on my wife's 2012 4runner Limited with no rubbing. Not sure what has changed between the 12 and 20 models. Will investigate more and report back. May need the liner mod and/or a trim.
bamma is offline   Reply With QuoteReply With Quote
pro , rimes , specs , sr5 , trd
VSS Specs? danielevioli Classic T4Rs 2 09-25-2017 11:08 PM
Does anyone know the specs on this? scottyperry 4th Gen T4Rs 2 01-22-2014 12:11 PM
Specs on this 4th Gen? dctacoma 4th Gen T4Rs 3 04-01-2013 03:27 PM
OEM Torque Specs SAC-CA-Runner 3rd gen T4Rs 4 03-11-2013 10:07 PM
05 with Nav Specs Thorton Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-27-2005 11:38 AM
