Old 02-27-2020, 10:57 AM #16
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
Originally Posted by bamma View Post
Bumping an old thread. I put Toyota TRD Pro SEMA wheels on my wife's new 2020 Limited 4Runner with Falken Wildpeak AT3s in P265/70R17 and am getting rubbing in reverse without going full lock.
Removed the mini mud guards from the front wheel wells and I am still getting rubbing. Had these wheels on my wife's 2012 4runner Limited with no rubbing. Not sure what has changed between the 12 and 20 models. Will investigate more and report back. May need the liner mod and/or a trim.
Could be any of the following:
1) You could be rubbing the body mount -the bit of metal that was directly behind the front mudguards. You can tell if you rub because wherever the body mount is rubbing will be rubbed clean versus the unrubbed parts that will still have dirt and debris. Or rub your body mount with chalk and then try to induce rubbing. If any chalk disappears, you know you're rubbing your body mounts. For reference, I'm rubbing my body mount even after removing my front mud flaps. After not washing the rig for a week, I noticed a part of the body mount that was still perfectly clean from being rubbed -the rest was covered in a layer of dirt and dust.
2) You're rubbing your front splash guards -easy fix that takes like 10m to push them forward.
3) You're rubbing a bit of your front bumper along with your front splash guards. If this is the case, consider trimming an inch or so of that lower lip. Nobody will be able to see it so it doesn't have to be perfect if you don't want.
What you could do is get someone to drive your vehicle in reverse in a parking lot while you follow them around giving them directions to see exactly where you're rubbing.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 02:36 PM #17
bamma's Avatar
bamma bamma is offline
Location: Stuck in an electric mountain trap in the Pyrenees or Mars, or Spokane WA.
Real Name: Dark Lord Xenu
bamma will become famous soon enough
bamma's Avatar
Thanks, I've been through this same process many times with other Toyota rigs. I was just surprised that a 265 would rub, especially when I had plenty of clearance on my 2012 Limited with these same wheels and tires that I swapped to the 2020 Limited, and this is considered a "stock" size for the 4Runner, being only .003" more in diameter (on paper). I know the Pro wheels stick out more to the offset, but that fact they come on the Pro (and countless others have installed with no rubbing on 5th gens, including 275s surprised me a bit. I'll report back this weekend when I have time to diagnose.
bamma is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 04:23 PM #18
I find that really odd as well. I even told my friend with a 2016 LTD that moving to a 17" rim with a 265 tire shouldn't give him any issues as that's what my SR5 came i.e. OEM sizing.
If you figure it out, post back! Be nice to know what to tell my friend to look out for.
Old 02-28-2020, 10:30 AM #19
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
It may have to do with the new front fascia in the 2014+ limited models. I know that when installing the pro wheels at port for the TRD Pros they have to trim the bumper and do the fender liner mod before ever sending it to the dealership, even for the stock size Grapplers that come on it. You could also check the alignment if its on the body mount/mudflaps. Increasing Caster could eliminate that.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 03:55 PM #20
10saints 10saints is offline
10saints is on a distinguished road
SR5 to TRD
So on a 2010 SR5 4wd, the TRD Pro Rims will fit without any spacers, regardless of being 2013+? Sorry, a little new to this.
10saints is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 04:04 PM #21
Thanks! Looks awesome.
Old 02-28-2020, 05:58 PM #22
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
I switched from SR5 to TRD Pro wheels and I have no rub. My caster is 3.2 degrees. You caster might be low so it rubs.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 07:04 PM #23
bamma's Avatar
bamma's Avatar
So it was definitely the front liner, on the driver side only, and just barely rubbing. The liner mod gave the tire a ample amount of clearance.
Greg's mother wishes she had aborted him.
Old 03-03-2020, 10:48 PM #24
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Did you buy oem? some of the knockoff sets are 17x8 with different offset. Should still fit on 265's though
ForRun is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 11:05 PM #25
bamma's Avatar
bamma's Avatar
Yes, they are OEM. Ordered from a Toyota dealer. They barely rubbed with the 265 Falkens on the driver side, and was very close on the passenger side.
Old 03-03-2020, 11:18 PM #26
ForRun's Avatar
ForRun's Avatar
Hmm, not sure than. I had 265 falcon on my stock 19 pro rims with zero rub.
Also have them on my 20 but currently on the trail rims
Old 03-04-2020, 01:24 AM #27
bamma's Avatar
bamma's Avatar
What trim was your 19? Maybe it is a newer Limited issue.
The trail rims don't have as much offset and are less likely to rub.
Old 03-04-2020, 08:53 AM #28
ForRun's Avatar
ForRun's Avatar
19 orp
pro , rimes , specs , sr5 , trd
VSS Specs? danielevioli Classic T4Rs 2 09-25-2017 11:08 PM
Does anyone know the specs on this? scottyperry 4th Gen T4Rs 2 01-22-2014 12:11 PM
Specs on this 4th Gen? dctacoma 4th Gen T4Rs 3 04-01-2013 03:27 PM
OEM Torque Specs SAC-CA-Runner 3rd gen T4Rs 4 03-11-2013 10:07 PM
05 with Nav Specs Thorton Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-27-2005 11:38 AM
