Old 01-27-2019, 10:04 PM #1
listo listo is offline
listo is on a distinguished road
SR5 Door Handle removal
Does anyone know if there is a recent write up for door handle removals? I just got the color matched handles to replace my chrome SR5 ones.
All the pictures are no longer posting on this older thread.
https://www.toyota-4runner.org/5th-g...id-2010-a.html
Thanks
2013 SR5 Magnetic Grey
listo is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 12:46 AM #2
Brown2mu Brown2mu is offline
Brown2mu is on a distinguished road
I’d be interested in this to.
Brown2mu is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 01:11 AM #3
intenseTRD intenseTRD is offline
intenseTRD is on a distinguished road
Never actually removed the handle on my 4Runner, but i have on other cars. Im assuming it’s the same concept.
Open the door of the handle you want to remove.
There should be a black plug on the edge of the door adjacent to the handle.
Remove plug and shine a light to see what screw is in there. The ones i’ve seen are Torx. Back the screw off by hand and not by power tool, careful not to back off too much.
Pull on the exterior door handle and slide towards the rear of the vehicle.
If i have some time at work tomorrow I’ll see if its the same.
intenseTRD is offline   Reply With QuoteReply With Quote
Old 03-05-2019, 10:51 AM #4
QwikKotaTx's Avatar
QwikKotaTx QwikKotaTx is offline
QwikKotaTx is on a distinguished road
QwikKotaTx's Avatar
Thanks, I had the same question. Looks like that is the case. Jump to the 1:00 minute mark in this video to bypass the chuckleheads.
YouTube
QwikKotaTx is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 01:40 PM #5
joiguez joiguez is offline
joiguez is on a distinguished road
You'll have to remove the door panels to get to the yellow tabs that lock/hold the outer door handle in place, that's the most important thing I learned. And check your new door handles to see if the are hollow like the original ones. 😵 Mine were not.
This video shows the rear door better.
YouTube
SR5 Door Handle removal-20200218_123153-jpg
joiguez is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 05:42 PM #6
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
You will need a 30mm Torqx bit
Remove the door panel
These two tabs:
Untitled by redrunner87, on Flickr
This one:
remove these 3 bolts and drop it down
Go in this way to take the 30mm torqx bit out. It is in a captive bracket so you don't have to worry about it falling out
Than you should be able to pull this piece out and the rest of the door handle.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 07:41 PM #7
Firesq14's Avatar
Firesq14 Firesq14 is offline
Firesq14 will become famous soon enough
Firesq14's Avatar
Same?
Is this the same for all four doors?
Firesq14 is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 10:14 PM #8
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
No, the front doors are just a little different. Instead of going into to remove the both bolts from inside of door you do one from edge of door, otherwise they are the same. On the edge of the door you will see a small black grommet. Once you remove that (do not damage it as you will need to replace it), you will see the head of the bolt right there.
I just replaced all 4 door handles on my 2012 and it was very easy. I've had the door panels off many times so I can get them off and back on in a matter of minutes so this job was quick for me.
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 07:40 PM #9
4byte4_Runner's Avatar
4byte4_Runner 4byte4_Runner is offline
Real Name: Captain Awesome
4byte4_Runner is on a distinguished road
Stuck with the keyless 2020.
Ok, been following the threads on this, have the rear door handles out, but am stuck on the drivers. it seems to be hung up on the part circled in red.
Has anyone taken the door handles off of their 2020 with keyless? or any keyless for that matter.
hopefully the attachment shows.
EDIT: Figured it out. Grabbed a sub for TIS and looked up the current specs. There are two latches in the middle of this thing, (just to the left of the green tape) on the top and bottom. release those latches and the green taped part will pivot out toward you. then you put your screwdriver or similar into the slot with the white tab all the way to the left in the circled part. press the tab in toward the right, while pulling on the two black tabs and it will release with the white part attached. if it just pulls the black part, you can release the white part separately and put them back together, like I did with the drivers door. Then flip the yellow thing all the way to the right and pull the handle out like the back ones.
SR5 Door Handle removal-doorinside-jpg  SR5 Door Handle removal-smartkeydoorhandleremoval-png
2020 TRD ORP KDSS that I'm always changing.
Past rigs:
Several 87XJ's - 75 FJ55 - 96 Ranger - 80 Suburban Hiboy - 2011 G37xs
Suzuki Sv1000 drag special.
4byte4_Runner is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 09:02 PM #10
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
You guys are ambitious. I’m too lazy and reluctant to go that route, so, I purchased these off eBay. Looks like it wil match the dash area finish somewhat above the glove box in my Pro, which, I think is the same as the OR & ORP. Not sure about the SR5. I will see if this is worth it in a week.
Black Wood Door Handle Decor Cover Trim Black Grain For Toyota 4Runner 2017+ ABS | eBay
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 05:53 PM #11
jane477 jane477 is offline
jane477 is on a distinguished road
see this Black Wood Door Handle Decor Cover Trim Black Grain For Toyota 4Runner 2017+ ABS | eBay
Do not be so hard on yourself
me, I'd probably overpaid some guy in the repair shop to fix it
jane477 is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 12:16 PM #12
QwikKotaTx's Avatar
QwikKotaTx's Avatar
I made a quick video of today's rear handle swap but it is pretty crappy and does not address keyless entry models. Does anyone think the partial license plate display at the beginning is a big deal?
https://www.youtube.com/watch?v=Z7Yk5etwX5g&feature=youtu.be
2010 SR5 MGM w/LEATHER
2002 DAKOTA 4.7L V8 VIPER T56
2015 RAM LARAMIE HEMI
Old 08-12-2021, 02:00 PM #13
jeremybenton's Avatar
jeremybenton jeremybenton is offline
jeremybenton is on a distinguished road
I can't seem to find the part number for replacement chrome door handles. Has anyone else been able to find it? It looks like everything associated with part number 6921160070 comes in a bunch of colors, but no chrome.
Current: 2012 4Runner SR5 4WD, 1977 Hilux Longbed 2WD
Past: 1996 4Runner Limited, 2007 4Runner Sport
jeremybenton is offline   Reply With QuoteReply With Quote
chrome , door , handle , replace , sr5
DIY: Exterior Door Handle Removal lightfreak 4th Gen T4Rs 15 11-27-2022 02:00 PM
Door handle removal help Pemrick 3rd gen T4Rs 10 10-16-2016 01:51 PM
help with door handle removal silversx 5th gen T4Rs 7 12-09-2015 10:34 PM
Door Handle Removal Stuck CAPS 4th Gen T4Rs 4 04-05-2013 12:11 AM
exterior door handle removal? mole177 4th Gen T4Rs 3 08-19-2009 06:01 AM
