Old 01-28-2019, 02:49 PM #1
omelette's Avatar
omelette omelette is offline
omelette is on a distinguished road
omelette's Avatar
Grinding/creaking noise when shifting from reverse to drive
My truck makes this concerning grinding/creaking noise on a cold start when shifting from reverse into drive.
Video here: 4runner_noise.mp4 - Google Drive
Has anyone else experienced this before? I couldn't find anything on here about it (unless of course, I'm an idiot). After driving for a bit, like if I go to the store, it doesn't make the noise.
Is this something with the transmission or the transmission fluid? I've had it at Toyota multiple times for services and other things and they have never said anything about it. Some mechanic friends have told me it's normal and nothing to be worried about but still.
omelette is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 03:05 PM #2
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
Check that your u-joints are properly lubricated.
2011 SR5/P 4WD Blizzard Pearl - 285/70/17 Falken Wildpeak AT3/W - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two-Tone Katzkin Interior - 15% Lumar Pinnacle Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips Interior LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 03:11 PM #3
TRDTommy's Avatar
TRDTommy TRDTommy is offline
TRDTommy will become famous soon enough
TRDTommy's Avatar
Sounds like mine after a cold start. I always thought it was normal. But curios now that its been mentioned.
2017 MGM TRD ORP w/KDSS
TRD Pro Wheels - 275/70/17 BFG KO2 - Spidertrax 1.25" Wheel spacers
Kings shocks w/front and rear adjusters, Icon Delta Joint Tubular UCA, Dobinsons rear coils
Sherpa Crestone roof rack
TRDTommy is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 06:47 PM #4
themaestro's Avatar
themaestro themaestro is offline
themaestro will become famous soon enough
themaestro's Avatar
I feel like mine does that if I'm not hard on the brakes while the shift happens, like the brakes are "rubbing". Try really pushing on the brakes and see if it does it.
If it's still doing it, I concur with the above, lube your driveshaft/U joints. I bought a grease gun and do it (6 zerk fittings) at every oil change. It seems to keep the driveline smoother.
themaestro is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 07:59 PM #5
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
drive train noise clunk sure can be you did not lube the drive shafts and the yokes..
MOLY GREASE ON THE YOKES 2 PUMPS .....LITHIUM GREASE ON THE U JOINTS PUMP UNTIL THE GREASE POPS OUT THEN CLEAN UP THE GREASE THAT CAME OUT ...
I do this every oil change 7500miles.
very smooth shifts no clunks ..
catrains is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 04:29 PM #6
Jonny_04's Avatar
Jonny_04 Jonny_04 is offline
Jonny_04 is on a distinguished road
Jonny_04's Avatar
Were you able to ever get this resolved? I'm having the same experience right now with a brand new 2019 TRD ORP.
Jonny_04 is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 10:49 PM #7
Titties地達eer Titties地達eer is offline
Titties地達eer is on a distinguished road
Any resolution reached? I noted a similar sound this morning after it had been out in a cold rain all night. I couldn稚 replicate it after driving it later but I think it may have to do with not traveling enough in either gear (maybe 5-10)
Titties地達eer is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 10:51 PM #8
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I think it's the brakes, press harder on the pedal when you're stopped and shifting.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 11-23-2019, 07:28 PM #9
I was able to replicate this during multiple phases of driving around today despite really stepping on the brakes. The truck has <500 miles on it so I知 assuming it has to do with the bedding process. I致e been really easy with them so far and they still squeak a fair bit while rolling after being parked overnight. Brake seem to also have poor cold bite compared to other examples I drove before purchasing, but I致e been enjoying the (relative) pedal modulation vs sudden nosedive I experienced on a few others.
I am expecting that it will improve with mileage, will report back if I find out something else.
Old 06-30-2020, 07:15 PM #10
k2theablam k2theablam is offline
k2theablam is on a distinguished road
Hey, just wanted to check in on this issue.
I have a 2019 TRD ORP and have noticed this cranking/grinding noise on cold startups when shifting from P to R, and much more from R to D.
Does anyone have any experience with this?
k2theablam is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 11:32 PM #11
lanceramirez19 lanceramirez19 is offline
Real Name: RugarayX
lanceramirez19 is on a distinguished road
Real Name: RugarayX
any updates about this noise problem? having issue this in my 4Runner Limited 2019
lanceramirez19 is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 10:18 AM #12
PrettyGoodSam PrettyGoodSam is offline
PrettyGoodSam will become famous soon enough
This happens on my 2012 TE as well. i have brand new rear brakes as of november 2019 and the front are in great shape...wondering if it is a u-joint, etc lube issue indeed.
PrettyGoodSam is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 09:56 PM #13
Real Name: RugarayX
Real Name: RugarayX
Hey bud, have you figured out what's the grinding noise when you shifting from reverse to drive? I'm having same problem right now, 4Runner Limited 2019 with 9k miles only. Thanks
Old 07-14-2020, 10:34 PM #14
Real Name: RugarayX
Real Name: RugarayX
Old 07-15-2020, 02:34 AM #15
Whippersnapper02's Avatar
Sounds like normal brake noise.
drive , grinding/creaking , noise , shifting , transmission
Gear grinding noise when shifting from 4H to 4L BobsTrail 5th gen T4Rs 12 04-12-2016 05:11 PM
Delay in Shifting from Reverse to Drive NWSKIUrbanRunner 4th Gen T4Rs 17 04-09-2016 07:50 AM
awful grinding noise shifting from 2hi to 4hi Will_4R 4th Gen T4Rs 9 02-23-2010 08:07 PM
shifting from reverse to drive - v8 4wd V8Limited4wd Problems & Warranty Issues 1 03-13-2008 08:44 PM
Transmission thump when shifting from reverse to drive blairbaxter 3rd gen T4Rs 1 11-28-2007 10:28 PM
