Old 02-03-2019, 11:55 AM #1
125mph 125mph is offline
125mph is on a distinguished road
Remote locking does lights go on?
My 2014 4runner got damaged by a hit and run last month. We just got it back after $7k of repairs. However, i noticed my keyless remote doesnt blink the lights or beeps sound when I lock. It still lights and beeps when I unlock.
I took it back to the shop and they said Toyotas dont blink light up when its locked but he said he eould look at the sound issue. Is that true? I could have sworn that the lights blinked when i hit the lock botton in addition to the audio.
125mph is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 12:01 PM #2
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Yes it should flash the lights and make the normal sounds. I think both of these are user selectable but you'll need a tech to access them in the computer. I'd bring it back to them and have it fixed. If they are not a dealer then you'll need to bring it to one.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 12:19 PM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman has a spectacular aura about Bossman has a spectacular aura about Bossman has a spectacular aura about
Bossman's Avatar
From the Toyota 4Runner Owner's Manual:
Opening, Closing, and Locking the Doors - Smart Key System
Operation signals - A buzzer sounds and the emergency flashers flash to indicate that the doors have been locked/unlocked. (Locked: once; Unlocked: twice).
Summer: Michelin Premier LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 03:29 PM #4
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
You can set it to do whatever you want with Carista or something like that. Unless they changed the programming though it should have come back from the shop the way it went in.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 05:52 PM #5
jhguth jhguth is offline
jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light
It wont beep and blink the lights when the door lock actuator fails because a doors not locked, that's how I learned mine had failed
jhguth is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 07:00 PM #6
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
^^^ This. I'm hoping maybe they didn't reconnect one of the actuators. Still, them stating incorrect information as a fact is troubling.
2011 SR5/P 4WD Blizzard Pearl - 265/70/17 BFG K02 C - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two Tone Katzkin Interior - 15% Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 08:24 PM #7
Thanks guys! I will go back to the shop next week..
What's more troubling is that they first said nothing was wrong, and the reason there was no beeping sound is because my remote battery was low... Then I pointed out to him the unlock still beeps fine, and the sound comes from the car, not the remote....
They said they would order me a new horn since maybe the horn is failing.. Does the beeping sound actually come from the horn?
Old 02-03-2019, 08:36 PM #8
Bayou_Pro's Avatar
Bayou_Pro's Avatar
No it's a high pitched beep not from the horn.
Paul
Old 02-03-2019, 08:55 PM #9
If everything works when you unlock but not lock you should really check your door lock actuators. Unlock all the doors, then lock with the remote, then try to open each door. I bet one of them is still unlocked and open. If that's the case lock it manually then hit the lock button on the remote and I bet it beeps.
Stop going to that dealership, find another one, this is a common problem.
Old 02-04-2019, 11:34 AM #10
That was it! The left passenger door wasnt locking... I can manually lock it and then the lock/unlocks work.. But after a while, it gets stuck again. That means I need a new lock accuator for that door?
Old 02-04-2019, 12:11 PM #11
yep, you can just replace the motor for about $6 and maybe 15-20 minutes to replace
https://www.toyota-4runner.org/5th-g...-pics-%5D.html
you want the standard length, flat shaft part:
Mabuchi Nichibo Door Lock Motor Flat or Round Shaft 20mm or 10mm FC-280PC-22125 | eBay
Old 02-04-2019, 05:56 PM #12
Superjet Superjet is offline
Superjet will become famous soon enough Superjet will become famous soon enough
Where was the vehicle damaged? It could be just simply not plugged in or damage to a harness if the problem occurred after the accident.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 02-07-2019, 03:14 PM #13
Okay, took it to another shop because I needed to get an oil change too.. Had them look at the lock, and indeed the motor / actuator is damaged.
$115 for labor and the part they said was $315.40.. wow a lot more than the $6 bucks I thought.
Good thing the insurance is covering it.
Old 02-07-2019, 03:15 PM #14
Was hit mostly at the driver side door and towards the front but did hit the rear driver side door as well..
The lock issue is from the rear driver side door.
Old 02-07-2019, 06:31 PM #15
They can only replace the full actuator, that's the right price for OEM. You can get an actuator on amazon for like $50 though. You have to open the actuator to replace the motor.
This is a common failure item, the replacement actuators have the same bad motor
back , blink , hit , lights , remote
Remote locking hubs Friedom Classic T4Rs 17 06-28-2017 11:43 AM
Problem with Key Remote and Locking/Unlocking Doors HI808SR5 5th gen T4Rs 4 08-18-2013 06:27 PM
Entail locking remote window control adolfo1 New Members 0 05-09-2013 10:15 PM
Remote Locking Issue KellyJ 3rd gen T4Rs 9 12-29-2007 04:20 PM
door locking, but no lights or beep? TiTaniuM4Runner Engines / Suspension / Wheels / Tires / Audio / Accessories 4 05-14-2005 12:59 PM
