Old 02-04-2019, 06:05 PM #1
DrVolkl's Avatar
DrVolkl DrVolkl is offline
DrVolkl is on a distinguished road
DrVolkl's Avatar
Regaining lost height after Baja/Sliders
2018 TRD Pro and after adding a ton of weight to my rig, I feel like I've lost an inch or two of overall height. (lift)
What's the easiest way to gain some back? Spacers? Springs? I'd prefer to keep the damn TRD suspension, just looking to gain back what I lost, not lift it into the sky.
Thanks for any advice...
2018 TRD Pro - Cavalry Blue
DrVolkl is offline   Reply With QuoteReply With Quote
Old 02-04-2019, 07:41 PM #2
Industrialwrench Industrialwrench is offline
Industrialwrench is on a distinguished road
Springs to match the added weight.
Industrialwrench is offline   Reply With QuoteReply With Quote
Old 02-04-2019, 07:53 PM #3
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
BAJA1 - 1" Front Lift for TRD BAJA and Pro Edition Tacoma & 4Runners
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 02-04-2019, 07:53 PM #4
mtnbiker49 mtnbiker49 is offline
mtnbiker49 is on a distinguished road
For a baja rack and sliders? No way you lost 1-2" of height. Absolutely no way. That weight is evenly distributed and if anything, the sliders offset the weight of the rack to keep the COG nearly the same. Wouldn't affect height much at all...less than 1/2".
mtnbiker49 is offline   Reply With QuoteReply With Quote
Old 02-04-2019, 08:50 PM #5
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R is a name known to all MAST4R is a name known to all MAST4R is a name known to all MAST4R is a name known to all MAST4R is a name known to all MAST4R is a name known to all
MAST4R's Avatar
Yes, there is no way you lost that much EXCEPT under the rocker panel.
Did you ever measure your ground clearance at the skid plates new? That's the measurement that matters. What is it now under the front edge?
The sliders really do eat into the rocker panel clearance, which is an excellent 17" stock on a regular TRD. I lost 3" to my Shrock sliders. That's fine even for difficult trails. Very difficult and extreme trails are another story.
Worst case scenario if you keep adding weight, maybe get Dobinsons springs to replace the factory ones. I don't think there are many options for 6112 shocks anyway.
(6112s/650lb at 1.3" lift, Icon 2.0 and Eibach 1" rear, Mickey Thompson ATZ P3 LTE 265 70 17 and Falken Wildpeak AT3W P265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids).
Old 02-04-2019, 09:49 PM #6
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: 2018 BLACK TRD PRO
TRD PANTHER has a spectacular aura about TRD PANTHER has a spectacular aura about TRD PANTHER has a spectacular aura about
Added Burtman Industries Cornfed UHMW 1.5/1” Pro spacer lift to the factory Pro suspension. Cost me just under $300 for parts, labor and alignment. 275-70-17 KO2’s. I have a set of Shrockworks sliders that I recall are 45 lbs. per side. I would be surprised if the truck lost any height. Forum member Tejas has a TRD Pro with a full rack and sliders with the spacer kit and tires I have. May want to find out what his results were. Even with the factory suspension I would be surprised if you would lose any height over a 1/4”.
Regaining lost height after Baja/Sliders-00597bb9-d1b3-4f8f-b820-ed43128d6012-jpg
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 01:24 AM #7
4Reak Show's Avatar
4Reak Show is a jewel in the rough 4Reak Show is a jewel in the rough 4Reak Show is a jewel in the rough 4Reak Show is a jewel in the rough
4Reak Show's Avatar
Wrong. Dumb.
Old 02-05-2019, 08:09 AM #8
JP421's Avatar
JP421 JP421 is offline
JP421 is a jewel in the rough JP421 is a jewel in the rough JP421 is a jewel in the rough JP421 is a jewel in the rough
JP421's Avatar
Originally Posted by 4Reak Show View Post
Wrong. Dumb.
That's helpful.
2019 TRD Off-Road Premium - no kdss - 285 Cooper STT Pros
Dobinsons - Front: C59-300, GS59-574 Rear: C59-505, GS59-701 - JBA UCAs
RSG Metalworks Sliders - Angled
JP421 is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 08:24 AM #9
jhguth jhguth is offline
jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light
how is stiffer springs for added weight dumb?
jhguth is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 03:26 PM #10
Jbellah's Avatar
Jbellah Jbellah is offline
Jbellah is on a distinguished road
Jbellah's Avatar
Originally Posted by TRD PANTHER View Post
Added Burtman Industries Cornfed UHMW 1.5/1 Pro spacer lift to the factory Pro suspension. Cost me just under $300 for parts, labor and alignment. 275-70-17 KO2s. I have a set of Shrockworks sliders that I recall are 45 lbs. per side. I would be surprised if the truck lost any height. Forum member Tejas has a TRD Pro with a full rack and sliders with the spacer kit and tires I have. May want to find out what his results were. Even with the factory suspension I would be surprised if you would lose any height over a 1/4.
Hi has everything been since the add one?
Jbellah is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 04:52 PM #11
Im guessing you were trying to say, has everything been done since the add ons? Are you referring to the sliders and my lift? Please clarify your question. Thanks.
Old 02-05-2019, 08:06 PM #12
DrVolkl's Avatar
DrVolkl's Avatar
Sure seems like I did... the baja rack weighs a ton, the sliders weigh a ton... the truck is loaded down... why wouldn't that compress the springs?
I parked next to my buddies stock SR5 and we're the same height at the mirrors.
I even have bigger tires on it... so there's something up for sure.
I think I'll try the burtman spacers... seems easy enough.
Old 02-05-2019, 08:14 PM #13
comtn4x4's Avatar
comtn4x4 comtn4x4 is online now
comtn4x4 is a jewel in the rough comtn4x4 is a jewel in the rough comtn4x4 is a jewel in the rough
comtn4x4's Avatar
Can you take some center of wheel to bottom of fender measurements on all four corners? And hopefully someone with a stock pro could chime in with similar measurements. That's really a better way to judge what's going on
If you're not happy with the height you need to re spring it to do it right. Or wait till you have a good idea what you're going to add for additional weight and when to decide what to do.
'13 TE w/ KDSS, 4:56 Gears, Radflo 2.5" front and rear. Eibach 700# Front, Dobinson C59-701V Rear, Sonoran Steel KDSS Trac Bar, BlackGate Customs KDSS Blocks. Fuel Revolver Rims 17x9 +1 mm 5" Backspace, Cooper ST Maxx 285/75r17, Hefty Fabworks Aluminum Front Bumper and Full Skids, C4 Fab Dual Swingout Rear Bumper, OPOR Sliders
comtn4x4 is online now   Reply With QuoteReply With Quote
Old 02-05-2019, 08:18 PM #14
catrains catrains is offline
catrains will become famous soon enough
you lost height because the springs take a set after a few K miles.. then adding some weight will drop it a bit more.
my 2016 runner did this .. front end dropped 1inch ..
On my GM truck this happened but I had torsion bars so I could get it back to the proper height.
since you lost some height you will need a front end alignment ..
catrains is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 08:56 PM #15
MAST4R's Avatar
MAST4R's Avatar
It still is very interesting. If you are the same height as an SR5 with a Pro (+0.8) and 33s (+0.5) then you have lost about 1.25" out of just a rack and sliders and some settling. Makes no sense, honestly, unless the Pro springs are softer than regular TRD ones.
What's the Baja Rack, 100lb? What are the sliders? 100-150, 150 max.
So, you are 200-300lb over stock. I am 250 and had not lost more than maybe 0.25" after 15,000 miles with all the settling of springs (maybe they settled 0.25" at most; I think less).
back , gain , height , lift , lost
New Baja Designs S8 LED Light Bar - Replaces Baja Designs Stealth - Now Shipping TotalAutomotiveLV Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-03-2016 08:24 PM
Baja Utility Rack - Height off top of vehicle? Keith_PDX 5th gen T4Rs 4 02-15-2016 12:24 AM
In memory of those lost and those who have lost SV_Dude Off Topic 6 09-11-2013 09:58 PM
Ahh ... Height control and adjustable tail end height? coconutpete 4th Gen T4Rs 3 02-26-2013 11:49 AM
