Old 06-21-2019, 03:14 PM #1
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
Alignment Question
A bit over a year ago I had a 2.25" lift on my truck and at the ~500 mile mark I had the alignment re-done. They were only able to get the caster to 1.9.
I drove it like this for almost a year and last weekend upgraded to JBA UCAs.
I just took it in for an alignment and they were able to get caster to 4.0/3.8. Terrific.
What was odd is that the report shows the before on the caster as 3.9/4.7.
How could that be?
Here's the report
Alignment Question-img_4699-jpg
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 03:21 PM #2
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
Aftermarket UCA's are designed to increase caster by default. The 'before' number is what the JBA's achieved once you put them on. The alignment 'fine tuned' it
How could that be?
Here's the report
Daikon is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 03:31 PM #3
plasticsnaks plasticsnaks is offline
Real Name: Brett
plasticsnaks is on a distinguished road
Real Name: Brett
The JBA’s are built with an added ~2* caster....so you were at +1.9* with stock uca’s then the JBA’s added ~2*....that’s where you got the increase on the “before” reading.
Edit...
Daikon beat me to it ����
2022 SR5 Barcelona Red
2019 Tacoma Trd Off-road
plasticsnaks is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 03:49 PM #4
Thanks for the quick replies.
I thought alignment adjustments were done at the LCA.
if the LCA was locked into place (alignment-wise) wouldn't new UCAs not have an affect until they're adjusted?
Build thread
Old 06-21-2019, 04:10 PM #5
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
Caster angle is determined by the geometric relationship between the ball joint locations on the lower and upper control arms. Lifting the truck changes this relationship and reduces the caster angle. Adjusting the lower control arm eccentric cam bolts can regain some, but not all, of what was lost by moving the lower control arm ball joint slightly forward.
Aftermarket upper control arms move the upper ball joint location rearward compared to stock. This results in increased caster angle -- usually about 2 degrees, as pointed out above -- even if the LCA adjusting bolt settings aren't touched.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 05:12 PM #6
Daikon's Avatar
Daikon's Avatar
Thanks. I needed this explanation too!
Old 06-21-2019, 06:16 PM #7
Ok. Next question. I've noticed I still get a bit of rub on the body mount on passenger side. I plan to crayon it and see how bad it is.
But, is there a way to avoid doing a BMC? Would moving Caster higher affect anything negatively? Would that even solve the issue?
Would going up another 3/4" on the lift help? (I'm at 2.25" now)
Would spacers work? I believe that would make it worse but it doesn't hurt to ask.
Wheels are 17x8.5 with -6 backspacing
Build thread
Old 06-21-2019, 07:46 PM #8
Real Name: Brett
Real Name: Brett
Thumbs up
Yes go higher on the caster if it’s not maxed out already. Go as high as you need to clear the body mount if possible. Higher caster should have no negative effects as long as you get the camber and toe in spec. Lifting more will not help as when you compress the suspension it’ll still rub....and your -6 wheel backspace is fine. Wheel spacers will also most likely make your tire rub worse.
Just went through this with a friends t4r...2.5” lift with JBA uca’s....-10 backspace 8.5” wide wheels with 285 toyos. Maxed out the caster on drivers side but still just barely rubs the body mount. Passenger side has more adjustment left....he didn’t want to chop the body mounts so he’s going with 265’s.
Old 06-24-2019, 12:38 PM #9
@plasticsnaks or anyone else
I just dropped the truck off at the alignment place. The tech I spoke with warned me against going higher on the caster saying it could cause issues with the drive train and how it handles on and Offroad. I understand that the turning radius will be affected somewhat but would going from 4 to 5 degree of caster really affect the drivetrain and how it acts when 4x4 is engaged?
I told him lets see what they can get out of moving it forward a bit. It doesn't rub at all when moving the tires to and fro while standing still, only when in motion and at a sharp turn.
He was really pushing doing the BMC which I just don't want to do.
Build thread
Old 06-24-2019, 01:30 PM #10
Real Name: Brett
Real Name: Brett
Hey mscot, I really don’t think going higher in caster (4.5-5) is going to affect your drivetrain nor have effects on road and off road driving....especially with 2.25” lift. The tech may not be factoring in that your JBA’s moved the upper ball joint towards the rear. It’s definitely worth trying to move you caster up to get the tire off of the body mount...if that doesnt move the wheel foward enough, then you’ll be facing the BMC or smaller tires.
Hope you get it to your liking!
Old 06-24-2019, 02:52 PM #11
Thanks.
Build thread
Old 06-24-2019, 03:32 PM #12
Luckily they got caster to 4.5 and no rubbing now.
Camber is at -1 and -1.3 which isn't great but I'll take it for now.
Build thread
Old 06-14-2020, 12:17 PM #13
Run Forrest Run's Avatar
Run Forrest Run Run Forrest Run is offline
Run Forrest Run will become famous soon enough
Similar situation and could use experienced eyes and feedback.
Installed Ironman Nitro lift (3”/2.5”) and Ironman UCA’s w/ 4* built in caster.
Went to local shop for alignment assuming it should be simple. Currently running stock wheels/tires with plans to size up to 285’s. I requested caster above 4 to avoid future rubbing with stock wheel. Tech worked diligently for 2.5 hours but it was obvious he didn’t have experience. I should have asked more questions before taking it in- my bad. End result is that all is in spec, but couldn’t get Caster above 3.0 on drivers side and 2.8 on passenger. It drives great, but could use some advise. Should I find a more experienced shop before buying new tires or am I being OCD that my Caster is in the low end of spec?
Before and After alignment specs and photos of L and R rear LCA below.
Does it look like the LCA was even adjusted or is it still in the neutral position?
I see signs of adjustment but don’t know how to read what was done.
Thanks for any experience or advice you can offer!
Alignment Question-8fc14592-11be-4d69-963c-01d5c15e2418-jpg  Alignment Question-0935dacc-1617-42af-8f3a-b86c39341da8-jpg  Alignment Question-b61b2452-d394-4b00-abc9-de6003cba0d1-jpg  Alignment Question-08c550a1-e048-4285-b276-7de033728e2f-jpg
2023 TRD OR, Lunar Rock
Run Forrest Run is offline   Reply With QuoteReply With Quote
4.0/3.8 , alignment , caster , report , year
Yet another alignment question! jasonator 5th gen T4Rs 3 05-03-2018 09:45 PM
Alignment Question KalihiRunner 5th gen T4Rs 6 10-06-2016 12:52 PM
Alignment question Rushingman 4th Gen T4Rs 4 07-17-2016 06:02 PM
alignment question Funcrazy1 3rd gen T4Rs 66 11-17-2015 09:55 AM
Alignment Question tamadabee128 5th gen T4Rs 9 07-01-2015 05:26 PM
