04-16-2019, 10:58 AM
#16
Thanks for the pics, exactly what I was looking for!
It seems stupid, but I'm fighting with my front mudflaps since adding Spidertrax 1.25" wheel spacers, running 17" FJ Cruiser 8-spokes with 255/75/17 Duratracs. Was able to move the front fender liners ahead and out of the way, but even with the inner mudflap panels completely removed I'm still getting rubbing in reverse with the wheel turned...so every time you back out of the driveway or a parking spot, very annoying.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
04-16-2019, 11:57 AM
#17
i took mine off. reverse it was definitely rubbing
275/70r17 on scs 17x8 ray10s
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
04-16-2019, 12:08 PM
#18
Have you replaced your UCA's? What is your caster at? If you have it between 3.5 and 4 you should have no rubbing.
04-16-2019, 01:03 PM
#19
Stock UCA's as I've only got a 1" leveling spacer on the front, I had it aligned after installing the spacer lift but I'm not sure what the castor setting was.
04-16-2019, 01:48 PM
#20
You may want to take it back and have them re-align for at least 3.5 cater , both sides. Iffy weather or not you can get that with stock UCA's.
04-16-2019, 01:55 PM
#21
Can someone with the mud flaps take actual size measurements?
Don't really want longer mud flaps but I do need some a little wider.
2018 TRD OFF ROAD
My Build
11-28-2019, 02:00 PM
#22
Originally Posted by OlyMM
I just installed these as well last month. It's tough to tell in this photo, but the regulars work well with 285s. There's a big difference in terms of spray on the side. I'm not sure there's a difference compared to the OEMs in terms of hatch spray.
They do hang lower than the OEMs enough that I'll probably take them off when it's time to hit the trails in the summer.
Also - zero rub with the 285s, which is what drew me to them in the first place (OEM fronts were removed with the lift/new wheels).
Any spacers with your 285s? Or what offset are you running? Trying to decide between the reg or XL myself. Im running stock Off Road wheels, 285s with 1.25" spidertrax.
11-28-2019, 03:06 PM
#23
What material are these made of? Is it a hard plastic like OEM, flexible rubber like old school mud flaps, or somewhere in between?
2015 SR5 Premium Bilstein 5100 | Dobinsons Springs | SCS SR8 | 285 Toyo Open Country AT3 | Trail Rack | TRD Intake | Borla Side Exit Exhaust | TRS LEDs | JBA UCAs | CTH T9 | Pioneer 9605 AMP | Scanspeak tweeters, Kicker 6x9s, Dayton HO 10"
11-28-2019, 04:05 PM
#24
They are not flexible rubber. It’s about the same stiffness as the stock.... maybe a little stronger material. I installed them and really like them. Much better coverage vs the factory flaps and more clearance for the front. Haughty recommended.
2023 TRD Pro Solar Octane:
2019 TRD ORP Mag Grey (sold), 2014 SR5 Mag Grey (sold), 2010 SR5 Pearl White (sold)…if you can’t tell I love 5th Gens.
11-28-2019, 11:12 PM
#25
Originally Posted by SR5Bart
Yeah I got 285s on there and the rims are -10 offset so XL it is.
How are those XL Rokblokz working out with your 285s? Any pics by chance?
06-15-2020, 03:08 PM
#26
Did you end up finding a good mud flap option? Just threw on some spidertrax as well, had to remove my flaps but I’m looking for a replacement.
'15 Barcelona Red Trail. Bilstein 6112 front, 5100 rear, KO2 285/70R17, Method Racing MR305 NV... Open to any and all suggestions!
04-09-2021, 08:50 AM
#27
This appears to be about the best source of info for Rockblokz mudflaps on the 5th gen’s but curious if anyone subscribed has any more info about fitment or long term use ?
Anyone run into
Problems with them ?
Seems the thread went pretty quiet.
I’m looking to go bigger rubber and want to keep the front mudflap protection and possibly improve on it.
04-09-2021, 09:03 AM
#28
Anyone run into
if you want a flexible option (rokblokz are stiff plastic), rally amor might be better - 2012-20 Toyota 4Runner, Rally Armor
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
