View Poll Results: Nice Device or Crack Pipe?
No way, you're too fat. 21 48.84%
21 48.84%
It will be fine, I am an engineer on the internet. 22 51.16%
22 51.16%
Voters: 43. You may not vote on this poll
Old 02-08-2019, 12:52 PM #16
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Originally Posted by KingTaco View Post
I am in similar FB territory. FWIW it is made out of "aircraft grade" aluminum. Says it is designed to support a 400 pounder. I assume that incorporates the force a 400 pounder can apply. I just added a link in my original post.
That's not an actual grade of aluminum, it's a marketing buzzword
jhguth is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 12:55 PM #17
KingTaco's Avatar
KingTaco KingTaco is offline
KingTaco is a jewel in the rough KingTaco is a jewel in the rough KingTaco is a jewel in the rough
KingTaco's Avatar
That's why I put it in quotation marks. Thought it was funny.
KingTaco is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 01:00 PM #18
KingTaco's Avatar
KingTaco's Avatar
Originally Posted by mcarey86 View Post
I'd be concerned about possibly misaligning the door latch.
I could be wrong, but I'd imagine the latch is just bolted to the sheet metal. Wouldn't that be pretty easy to flex out of place a bit? Surely they weren't engineered to take flex like this would put on it.
Also, what happened to using the tires like a normal person?
The tire may still be fine. I haven't mounted the tent yet, so I just don't have a feel for how much more (if any) reach I will need. It will obviously be higher, so I assumed I would want more.
Old 02-08-2019, 01:21 PM #19
svana svana is offline
svana is on a distinguished road
I bought one off of Amazon a few months ago that had a hinge to fold flat and only came with a sticky backed tape to protect the body from damage of the step. I returned it because it was advertised to come with a more robust rubber boot, so I never got to try it. In that situation the hinge would've been the obvious weak point. Here it looks like it eliminates that problem (of course at the cost of portability) - I might consider trying one out (I'm 240 for reference). If it's one solid piece of aluminum, I think it should be able to hold (I'm not an engineer, I only hire them lol). The door latches are bolted into much more than sheet metal - if I understand correctly, they're required to hold a door in place for up to 4,500N (~1,000lb of force). Of course that's lateral force versus vertical force, but still. Wife was actually the one who brought it up since she's clocking in at 5'3 and cant reach the rack all that easily.
svana is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 02:17 PM #20
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Originally Posted by rihavens View Post
My math is shaky at best, but the step is twice as long as the arm holding it. That means it doubles the load force on the other side of the fulcrum. That means if I put my fat boy 270 pounds of force on the step, the top of that arm is holding back 540 pounds. That's assuming dead weight. Stepping down on it would create more force. I am sure someone will correct me. But that shitty piece of plastic does not look like it's going to support that.
You nailed it for the worst case scenario. The dynamic loading of stepping up onto it would cause more lateral and vertical force on the latch than I would be comfortable with.
El Dusty is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 02:24 PM #21
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
Lose some weight?
Toffees is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 02:26 PM #22
Toffees's Avatar
Real Name: Micah
Toffees's Avatar
Real Name: Micah
That was my thought, more worried about damage to the latch than anything else. Don't want the door to open unexpectedly, especially in an accident.
Old 02-08-2019, 02:43 PM #23
notoriouslyKEN notoriouslyKEN is offline
notoriouslyKEN will become famous soon enough
I bought one of these on Amazon today, before I saw this topic. I'm a larger guy at 250lbs, so I'll be interested to see how it holds me.
notoriouslyKEN is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 03:26 PM #24
michalik.piotr6837's Avatar
michalik.piotr6837 michalik.piotr6837 is offline
michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough
i have a similar one, comes with a seat belt cutting tool and glass breaking tool at the end. i'm 200lbs and use it to tie up surfboards on top of the hard shell tent.... love it. works way better then stepping onto the front door arm rest or window switch panel with sandy feet. Hope it helps.
michalik.piotr6837 is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 04:06 PM #25
3wbdriver's Avatar
3wbdriver 3wbdriver is offline
Real Name: CJ
3wbdriver will become famous soon enough
3wbdriver's Avatar
Real Name: CJ
I bought a 300# rated 2' high fiberglass step ladder. I can walk it around the truck as needed to get at everywhere on the roof rack, and it is small enough folded to fit in the back or on the rack with gear. I do have one of those aluminum door jamb steps and it seems to hold my weight fine, but the small footprint is hard on my arthritic feet. The ladder went on 3 camping trips last year and works like a champ.
https://www.amazon.com/Louisville-FS...s%2C195&sr=8-5
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
3wbdriver is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 04:22 PM #26
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Originally Posted by 1jzgte View Post
the only damage i can predict is when you forget to remove it while your instincts tell you small the door shut... door plastic and paint damage
Now THAT is a real concern. That's going to happen eventually for sure!!
Naw, that latch striker is beastly strong. Designed to keep the door shut in the worst collisions. You'd have a hard time bending it with a sledge hammer.
Originally Posted by Furagwa View Post
When I looked at how high my striker was from the ground it didn't look like it would be too easy to even get up onto the step. And then it would put me up too high
Well, presumably you'd step up on the door threshold on your way up to it.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 04:44 PM #27
Z-MAN54's Avatar
Z-MAN54 Z-MAN54 is offline
Z-MAN54 is on a distinguished road
Z-MAN54's Avatar
I have one and use it often. It works as advertised. MOKI door steps are pricey but work great for those looking for roof top access. Amazon has cheaper brands from China. I can't say they are good or bad just cheaper.
Z-MAN54 is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 04:45 PM #28
Rightside Up's Avatar
Rightside Up Rightside Up is offline
Rightside Up will become famous soon enough Rightside Up will become famous soon enough
Mind blown!
2018 ORP Barcelona Red
Dobinsons 2.5”/1.5” lift with springs and shocks.
Diff. Drop.
Pro Comp UCAs.
RSG angled sliders.
Rightside Up is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 10:46 PM #29
rihavens's Avatar
rihavens rihavens is offline
rihavens is on a distinguished road
rihavens's Avatar
Originally Posted by Toffees View Post
Lose some weight?
Just started my cutting cycle.
rihavens is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 11:50 PM #30
codyHTX's Avatar
codyHTX codyHTX is offline
codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light
codyHTX's Avatar
Bought the Moki step to help reach mount latches and stuff at the front of my skybox, works really well. I just use 1 foot and don’t stand out on the end of it, I don’t see any flexing or bending. Solid piece of metal with a thick rubber boot at the bottom.
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
codyHTX is offline   Reply With QuoteReply With Quote
door , jamb , latch , spark , step
DIY: Replace door courtesy / door jamb switch (fix door ajar light and door sensor) andrewbares 3rd gen T4Rs 17 05-16-2021 03:17 PM
Yellow sticker in door jamb ? (Factory modifications) concrete_boots 5th gen T4Rs 56 08-28-2018 10:06 AM
Strange sticker on door jamb brockvond 5th gen T4Rs 21 03-26-2016 01:00 PM
Door Jamb Rust Fix nc-grayson 3rd gen T4Rs 8 02-23-2016 04:34 PM
